My custom taillight project
Discussion in '2nd Gen Tundras (2007-2013)' started by Jwood562, Dec 30, 2020.
  1. Dec 30, 2020 at 9:15 PM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    So my plans are to get a new rear bumper with some flush baja designs reverse lights. I also run a vled reverse led plate frame.
    So my idea was to take factory tundra lights and customize them a little.
    I made the entire light assembly red, smoked them lightly and clear coat them. I then will modify the light harness to either run the factory reverse light as a parking light or eliminate it all together. I will see how I like it as a Parking/running light.
    Started with some factory fresh lights from local offer up. Took me a while to get a smoking deal. But time was on my side. Ended up landing a mint 10-13 set for $50
    First a cleaning, just wipe down with a cleaner of your choice. Just to remove dust and grime that might leave scratches as you sand.
    Soak a piece of 1000 grit paper in clean water. If your lenses are in good shape with minimal scratches you can use the 1000 grit. If you have defects to remove, start lower and work up. I was just looking to scuff and clean.
    One sanded the shine should be all gone and they should look dull. Wipe down with wax and grease remover and let sit in the sun to dry and warm. It was about 75 degrees when I did this.
    I also let my vht red night shades sit in the sun to warm the can. Warm cans spray better.
    Now since I am only really concentrating on the clear portion most people would want to tape off the existing red. I respectfully disagree as I do not want a hard paint/tape line to deal with. I prefer to gently blend the paints with no tape. It’s much cleaner in the final product.
    I will spray multiple light coats of red over the clear portion until the desired red is near, 2 coats then I give the entire light another 2 coats of red so they all match and have the same tint of red.
    Let dry completely. I will leave them out all day in the sun.
    Strat again with the original step of west sanding with 1000grit
    To knock the shine and the dust off or whatever. And leave the black nightshades out in the sun.
    I did light coats of niteshades and was happy after 3 light coats. I like a lightly tinted look. I also run very nice and bright LED bulbs so output it still better than original.
    Let dry another day and now is time for clear. I am a huge fan of 2k clear in a can. Basically professional automotive clear in a spray can. Runs about $25 a can but worth it. I would have liked it warmer today but it was still about 65 and low humidity. After 5 coats I was happy.
    Now they need to cure.
    I’m going to modify the wire harness next. Pretty easy to identify the reverse light positive wire here. I’m going to cut it to tap into the parking light wife of the top brake bulb. But also remember to leave the factory reverse wire in case you run a back up camera or aux reverse lights like I do. I ran yellow wire to make it easily identifiable for me.
  2. Dec 30, 2020 at 9:15 PM
    Jwood562
    2013 Tundra 4x4
    Place holder for install and testing soon
    I am also going to run a 194 red led bulb in the reverse light socket. I know they normally run t15/921 bulbs but that would be too much heat and maybe too much light for a parking light.
    Tundra2 likes this.
  3. Dec 30, 2020 at 9:25 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Cool project!
    Tundra2 likes this.
  4. Dec 30, 2020 at 9:30 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Very cool, looking great!
    Tundra2 likes this.
  5. Dec 31, 2020 at 1:29 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    You could use the empty reverse light socket to double up your turn signal bulbs. Looks great so far.
  6. Dec 31, 2020 at 1:31 AM
    Jwood562
    2013 Tundra 4x4
    You’re right. Another easy option to explore
    I can easily make a small video of all my options and leave it up to the forum on what looks best
    Tundra2 likes this.
  7. Dec 31, 2020 at 1:42 AM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Looks great so far :thumbsup:
  8. Dec 31, 2020 at 2:47 AM
    Looking good so far.
  9. Jan 10, 2021 at 7:46 PM
    Jwood562
    2013 Tundra 4x4
    I got everything finished up and couldn’t be happier.
    the all red tail lights give a subtle yet custom appearance and the Baja designs s2 flush mounts look awesome and perform better!
  10. Jan 10, 2021 at 8:17 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Well done!!
  11. Jan 10, 2021 at 8:26 PM
    Jwood562
    2013 Tundra 4x4
    Thank you.
    I need to get some good pics to do these justice. They look good
  12. Jan 10, 2021 at 9:05 PM
    MTRock
    MTRock 1889
    Montana
    Yes they do! I tried and messed mine up!
  13. Jan 11, 2021 at 4:34 PM
    Jwood562
    2013 Tundra 4x4
  14. Jan 11, 2021 at 7:20 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Looks great
  15. Jan 11, 2021 at 7:33 PM
    LunaC_TRD
    LunaC_TRD New Member
    Gene
    Houston, Tx
    2021 TRD Pro Lunar Rock
    Retrax Pro MX, ceramic tint, LineX spray in bedliner, NFab Nerf bars
    You did a great job with those tail lights!
  16. Jan 11, 2021 at 7:41 PM
    I'm amazed at how the red matched up! :thumbsup:
    Mountun Goat likes this.
  17. Jan 11, 2021 at 7:51 PM
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
    Killer diy for sure. Nice work, nice write up.
  18. Jan 11, 2021 at 7:51 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    How about I send you my taillights, I'm serious how much?
    MTRock likes this.
  19. Jan 13, 2021 at 8:26 AM
    Jwood562
    2013 Tundra 4x4
    let me find an extra set. I would rather work with a core set and do exchanges. For a couple reasons.
  20. Jan 13, 2021 at 3:47 PM
    Red Freighter
    Oregon City
    This might be a start to something big.
    Jwood562[OP] likes this.
  21. Jan 13, 2021 at 6:04 PM
    babydaddy
    babydaddy New Member
    Craig
    2000 Tundra LTD
    Is that reverse positive wire red/blue??? I'm basically color blind......
  22. Jan 13, 2021 at 6:05 PM
    babydaddy
    Craig
    2000 Tundra LTD
    Those taillights look great, by the way..
  23. Jan 13, 2021 at 6:13 PM
    dMO
    dMO New Member
    David
    2010 Black Tundra
    Toytec 3/1 leveling kit 18x9 VE37 35x12.50 Toyo RT
    that looks good! Killer tail lights!
  24. Jan 13, 2021 at 6:28 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I love this. Nice work.
    MTRock likes this.
  25. Jan 13, 2021 at 6:35 PM
    MTRock
    MTRock 1889
    Montana
    I have a set... a Failed attempt to tint! But I’m afraid after your done with them the rest of my pickup would look shit!
  26. Jan 13, 2021 at 6:56 PM
    Jwood562
    2013 Tundra 4x4
    Yes, but these were an aftermarket harness that came with some aftermarket eBay lights. The ones on the factory harness was a different color bits it’s easy to spot. The ground is black and runs to all three plugs.
    So the positive sides on the sockets are easy to identify. The only time I needed to test a wire was the parking light vs. the brake light.
    Easy enough though, using a test light turn on the parking lights and probe the two wires in the brake light socket and tap that one for the parking light.
  27. Dec 12, 2023 at 11:54 PM
    IIonPilgrimg
    IIonPilgrimg New Member
    2008 Tundra Limited Double Cab 4x4 5.7 6-speed Red Rock
    TTT... Two year old thread. These would look great on my black Tundra. Dope!
    4x4WarriorOfRocks likes this.
  28. Dec 18, 2023 at 11:04 PM
    Jwood562
    2013 Tundra 4x4
    thanks, I still look at them everyday and love them.
    I have since upgraded to VLED reds for my brake lights and they are almost too bright for brake lights!
    I have also done an all red set with no tint and they look great
  29. Dec 19, 2023 at 7:10 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    ...but how are we to pass judgment without photographic evidence??
