Multiple misfires after rebuild ** FIXED **
Discussion in '1st Gen Tundras (2000-2006)' started by Brynden29, Jul 16, 2022.
  1. Aug 27, 2022 at 5:39 AM
    #511
    Brynden29
    Brynden29 [OP] Just a guy who works on cars
    Brynden
    Bellville, TX
    1999 Mustang GT
    At idle the LTFT were both at -4 or so. They didn’t move since it was just idling. I didn’t drive it after letting it idle. I will check it the next time I drive it.
    N84434 likes this.
  2. Aug 27, 2022 at 6:49 AM
    #512
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Hopefully this is it. If anything this has been a very good tutorial.
    dbittle likes this.
  3. Sep 1, 2022 at 6:13 AM
    #513
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I dropped it off Tuesday evening at a local shop. I haven’t heard anything from them yet. When I do, I will post here what their diagnosis is. It is still misfiring at idle just like before. So pulling the head and checking the valve lash apparently didn’t do anything but waste my time.
    w666 and chunk like this.
  4. Sep 1, 2022 at 7:10 AM
    #514
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Not so. If you did indeed inadvertently play mix-n-match with your shims during the rebuild then re- checking the lash potentially saved you from a burnt exhaust valve 10,000 miles from now.
  5. Sep 1, 2022 at 7:59 AM
    #515
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Well, that is one thing that I know is correct. I made sure the shims were correct for the head.
    N84434, dbittle and hagrid[QUOTED] like this.
  6. Sep 1, 2022 at 6:34 PM
    #516
    zgurrola21
    zgurrola21 New Member
    Zyan
    2001 Toyota Tundra SR5 TRD OFF-ROAD
    You either cut a wire up by accident or you have a vacuum leak, either the head gasket, the valve gasket or even the intake man did ok gasket. I have the same codes except for the Igniter and the issue was the intake manifold gasket was leaking
    Brynden29[OP] likes this.
  7. Sep 1, 2022 at 7:56 PM
    #517
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Did your truck only misfire at idle?
    I did replace the intake manifold gaskets with genuine Toyota brand gaskets.
  8. Sep 2, 2022 at 1:46 PM
    #518
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    So the repair shop has had the truck for 3 days. I just drove by and saw it parked on the street. I called them to check on it. They said it was going to take some time to figure it out. They think it is something mechanical. I wonder how long they are going to keep it before giving up.
  9. Sep 2, 2022 at 1:53 PM
    #519
    AZTundra
    Paul
    Phoenix, AZ
    Are they charging a flat diagnostic fee?
  10. Sep 2, 2022 at 1:54 PM
    #520
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Honestly, we didn’t even talk about what I will be paying them.
  11. Sep 2, 2022 at 3:30 PM
    #521
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Yikes, I think it would be a good idea to have that conversation with them, sooner than later. Good for them, and good for you.
  12. Sep 6, 2022 at 4:24 PM
    #522
    fighthedude
    fighthedude New Member
    Update?
  13. Sep 6, 2022 at 4:28 PM
    #523
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I didn’t get a chance to call. I will try tomorrow. I have not heard from the shop.
    fighthedude likes this.
  14. Sep 6, 2022 at 6:23 PM
    #524
    Aerindel
    Aerindel New Member
    Montana
    They have probably crawled into bed with a bottle of booze crying after trying to solve this one.
  15. Sep 7, 2022 at 5:39 AM
    #525
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I am half expecting a call from them telling me to come get it because they can’t fix it.
  16. Sep 8, 2022 at 9:40 AM
    #526
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I went to the shop to get my sunglasses out of my truck. I asked about the fee for diagnosis. The guy told me it is the shop rate of $95 an hour. And hopefully they can figure it out in that hour… which tells me that they haven’t even looked at my truck yet. It’s been a week.
  17. Sep 8, 2022 at 10:12 AM
    #527
    Lame!
    Tundra2 likes this.
  18. Sep 9, 2022 at 12:36 PM
    #528
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I talked to the shop and they looked at it today. Basically, they don’t know what is wrong. They want to pull the front cover to check the timing, which I know is correct, but they don’t have time right now. I am going to go get it and set up a time to take it back to them. They aren’t going to charge me anything until they figure out what is wrong, so that’s good. But I’m still not any closer to finding out what is wrong.
    AZTundra likes this.
  19. Sep 9, 2022 at 1:53 PM
    #529
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I saw a video online about a guy that has an issue where his camshaft gear rotated because he didn’t put the service bolt in before removing the camshaft. I did not use a service bolt and I removed the camshafts. Could the gear have rotated on me? Does that sound like a thing?
  20. Sep 9, 2022 at 3:01 PM
    #530
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Ignore the red, I stole this picture. The part in yellow. It appears that the gears can rotate.
  21. Sep 9, 2022 at 4:34 PM
    #531
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    What you see there is a split gear that's spring loaded. The spring acts upon the thinner section to suck up all the lash so you can't hear the drive and driven gear meshing.
    The ones I've dealt with don't have enough stroke to wind back an entire tooth. Besides, if you had a camshaft indexed incorrectly by one tooth would your engine run as well as it does now? I think it would be shaking around in the engine bay... provided it would idle at all.
    N84434 and FrenchToasty like this.
  22. Sep 9, 2022 at 6:17 PM
    #532
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    You have already checked about everything I would think to check. You might try going really old school and put a vacuum gauge on it and see what it shows at idle cold and hot.
    I would think it would give you a good indication if the valves are sticking, leaking, etc.
    You might be able to get one through the loan-a-tool program at the local auto parts store.
  23. Sep 12, 2022 at 4:39 PM
    #533
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I hooked my logger up today and did a few tests. With the car idling in park I get misfires. When I put it in drive, the rpm’s lower and the misfires stop. When under load it doesn’t misfire.
    I don’t have any idea why that would happen. I am going to do an exhaust back pressure test as well as a leak down test. I’ll report back my findings.
    dbittle and N84434 like this.
  24. Sep 13, 2022 at 12:03 PM
    #534
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Is it only cylinder #3 at this point and are the fuel trims still different between the two cylinder banks?
  25. Sep 13, 2022 at 12:17 PM
    #535
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    It’s all the cylinders. Here are some pics I took:
    55 mph:
    Stopped at light, in drive:
    in park:
  26. Sep 13, 2022 at 12:34 PM
    #536
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    You have a sensor/electrical issue.
    NOPE... I take that back. A vacuum leak can still be part of it. Brake booster possibly...
  27. Sep 13, 2022 at 5:51 PM
    #537
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    The shop was adamant that it was not electrical. They checked the wiring. They told me it was definitely mechanical.
  28. Sep 13, 2022 at 7:16 PM
    #538
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Seems pretty easy to test. Pull vacuum line off booster and cap off and see if problem remains.
  29. Sep 13, 2022 at 7:17 PM
    #539
    Not to be crass, but what do they know? They don't know what is wrong, how can they tell you what isn't? This has been an incredibly frustrating ride for you and I can't imagine. They couldn't possibly have checked the wiring to the degree that they could rule that out completely. Still in the discovery phase unfortunately. I am truly rooting for a solution here.
  30. Sep 13, 2022 at 7:25 PM
    #540
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I have a vacuum test gauge coming and I plan on testing it when it gets here.
    dbittle and NickB_01TRD like this.
