My front height is the same w/ trailer hooked up
Discussion in 'Towing & Hauling' started by IowaGuy, Jan 5, 2023.
  1. Jan 5, 2023 at 5:49 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    A few weeks ago I took some measurements when my trailer was hooked up and I was surprised to see that the front fender height stayed the same. The rear only dropped about 1.75 inches.
    My trailer is a 17 ft. toy hauler that I use as a camper and no toys. It is fairly light @ 3k lbs. and I do not know the tongue weight. I guess the rear springs took most of the weight and not enough to start moving the front end up? I am thinking of adding airbags or the spring helper for when I tow.
  2. Jan 5, 2023 at 5:58 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Doesn't your truck have about 2" of rake? I wouldn't change anything.
  3. Jan 5, 2023 at 6:00 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  4. Jan 5, 2023 at 6:14 AM
    IowaGuy
    In Process
    1.5 of rake. When I hooked up the back was down about 1/2 inch or so. I might just leave it
  5. Jan 5, 2023 at 6:17 AM
    There will not be a lot of weight transferred to the front without a LDH…and your setup doesn’t really require one.
  6. Jan 5, 2023 at 9:01 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Think of the front as a pivot point. A teetor totter has a pivot point in the middle since there's only one point of contact on the ground (the middle). A truck has two axles creating two points of contact (yes I know technically 4 since there's 4 tires). Therefore, you push down on one, without a significant amount of weight, and the other works as a pivot and wouldn't move much.
    You're overthinking this trailer thing. It's ~3klbs. Hook up and go enjoy it.
    JLS in WA likes this.
  7. Jan 5, 2023 at 9:13 AM
    Blue Thunder
    Washington
    I’ve measured these distances right after hooking up and then again after driving. They change a bit after things have “shaken out”. Having said that, with your light trailer I wouldn’t add any new gear unless you find the towing experience unpleasant.
    Cpl_Punishment likes this.
  8. Jan 5, 2023 at 9:15 AM
    AZBoatHauler
    So.Arizona
    Your rear shouldn’t drop almost 2” with 300lbs of tongue weight. My guess is the trailer is way out of balance due to the mods that have been made.
    Cpl_Punishment and TRDFerguson like this.
  9. Jan 5, 2023 at 9:22 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I highly doubt hubcaps would cause that much sag...
  10. Jan 5, 2023 at 9:51 AM
    IowaGuy
    In Process
    My trailer pulls great although I do have more weight up front. I added one lower kitchen cabinet in the front and I have a mini-split HVAC compressor on the tongue. I have an Anderson WDH that I am going to add just to help some.
  11. Jan 5, 2023 at 10:03 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    And think of the back as a 400# woman straddling a 135# guy.
  12. Jan 5, 2023 at 12:50 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    But....I don't wanna :help:
  13. Jan 5, 2023 at 3:18 PM
  14. Jan 5, 2023 at 3:37 PM
    SD Surfer
    Bruce
    So Cal
    I do NOT want to know how you found that!
    (Might wanna' clear your browser history though) :rolleyes:
  15. Jan 5, 2023 at 3:46 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I said, I don’t wanna think of it :rofl:
  16. Jan 5, 2023 at 4:03 PM
    IowaGuy
    In Process
    HO LEE CHIT, I am going to need a 6 pack to get that image outa my head. BAN ColoradoTJ
  17. Jan 5, 2023 at 4:19 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    ColoradoTJ 4 Prez - “Fat chicks need love, too. They just have to pay for it.”
    Bammer, Jaypown and Cpl_Punishment like this.
