My AC smells.
Discussion in 'General Tundra Discussion' started by Achuop, Jun 4, 2017.
  1. Jun 4, 2017 at 9:09 PM
    Achuop
    Achuop [OP] Stormtrooper 5.7
    Anthony
    Orange County, CA
    2015 Tundra Crew Max TRD 4x4
    TRD Pro grill, Magna Flow Exhaust, 3/2 leveling kit, TRD sway bar, black out emblems, Bakflip G2 cover, 20” ProComp wheels and Tires and lots of love and affection.
    So my AC smells like stinky socks.
    First it was my 4runner that smelt like stinky socks. A couple weeks later, my tundra smelt like stinky socks also. What's going on? Both vehicles are 2015. We moved from Orange County to Vegas and I think it has something to do with the heat. Sometimes it smells sometimes it doesn't. But most of the time it does.
    Has anyone dealt with this?
    Jsena likes this.
  2. Jun 4, 2017 at 9:10 PM
    ride2wheels
    ride2wheels New Member
    Nathan
    2016 Tundra SR5 4x4
    Weathertech mats , S&B intake, soon Tacotunes SQ1
    I have the same issue in AS. What do we do?
    Achuop[QUOTED][OP] likes this.
  3. Jun 4, 2017 at 9:11 PM
    Turn off the circulator a few miles before you get to your destination. CAF prob needs to dry out
  4. Jun 4, 2017 at 9:11 PM
    ride2wheels
    Nathan
    2016 Tundra SR5 4x4
    AZ stupid auto correct.
    Jsena likes this.
  5. Jun 4, 2017 at 9:19 PM
    Achuop
    Anthony
    Orange County, CA
    I have tried this several times and the smell is still there.:(
    Jsena likes this.
  6. Jun 4, 2017 at 9:21 PM
    Achuop
    Anthony
    Orange County, CA
    Also checked cabin filter in both vehicles and it was pretty clean.
    Jsena likes this.
  7. Jun 4, 2017 at 9:25 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Been here my whole life.. never heard of this :goingcrazy:
  8. Jun 4, 2017 at 9:34 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Hmmm....stinky socks in with the CAF...I know what I'm doing to a few coworkers trucks tomorrow :)
  9. Jun 4, 2017 at 9:43 PM
    ToyotaDreaming
    ToyotaDreaming New Member
    ted
    Fayetteville, Ar.
    2015 Tundra 1794
    Bakflip HD
    I seen some stuff in auto car section of Walmart for this, is some sort of air-sol product that you place near a/c intake and you set off like a bug bomb with a/c on, doors shut and you out of car. It kills bacteria. Sorry I don't remember name or have picture.
    kenomouth64 and Achuop[OP] like this.
  10. Jun 4, 2017 at 9:59 PM
    Achuop
    Anthony
    Orange County, CA
    Just google some stuff. Will give it a try. Mold and bacteria is the cause.
  11. Jun 4, 2017 at 10:09 PM
    Achuop
    Anthony
    Orange County, CA
  12. Jun 4, 2017 at 10:41 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I had this problem last summer and No matter how long I ran it on fresh air it still stank. .. now this summer there is no smell....yet.
  13. Jun 4, 2017 at 10:43 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    I've noticed a wet towel smell if the AC is on, the outside humidity is fairly high and the system is in recirculation. It's happened a couple times with the Tundra and my previous car which was an 05 Acura RL. After a day or two the offending smell goes away.
  14. Jun 5, 2017 at 2:43 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    My uncle had a dead mouse in vents of his Trooper once.
    They had to take the system apart to clear it.
    Black Wolf and SouthBoundSteve like this.
  15. Jun 5, 2017 at 3:11 AM
    PermaFrostTRD
    Northern NY
    OP is your truck garage kept? If so I'd check for critters, run the AC w/ the recirculating off for a couple days, leave it outside.
    Hopefully one or all of these things help
  16. Jun 5, 2017 at 4:04 AM
    MrWrench
    MrWrench New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    What I do is shut my a/c off a few minutes before I get to where I am going. This way the evaportor has time to dry. Its moisture in plenum from the a/c system. They make sprays to help with the smell but I believe the correct way is to clean the evaporator with vinegar and if that doesn't correct the smell to replace the evaporator. Also make sure your drain isn't blocked, blocked drains won't allow water to escape the ac housing.
    rickc5, ToyotaDreaming and Wynnded like this.
  17. Jun 5, 2017 at 9:32 AM
    Achuop
    Anthony
    Orange County, CA
    Thanks fellas! I will give everything a shot. I'll keep you inform of the outcome.
    Where is the evap located?
