My first Tundra
Discussion in 'New Member Introductions' started by moviepro314, Sep 24, 2017.
  1. Sep 24, 2017 at 10:32 AM
    moviepro314
    moviepro314 [OP] New Member
    Iowa
    2017 Tundra Platinum
    Line-x Premium Spay-on bed liner, Truxedo Lo Pro Roll-up Tonneau Cover, Dual Swing Cases from Undercover, Pop & Lock Power Tailgate Lock, BottlePro 2
    I've been a Toyota fan forever and the Tundra body style just keeps getting better, in my opinion. I was finally able to buy my first Tundra, a 2017 Platinum, about 6 weeks ago and I'm loving it. Already had it on its first 4,000+ mile road trip.
    So far I've added a Line-x bed liner, Truxedo Lo Pro cover and dual Swing Cases by Undercover. More to come though it will be a slow process. Build list includes replacing factory JBL system, strobe lights, bed lights, floor mats, and whatever else comes up along the way.
    Casper3, MotoTundra, jfrd30 and 4 others like this.
  2. Sep 24, 2017 at 10:36 AM
    Welcome from CO!
    :worthless:
    4x4_Angel and Y0TA PR0 like this.
  3. Sep 24, 2017 at 10:36 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome from :canada:
    :worthless:
  4. Sep 24, 2017 at 10:36 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Sweet! Welcome from Texas! Sounds like you joined the right place to spend money! We help each other do that!:rofl:
    Side note: We are very visual people like kindergarteners and need pics....POST 'EM UP OF YOUR TRUCK! :D
    :worthless:
    831Tun likes this.
  5. Sep 24, 2017 at 10:50 AM
    Welcome from Texas! Until you post pics of your ride...:worthless:
  6. Sep 24, 2017 at 10:52 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from Las Vegas, you found the right place to spend all your money and money you don’t even have yet.
  7. Sep 24, 2017 at 11:01 AM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Welcome from SoCal
  8. Sep 24, 2017 at 11:19 AM
    moviepro314
    Iowa
    Of course I have pics!
    No patience around here... ;)
    757TUNDRA, Kyle100, CJ21 and 9 others like this.
  9. Sep 24, 2017 at 11:25 AM
    moviepro314
    Iowa
    First modification I did myself was a power lock for the tailgate. I went with one from Pop & Lock based on users on tundratalk.net. As others have stated, it is LOUD. But it works. I've tried a few different ideas to quiet it, but its metal on metal and you definitely hear it work. It would be better if there were less play in the actuator or if you could get some rubber on the tabs somehow. Heat shrink didn't do the trick, I tried... Still looking for a better solution to quiet the "clank" but otherwise I view this mod as a must. I'm not sure why Toyota doesn't make it standard.
    The install was easy. Run two wires (provided) up to the passenger compartment footwell and use that taps provided to get voltage from the factory harness. Took about an hour to get everything the way I wanted to, hardest part was getting through the grommet on the firewall.
    757TUNDRA and blue16 like this.
  10. Sep 24, 2017 at 11:27 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    OOOOOOOOOOOOooooooooo.....she's purdy!!! Your truck is a she right???
  11. Sep 24, 2017 at 11:31 AM
    moviepro314
    Iowa
    Next addition was the BottlePro 2.
    They make 2 different versions and I ordered one of each to try. I didn't like the way the Original version rested on the "chrome" trim piece so I wrote the company requesting an exchange and they just sent a replacement and told me to keep the original one as well. Its a husband and wife company and I highly recommend them. I wish Toyota hadn't move to the smaller cup holder size, but this is a great solution for those that like large beverages.
    BottlePro (Original) on the left and BottlePro 2 on the right.
    2 BottlePro 2s will fit next to each other without a problem.
  12. Sep 24, 2017 at 11:32 AM
    moviepro314
    Iowa
    Thank you! Definitely a she... Just won't tell me her name.
