My experience with largest tires on stock trd pro setup
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by mallard75, Feb 19, 2017.
  1. Feb 19, 2017 at 4:02 PM
    mallard75
    mallard75 [OP] New Member
    darren
    2016 SR5 TRD 4x4
    A couple folks pm'd me after posting a photo of my 17 trd pro on 35's. here is my experience:
    My cement pro was ordered by someone else who bailed when it came in. Lucky for me I have a connection at the dealer and my phone rang first. It came from the dealer with bfg ko2 35x12.5s. Here is what it looked like:7e67a77359160ee97f1a9ac16b87c982_44681ca1fc4c0fd8b800296a9d57ac4093d47b73.jpg
    After driving for a week I couldn't take it. They look absolutely bad a$$ but the rub. Mainly in reverse. The mud flaps in front are gone but it rubs slightly on the bolt in the front of the fender liner:
    And the sway bar:
    Although I could not stick my pinky between the uca and the tire, it did not seem to run the uca.
    So I began to research....
    I can now confirm that the following is true:
    So I went with the 305/65/18 only because bfg ko2's don't come in that size. Ridge grapplers do but I was limited on the trade. Below is a series of pictures comparing. The last will be my truck on 305s. I love them. Drives better and looks more balanced imo.
  2. Feb 19, 2017 at 4:19 PM
    mallard75
    darren
    2016 SR5 TRD 4x4
  3. Feb 19, 2017 at 4:21 PM
    R-C
    R-C http://101financial.com
    Ryan
    Las Vega$
    2017 TRD Pro
    Good info.
  4. Feb 19, 2017 at 4:21 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Watching this
  5. Feb 19, 2017 at 4:24 PM
    ktharbour6
    ktharbour6 New Member
    2016 Toyota Tundra TRD Pro MGM
    Very good post and info. Only thing I question is that the ridge grapplers don't come in a 305.
    2016 Toyota Tundra TRD Pro CM MGM.
    zcarpenter92 likes this.
  6. Feb 19, 2017 at 4:24 PM
    R-C
    Ryan
    Las Vega$
    2017 TRD Pro
    Any issue with the 305 and the UCA?
  7. Feb 19, 2017 at 4:25 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    Different wheels and remove that front plastic and your good. I've ran 35's with less lift then the pro with no rubbing wheel offset is key 18x9 with a +20 to +25mm and your golden with 35x12.50's.
  8. Feb 19, 2017 at 7:13 PM
    mallard75
    darren
    2016 SR5 TRD 4x4
    None whatsoever. Took it off road this weekend and never once rubbed anything.
    R-C[QUOTED] likes this.
  9. Feb 19, 2017 at 7:17 PM
    mallard75
    darren
    2016 SR5 TRD 4x4
    I am not sure if the ridge grapplers come in 305 or not. I meant that the ko2's don't come in the 295 but I have seen others running nittos in that size. If I had the option to go with a nitto, I would have gone 295/70 or 75 because I personally like the narrower tire. But that said, I am happy with the ko2's for now. I could have kept the 35s and added spacers or shims and shackles but just didn't want to do that. I feel like the designers set it up this way for a reason. My opinion obviously.
  10. Feb 19, 2017 at 7:19 PM
    mallard75
    darren
    2016 SR5 TRD 4x4
    I hear ya... I was just trying to keep it stock for now. Obviously an aluminum wheel is not the best for serious off road. I found out after the fact that the pro actually has a wheel option for the trd off road wheel that is a 16 inch steel wheel. I forget what they are called. I like the looks of the stock 18 and it will suit my needs for now.
    Tibetan Nomad and Cisko213 like this.
  11. Feb 20, 2017 at 7:00 AM
    chphilo
    chphilo Tundra addict
    Western PA
    As far as I know, because of the large brake rotors, the smallest wheels we can use on Tundras is 17, (only a few in that size).
