My 4wd is not engaging and ducks come in season soon.
Discussion in 'New Member Introductions' started by jhopkins, Sep 18, 2018.
  1. Sep 18, 2018 at 9:53 AM
    jhopkins
    jhopkins [OP] New Member
    Joe
    08 Sequoia
    I'm feeling completely retarded with this. I've got no codes in the computer with my issue. I think I'm googling this wrong because I can find anyone with the same issue, but....
    When I switch to 4wd hi or lo I get a red flashing on the dash of my 4wd system with an "X" on it Then 4wd Hi starts flashing. If I keep switching the switch in the dash it will stay on until I turn the truck off and back on. Anyone got any clues???? It's a 2008 Tundra with about 210k on it.
    I appreciate the help. Just trying to avoid going to the dealer and not replacing every part until I've rebuilt the whole system if I can.
    Prostar 190 and T-Rex266 like this.
  2. Sep 18, 2018 at 10:37 AM
    Welcome. Agreed on actuator.
  3. Sep 18, 2018 at 11:22 AM
    jhopkins
    Joe
    08 Sequoia
    I tried the driving up to 10-15 and no luck..... I also did it reverse and not luck. So you guys think I should change the actuator?
  4. Sep 18, 2018 at 12:30 PM
    Welcome from Ohio!
  5. Sep 18, 2018 at 1:17 PM
    jordanpop1
    jordanpop1 New Member
    Buy a boat. More ducks that way. Problem solved. :spending:
    TXMiamiFan and jhopkins[OP] like this.
  6. Sep 19, 2018 at 7:40 AM
    jhopkins
    Joe
    08 Sequoia
    Oh I got the boat.
    TXMiamiFan likes this.
  7. Sep 19, 2018 at 7:45 AM
    jhopkins
    Joe
    08 Sequoia
    I bought an actuator and I'm hoping that's it. It just where I'm going to start for now because it ran me about $125 and if I can get lucky at that price I'll feel really good about myself.
  8. Sep 19, 2018 at 7:47 AM
    jhopkins
    Joe
    08 Sequoia
    I ran home and ran my wife's 4runner around in 4x4 for a while from this post. I appreciate the tip. I don't need to replace to of them.
    Watt maker likes this.
  9. Sep 19, 2018 at 7:53 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  10. Oct 22, 2018 at 7:18 AM
    jhopkins
    Joe
    08 Sequoia
    I replaced the front axle actuator and I'm still not having any luck. That one was the cheaper of the two. Now I'm sitting here debating on blowing close to a G for part number 3641034041 which I think is called the shift actuator. Any of you guys have any experience with this? Basically my transfer case isn't engaging and I can't lock my rear end either.