  13. Sep 24, 2017 at 11:38 AM
    moviepro314
    Iowa
    I'm loving the Swing Cases by Undercover. The hold a lot more than I expected. My biggest complaint is that on the first gen models, one of the pins on the hinge was longer than the other which was to make the case easier to line up. On gen 2, the made them both the same length, so lining up a case with up to 75 lbs worth of gear is a lot more complicated than it needs to be. I am a big fan of the ease of which the cases can be removed if you need bed space which was one of the main factors for going this route. I also wish the design allowed for a larger lock to lock the case in the bed, there isn't enough depth between the case and the lock point to allow for a large lock, and the small locks that will fit can easily be overcome. Luckily they are hidden under the Truxedo cover most of the time.
  14. Sep 24, 2017 at 11:42 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    She's being shy....give her time....she'll tell you eventually. :D
    Mine came with her name displayed on the monitor of the radio :p
  15. Sep 24, 2017 at 1:33 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  16. Sep 24, 2017 at 7:58 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Welcome. Great mods so far. Keep it up!
  17. Sep 24, 2017 at 8:17 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI
  18. Sep 24, 2017 at 8:36 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Welcome from Norcal, and good job with the prompt pics. :thumbsup:
    Double check and make sure your pop & lock is still locking the tail gate. It looks like they got some lineX on the part that moves. I just happened to check mine a few days ago and noticed it wasn't locking. It was still moving the actuator and making the loud thunk thunk, but not enough to lock. I sprayed it with silicone spray and it loosened up enough to start working again.
  19. Sep 24, 2017 at 10:08 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from N. Cal.
  20. Sep 25, 2017 at 4:49 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Welcome from NC
  21. Sep 25, 2017 at 6:02 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Welcome from San Antonio!
    Great looking truck!
  22. Sep 25, 2017 at 7:14 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO! Blue is the second best color behind white :D:crapstorm:
    Had no idea these cup holders existed . . . now I'm gonna have to look for them. Thanks for those pics.
    jfrd30, Eclipsed & Floating and G-man like this.
  23. Sep 25, 2017 at 7:15 AM
    G-man
    G-man New Member
    DFW, Texas
    2017 Platinum CM Super White
    Welcome from Texas! I'm really digging the swing cases. First time I've seen them.
  24. Sep 25, 2017 at 8:37 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Ohh man, i didn't know those cup holder adapters existed. My hydroflask has been rolling around the front on side tray of the center console. I'm ordering 2 from Amazon
  25. Sep 25, 2017 at 8:40 AM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    Nice rig! Welcome from CO
  26. Jan 20, 2018 at 9:57 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Can the swing case be opened when it is in the folded in position? In one of your pics it looks like your drivers side case is sagging..Is it saggy when loaded up? Case looks to be made out of plastic...how heavy duty is it really. Can you flex the case up and down?...is the hinge not beefy enough?
    MotoTundra and ladywolf like this.
  27. Jan 21, 2018 at 4:16 AM
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
    definitely following on this! I like those!!!
    MotoTundra likes this.
  28. Jan 21, 2018 at 4:28 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have a Swing Case so I will answer until someone else chimes in.
    Yes, you can open it when in the folded position, but just a little. I will try to grab a pic when I can, sick as a dog at the moment.
    I had to use the bed rail lowering brackets to use my tonneau with the bed rails, without going to my truck to look I think that may restrict opening the Swing Case a little bit when in the folded position compared to not having those relocation brackets.
    It is made of plastic. Mine doesn't say, but if I have my tonneau open and my windows down I can hear it making a little noise back there while hitting small bumps and going slow, I think it is the play that the bracket allows. I wouldn't call it heavy duty, I'm sure Undercover can give you the max weight recommendations. It's more than enough for what I out in there. Ex. Tow straps, bungees, hitch pin/tounge, flares, tie downs. If you plan to load it with wrenches, sockets, and other heavy tools I would go with a legit toolbox.
    For my use, I love the Swing Case.
    ladywolf[QUOTED] likes this.
  29. Jan 21, 2018 at 4:51 AM
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    Awesome. Thanks. Thats what I would be using it for as well, along with some dog stuff (bowl, extra collar/leash) and a few horse items (halter/lead), etc...)
    MotoTundra[QUOTED] likes this.
  30. Jan 21, 2018 at 5:31 AM
    MotoTundra
    MotoTundra The Ocho
    Don
