My Drivers Side Window Wouldn't Go Back Up
Discussion in '2.5 Gen Tundras (2014-2021)' started by TaquitoBandito, Aug 24, 2018.
  1. Aug 24, 2018 at 5:16 PM
    TaquitoBandito
    TaquitoBandito [OP] SSEM #91, KitKat Aficionado, A Dancer for Money Exotic Dancer
    Joel (AKA Bif)
    Hopefully I'm putting this in the right spot. I brought the truck into the dealership for it's tire rotation and oil change. All went well. They had it waiting for me with the window rolled down when it was ready to go. It rolled up without a problem.
    About an hour later, I was visiting my special needs brother-in-law and, as I was leaving, he came outside to ask me a question. I rolled the window down. Talked to him for a minute and then it wouldn't roll back up. No noise, nothing. It's only about 800 degrees here in Texas right now.
    Because I'm a mechanical genius, I immediately assumed the little leprechaun living in the drivers side door that pushes/pulls the window up and down on command had died. As I was driving back home, I kept hitting the switch, and the window would come up a little and then stop. I'd push the switch down and it would go back down. I kept doing it back and forth and the window finally shut.
    So, again, being a mechanical genius, I pushed down on the switch and it went down. Then I had to fiddle with it back and forth until I could finally get it to shut again.
    Bad switch? Weird fuse? Angry leprechaun? Any ideas?Leprechaun_Tapped_Out.png
    Marty McFly and boostedtrdpro like this.
  2. Aug 24, 2018 at 5:25 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Are you opposed to pulling the door panel? Might be bound up or something in the window track. Getting that panel off would allow a lot more troubleshooting.
  3. Aug 24, 2018 at 5:26 PM
    Maybe the glue that holds bottom of window to the 2 U channel brackets came undone??? I had this issue, turned out the glue came undone, had to go to a auto glass distributor shop buy glue and primer the (good stuff you can't find at auto store) no issues anymore
    TaquitoBandito[OP] likes this.
  4. Aug 24, 2018 at 5:42 PM
    Outbound
    Aaron
    Northern Alberta
    Definitely an angry leprechaun.
  5. Aug 24, 2018 at 5:46 PM
    TaquitoBandito
    Joel (AKA Bif)
    Thanks - I normally would dive right in and take the panel off but it's so damn hot and I have no garage. At first I was hoping it was a fuse but when it started coming back up, I knew that wasn't it.
    I had an Xterra (don't judge me!!) before I could afford a Toyota and the belt or whatever made the window go up and down would bust and the window would just fall. I could literally just pull it up. The Tundra window was solid. There was no wiggle.
    I'll probably just drive back to the dealership on Monday.
    One of the mechanics yelled "Have a good day, sir!" as I was leaving. That never happens and he looked kinda squirrelly. Maybe I got set up. :)
    boostedtrdpro likes this.
  6. Aug 24, 2018 at 5:55 PM
    Wvmoonshiner
    Wvmoonshiner 2020 T4R Venture SE
    Chuck
    West Virginia
    2020 T4R Venture Midnight black
    With auto up windows if something is in the track it will stop from going up. Down not an issue
  7. Aug 24, 2018 at 5:56 PM
    TaquitoBandito
    Joel (AKA Bif)
    Thanks - I'll take a look tomorrow and see if I can see anything.
  8. Aug 24, 2018 at 7:03 PM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Maybe try some silicone lubricant and it’ll clean out the channel
  9. Aug 24, 2018 at 7:11 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    How many miles do you have on it, and any factory warranty left?
  10. Aug 24, 2018 at 7:16 PM
    Ericsopa
    Ericsopa Old man and the sea
    Or a very lazy one. A millennial Leprechaun, perhaps?
  11. Aug 24, 2018 at 7:33 PM
    Twinky
    07 double cab work horse
    Have you tried using the window controls on the passenger door also?
    And isnt "leprechaun" not politically correct anymore? I think we are supposed to call them "little drunks" these days.
  12. Aug 24, 2018 at 8:00 PM
    Jay661
    Jay661 New Member
    Bakersfield,CA
    2014 Toyota tundra
    I had the same problem with my driver side window it's the weather strip on the bottom it was cover under warranty
  13. Aug 24, 2018 at 8:01 PM
    TaquitoBandito
    Joel (AKA Bif)
    That's a great suggestion - I think I may have some around here somewhere - thank you.
    Around 22k and I have the Platinum warranty so it should be covered. I just hate having them open anything up if it's something I can do, you know?
    A millennial Leprechaun would be living in their parents basement. It's a least a Gen X Leprechaun.
    Ahem, I believe "little" is derogatory these days.
  14. Aug 24, 2018 at 11:29 PM
    Twinky
    So we are still good to call people drunks, right?
  15. Aug 25, 2018 at 5:04 AM
    Adam New Member
    Drunk? Hate monger. ;)I prefer to be called "So lit you could read by him"
  16. Aug 25, 2018 at 5:27 AM
    Outbound
    Aaron
    Northern Alberta
    Nope. Definitely an angry one. The OP made him mad.
    Source: Am an angry leprechaun.
  17. Aug 25, 2018 at 5:38 AM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Well... we need to know what color tundra first.
    TaquitoBandito[OP] and T-Rex266 like this.
  18. Aug 25, 2018 at 9:05 PM
    Tundra101
    Tundra101 New Member
    ODee
    Upstate NY
    2017 Quicksand Tundra SR5 4X4
    Pro Comp 6” Lift
  19. Aug 25, 2018 at 9:17 PM
    Cement
