My 21’ almost left me stranded yesterday - questions!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cl8NL, Nov 4, 2021.
  1. Nov 4, 2021 at 9:34 AM
    Cl8NL
    Cl8NL [OP] Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    2021 limited, TRD off road with push button. 11k miles.
    I used the remote start function, but when I got in the truck it didn’t shut off immediately like usual. It was still running for about 3-4 seconds after I sat in the drivers seat so I shifted into drive. It then shut off like I expected but I couldn’t start it again.
    it did detect the key, a button press would take it into accessory mode, but then with my foot on the break pressing the button did nothing to turn the truck over. It didn’t even shut off accessory mode. The only thing that would shut off accessory mode was hitting the lock button inside or on the remote. I tried for 5 mins straight. I even walked away/back with the key to try and “reset” and nothing. I should also add, the brake pedal felt very stiff this entire time. I could only press it down an additional half inch or so.
    After about 5mins of trying, it miraculously started and has been starting fine since. Was I just doing something wrong? It’s my first keyless rig
  2. Nov 4, 2021 at 9:35 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Bad battery?
  3. Nov 4, 2021 at 9:39 AM
    Cl8NL
    MKE WI
    Do you think that’s
    a)possible with a 4mo old truck
    b) it would still start remotely and then power everything else still while trying?
    genuinely wondering, thanks for responding!
  4. Nov 4, 2021 at 9:53 AM
    Taco-Spike
    Two Trucks
    Sounds like a glitch in the Matrix
  5. Nov 4, 2021 at 10:01 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm no expert but these Tundras do seem to have weak batteries and do very weird things as they get low on charge. Can't hurt to have an auto shop load test it
    Have you added anything to the truck? I assume the remote start is from the factory? Added an OBD2 monitor or anything like that? Nothing plugged into USB ports?
  6. Nov 4, 2021 at 10:11 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I know its Toyota but this is why i wanted an SR5 with an actual key. I just dont trust these pushbutton starters. My dad had a Kia with a pushbutton and every so often, it just wouldnt work and he had to sit around the parking lot for 15-20 minutes until it decided to work.
    Chip_Tundra and Cl8NL[OP] like this.
  7. Nov 4, 2021 at 10:12 AM
    Cl8NL
    MKE WI
    To be completely honest, it had a breathalyzer wired in for the first two months of its life…. Maybe the installers didn’t wire the ignition back in properly and it’s shorting?
  8. Nov 4, 2021 at 10:13 AM
    2mchfun
    The thing with radio frequencies is interference. You may not ever have any, you may encounter everyday.
  9. Nov 4, 2021 at 10:14 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, could be. Or they could have left something behind that's drawing power. I'd pop the hood/get under the dash and see if there are any rogue wires around.
    TheBeast and Cl8NL[QUOTED][OP] like this.
  10. Nov 4, 2021 at 10:58 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I'd check the key fob battery, contacts and buttons for clean and smooth action too.
    Also FWIW, if I inadvertently triggered the safety shutoff on my prior vehicle's alarm system, the restart was usually delayed or rough.
    Cl8NL[OP] likes this.
  11. Nov 4, 2021 at 11:01 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    ^^ This
  12. Nov 4, 2021 at 11:48 AM
    Cl8NL
    MKE WI
    Got it, this could definitely be it too as I matched my key fob cavalry blue ;) so I’ve been inside there and probably have bad contact etc
  13. Nov 4, 2021 at 12:09 PM
    myGreenMachine
    myGreenMachine DeChromed
    scott
    Bend, Oregon
    2021 Tundra Limited
    looking here for ideas and instruction...
    Thought I read somewhere... if you are having problems with the smart key you need to hold the key fob next to the stop/start button and try it again or hold it there 5 seconds... I'll try to find it and post it..
    Black Wolf likes this.
  14. Nov 4, 2021 at 12:18 PM
    Cl8NL
    MKE WI
    yep, I have a placard in my glovebox that said that and I tried to no avail….
  15. Nov 4, 2021 at 12:50 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Did you forget to put into park after it shut off?
    TheBeast likes this.
  16. Nov 4, 2021 at 1:43 PM
    myGreenMachine
    scott
    Bend, Oregon
    2021 Tundra Limited
    if all else fails... disconnect the Neg side of the battery and wait a few min... reconnect and see if that resets.. Ctrl-Alt-Del
  17. Nov 4, 2021 at 2:18 PM
    Cl8NL
    MKE WI
    It shut off while in drive, but I put it in park (confirmed by my DIC) and it still didn’t matter
  18. Nov 4, 2021 at 2:22 PM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Check battery terminals for tight connections. Have heard of bad batteries coming out of the factory.
  19. Nov 4, 2021 at 2:40 PM
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    2020 Platinum - Super White
    Elka DSC Suspension, Ray-10s, MaxTrax, Dirt King UCA, 295/70/18 Toyo AT3, TRD Skid + Intake, .25 Bumper Shim, UnderCover UltraFlex Tonneau, RoadActive Suspension, Tuffskinz, etc.
    If the brake pedal was a bit stiff, and it was going into accessory mode when you hit the button, it was probably just the stiff brake pedal not being depressed enough to kick it into start mode. I've had a few Toyota smart key vehicles and have had that happen, just a firmer push on the brake pedal and no issues. Not sure on the remote start extended running, my understanding of the factory remote start with smart key is it will die when the door is opened.
    Cl8NL[QUOTED][OP] likes this.
  20. Nov 4, 2021 at 5:08 PM
    Cl8NL
    MKE WI
    I was wondering if that was the case, thanks!
  21. Nov 4, 2021 at 5:42 PM
    BigT27
    BigT27 New Member
    LMAO maybe because that was Kia ‍♂️
  22. Nov 4, 2021 at 6:56 PM
    MadMaxCanon
    100% but apparently from this post gremlins live in Toyotas too, although a far smaller population.
  23. Nov 4, 2021 at 7:03 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Yes.