  18. Jun 5, 2017 at 9:50 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Better than any commercial product AND cheaper, is to fill a spray bottle with a bleach solution and with the air flow on recirc, spray the solution into the intake down under the glove box until the duct tubing is lightly coated. This kills mold and fungus effectively.
    We've had mice and rats nesting before and they leave a real stench, a bit worse than dirty socks, lol
  19. Jun 6, 2017 at 6:14 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Achuop[OP] likes this.
  20. Jun 6, 2017 at 6:53 AM
    DVYota
    DVYota Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    I have this problem in all my Vehicles if I shut them off when I've been blasting the AC... now I turn the temp up a minute before I shut off the truck to keep from getting condensation in my vents and don't have the problem.
  21. Jun 6, 2017 at 8:07 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    This is what I used on my old 4runner when I had this problem. It is likely due to bacteria/mold build up in the evaporator. It is best practice to turn off the air re-circulator a few miles before turning the truck off, so that it dries it out. The drain hose can also be clogged, doubt that would happen on both vehicles but it is possible. You can just put a screwdriver down the drain hose to clear the mold out of the hose. Toyota has a service for this issue, they are charging like 120$ for it.
    https://www.grainger.com/product/4L...7877!&ef_id=WO_FXQAAASm9eAeX:20170606150437:s
  22. Jun 8, 2017 at 9:39 PM
    Achuop
    Anthony
    Orange County, CA
    My first step by turning the AC off a couple miles before my destination has helped a lot. There is still a little bit of smell but it's barely there. My next step will be the Lysol/bleach trick.
    NewImprovedRon and kenomouth64 like this.
  23. Dec 27, 2019 at 6:11 PM
    Thumper426
    Thumper426 New Member
    my 17 smells like stinky socks. i thought it was mice, but have had no signs of mice for 8 monthes. i park it in an overhang daily. I can't figure it out. 21k on her. Pisses me off, but like Pa says, better to be pissed off then pissed on. I changed out the Cabin air F, no difference. i spray lysol in the intake fresh linen ( nice smell, i prefer my f-ing new car scent), (sometimes with C Filter removed, sometimes with) and it still stinks. I can see water dripping from above the tranny when ac on, so its not clogged. Seems like a poor design. Im considering a condensor clean on the system. i still have to figure out how that works if i do it myself. Do a favor and write to the NHTSB on how it smells like shit and maybe enough people can get a recall on all the vehicles. 54k for a vehicle and 21k it smells like crusty a hole. let me know if you figured this out, i would love to know and apply your knowledge to fixing my vehicle.
  24. Dec 27, 2019 at 8:43 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    I used to do A/C work in dealerships and a fleet shop. When you start getting to musty odor like this change the cabin filter. But when you do, spray some Lysol into the case toward the evaporator. Mold builds up on the evaporator face from the constant sweating and catching dirt that goes past the cabin filter. This should clear up the odor.
    NewImprovedRon likes this.
  25. Dec 27, 2019 at 9:54 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Tag this thread, my wife’s car was getting this funky smell in the summer. We haven’t used the AC since it’s freaking cold right now. Im gonna do some of the advise here, when its start smelling or when it does in the summer. Thanks fellows.
  26. Dec 29, 2019 at 6:08 PM
    SuperWhite20
    Robert
    Georgetown TX
    The way I find it easiest to do is remove the cabin filter. Put the cover back on. Turn blower on High, not on recirculate. Spray Lysol into the vent on the right side of the cowl outside by the wiper. Be sure the doors or windows are open. This generally knocks it out.
    Ajkkane and Ely010606 like this.
  27. Dec 30, 2019 at 3:01 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    1. If your truck has a cabin filter remove it. 2. Get Lysol and spray it into the filter housing. 3. Spray Lysol into all air vents. 4. Make sure the condensate drain-line is clear. 5. After letting the Lysol sit for a few minutes turn the ac on high and spray into the return vent under the dash for about ten seconds then install a new filter. If you can’t find the return, open for fresh air recirculate (button) and spray into the cowl outside were the wiper blades are. Lysol kills bacteria and mold. You may have to repeat the Lysol.
  28. Dec 30, 2019 at 11:46 PM
    Achuop
    Anthony
    Orange County, CA
    Moved back to California and never had that issue again. LOL
  29. Dec 31, 2019 at 1:09 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    On my 2001 some years ago, I pulled my blower fan to fix a squeaking fan motor. I was surprised at how grungy the blower fan was. I cleaned the fan and sprayed it with Lysol. I also sprayed Lysol directly into the evaporator. No more stinky smell after that.
    SuperWhite20 likes this.
