My Front Blinkers Anger Me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jan 12, 2019.
  1. Jan 12, 2019 at 7:57 PM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    The more I see my directionals in reflections it angers me. They're weak as shit, Toyota definitely dropped the ball on them. What is the easiest fix? New LED bulbs? The flashback setup or whatever it's called? Help me out, this is going to be my next mod.
    Sp33dNut and hi_rawb like this.
  2. Jan 12, 2019 at 8:24 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I've been thinking the same thing. To the point I worry oncoming cars can't see me signaling. LEDs with resistor is the fix. I wish I did it when I installed my new headlights. I didn't wanna spend the extra cash but I know I will be soon. @BlueBottle I think is the man to talk to
    831Tun likes this.
  3. Jan 12, 2019 at 8:26 PM
    Silv333
    NJ-NC-MD-NC
    The whole resistor thing is German to me. Where does it go?
    Pudge likes this.
  4. Jan 12, 2019 at 8:38 PM
    Pudge
    CT
    I think it goes inline with the power wire to prevent hyperflash. Someone will know better than I.
    NewImprovedRon likes this.
  5. Jan 12, 2019 at 8:59 PM
    TokerJoker, B737, equin and 2 others like this.
  6. Jan 12, 2019 at 9:04 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    What Jim linked is what I have. You can get them w plug and play resistors and not worry about anything. No splicing. Get 3ohm resistors per side if your doing led to both front and rear. 6 ohm is your only doing the front in led.
  7. Jan 12, 2019 at 9:36 PM
    Silv333
    NJ-NC-MD-NC
    Thanks for the info. You have a video of the fronts in action?
  8. Jan 12, 2019 at 9:37 PM
    Silv333
    NJ-NC-MD-NC
  9. Jan 12, 2019 at 9:43 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I do somewhere but Have no idea where it is lol. It’s somewhere in this site.
    I have 2 sets of these resistors brand new. Each resistor will only take care of 1 led bulb. $12 shipped each or $20 shipped for both sets.
    https://www.vleds.com/vlr-6-duotap.html
    831Tun and Silv333[QUOTED][OP] like this.
  10. Jan 12, 2019 at 9:54 PM
    TheBeast The Beach
    VLEDs are solid.
  11. Jan 12, 2019 at 10:26 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  12. Jan 14, 2019 at 11:49 AM
    Ikonrat
    Ikonrat New Member
    2018 MGM DC TRD OFF ROAD
    For what its worth, I had a guy come up to me at the grocery store and tell me he can't see the turn signals of mine and other Tundra's. This after almost turning in front of me into the lot. I've had a couple other times where people at 4-way stop didn't realize I was turning. Once the guy told me, I knew I had to switch.
    After searching quite a bit on here and learning a heck of a lot about LEDs and our trucks, I bought multiple LED bulb types including $60 LASFIT bulbs with canbus built in and a $40 LASFIT switchback w/o canbus. I returned both of these. I ended up with the $20/pair LASFIT 7443 bulbs on Amazon and they are brighter than bright. No canbus or resistors needed. No hyperflash and people definitely see me turning now. I have stock 2018 DC SR5 with LED headlights. Here's the one I bought on AMZ...hope it helps.
    https://www.amazon.com/gp/product/B077PXPR23/ref=ppx_od_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  13. Jan 14, 2019 at 12:06 PM
    Silv333
    NJ-NC-MD-NC
    Thanks for sharing man. I will try them. Can you post a video so we can see the brightness?
  14. Jan 14, 2019 at 1:35 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    The OEM blinkers are dim. This is what I purchased. 4 min swap and done!!
    https://www.amazon.com/gp/product/B00PHVUWR8/ref=ppx_yo_dt_b_asin_title_o05__o00_s00?ie=UTF8&psc=1
  15. Jan 14, 2019 at 1:36 PM
    r1-superstar
    DB
    UTAH
    They are UBER Bright!!! No video needed. Take my word for it.
  16. Jan 14, 2019 at 1:43 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    No hyperflash with either Amazon buys?
  17. Jan 14, 2019 at 1:49 PM
    Silv333
    NJ-NC-MD-NC
    I was wondering the same thing
    yoshi82 likes this.
  18. Jan 14, 2019 at 1:50 PM
    Silv333
    NJ-NC-MD-NC
  19. Jan 14, 2019 at 1:57 PM
    YZTundy
    YZTundy New Member
    Denver, Co
    2011 Crewmax Rock Warrior
    As far as I know the JDM ASTAR's have a resistor built in
    Flyinryank and Pudge like this.
  20. Jan 14, 2019 at 2:04 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I just dropped $$$ on their site in a multi-bulb purchasing extravaganza as a result of this thread.
    Once installed, expect a roller coaster of a thread replete with up to the minute feline/Great Dane poo updates
    phogallen and panicman like this.
  21. Jan 14, 2019 at 2:06 PM
    Cthulhu
    yoshi82, Hatwsneezing, DMG85 and 2 others like this.
  22. Jan 14, 2019 at 2:27 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I used the same bulb for the front indicators in my 18 SR5 with the OEM LED headlights and works without hyperflashing.
    r1-superstar and WrigglingWilly like this.
  23. Jan 15, 2019 at 2:27 AM
    Ikonrat
    Ikonrat New Member
  24. Jan 15, 2019 at 3:13 AM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    Let me start by saying that I LOVE all my VLEDS bulbs and their customer service is the best in the biz but at $20 shipped to me I am getting these ^^^^.
    tundrarob, equin and WrigglingWilly like this.
  25. Jan 15, 2019 at 3:16 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Do the LASTFIT, JDM Astar or VLED bulbs for the front blinker still work as DRL?
  26. Jan 15, 2019 at 3:38 AM
    Ikonrat
    Ikonrat New Member
    The LASFIT does NOT work as DRL on the 2018 OEM headlights. I tried the $40/pair switchback model hoping it would. Only the amber illuminated during signaling only. The white stayed off.
    Vr0ck[QUOTED] likes this.
  27. Jan 15, 2019 at 4:50 AM
    niscur38
    niscur38 New Member
    I grabbed the lasfits for my 2019 thanks for posting up that info and video!
  28. Jan 15, 2019 at 5:41 AM
    SnrDisregardo
    Wade
    IL
    yoshi82 likes this.
  29. Jan 15, 2019 at 6:03 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Thanks! I just took a look at these, and my Amazon app says this product will NOT fit my 2018 Tundra. Is Amazon mistaken? Thanks again!
  30. Jan 15, 2019 at 6:07 AM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    Dude Amazon, really cmon you dudes rock love em. And they gave my jackwagon nephew a job wooooooo hooooo rock on bro.