    Tibetan Nomad and zcarpenter92 like this.
  12. Feb 20, 2017 at 3:01 PM
    mallard75
    darren
    2016 SR5 TRD 4x4
    You are right they are 17's.
  13. Feb 20, 2017 at 3:23 PM
    ktharbour6
    I believe the other option is the forged wheels that came on the rock warrior tundras, which is a 17" wheel.
    mallard75[OP] likes this.
  14. Feb 22, 2017 at 5:41 AM
    Berettafan
    Berettafan New Member
    2017 CM
    Those look perfect! head on shots you could share? no spacers on wheels? did you air down to off road and if so still no rubbing?
    TundraMick and PermaFrostTRD like this.
  15. Jun 1, 2017 at 12:59 PM
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    So I'm thinking about running 35x12.5r18 on the stock trd pro wheel and stock suspension, Its 18x8 +60 if I ran a 1.25" spacer it'll push the offset to +28.25 and a 1.5" spacer will make it +21.9. I would like to be able to run the 1.25" but if the only way they'll fit is 1.5" I'll go that route. What size spacer do you think will make it fit?
  16. Jun 1, 2017 at 1:17 PM
    CPsTundra
    CPsTundra 915
    Super White CM TRD Pro
    Is that stock PRO suspension? Or did you do a small lift? Thanks
  17. Jun 1, 2017 at 2:09 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
  18. Jun 1, 2017 at 2:27 PM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    And I cracked a wheel on my Rock Warrior that wasn't any fun getting tig welded 250 miles from home.
  19. Jun 1, 2017 at 5:50 PM
    PermaFrostTRD
    Northern NY
    +1
  20. Jun 5, 2017 at 5:36 AM
    FUNTUN
    FUNTUN New Member
    2016 TRD Pro
    AFE intake, Hypertech tune kit, AMP power running boards, MT Bajas, XD rims, Linex bed liner w/TRD Pro logo, Revolver X2 bed cover, Swing Case undercover storage boxes, vent shades
    i'm on a 18x9 rim with a +18 offset. Running 305/60/18's. Will be changing soon. From what I read above, you guys think I can go to a 305/70/18 without additional cutting or rubbing. I have standard Pro set up.
    TundraMick likes this.
  21. Mar 10, 2018 at 12:43 PM
    trdpro144
    trdpro144 New Member
    David
    Berkeley/San Jose
    2015 Tundra TRD Pro Crewmax
    I plan on getting the 18x9 +18 methods on 35"s with Pro Suspension plus CB shackles and shims... Still need to chop am i right?
  22. Mar 10, 2018 at 4:29 PM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Maybe depending on the tire and alignment.
  23. Jul 19, 2019 at 8:27 PM
    ncomeau35
    ncomeau35 New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    nitto ridge grappler 285/75/18
  24. Jul 21, 2019 at 7:31 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    100% stock?
  25. Sep 22, 2019 at 10:26 AM
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    They do come in 305 in both 18" and 20"
  26. Oct 6, 2019 at 4:29 PM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    88Rotors does this set-up all day and daily to fit 35s. Shims up front and shackles in the rear to fit 35’s. Check em out on YouTube if you haven’t seen them yet. Clean work and great examples on how to fit 35s on Tundras.
  27. Oct 6, 2019 at 4:33 PM
    GarTX526
    GarTX526 New Member
    Many pending.....
    And yes, they do the Body Mount Chop to make it work.
  28. Apr 27, 2020 at 7:04 AM
    KenJen
    KenJen New Member
    To make the 305s work, do you HAVE to take off front mudflaps? Or can you leave them on?
  29. Apr 29, 2020 at 8:15 AM
    Tibetan Nomad
    Tibetan Nomad New Member
    BLQPNTHR and Offaxis2015 like this.
  30. Apr 29, 2020 at 8:37 AM
    degs
    degs New Member
    2020 MGM Crewmax
    Looks rad!
