Multiple light on the dash!??
Discussion in '2nd Gen Tundras (2007-2013)' started by Drummondj, Dec 16, 2018.
  1. Dec 16, 2018 at 4:07 PM
    Drummondj
    Drummondj [OP] Tundrakid93
    James
    Vernon Ny
    2010 Toyota Tundra xsp
    MBRP exhaust
    Hey guy so im freaking out a bit lol I just started up my truck and I have multiple lights in the dash and the truck doesn’t want to shift right. The lights that are lit up are the traction control, check engine light and the for low light is flashing. Any ideas what’s going on??? I’m at work now so I can’t check anything but I didn’t disconnect the battery just for shit so we will see after work
  2. Dec 16, 2018 at 7:26 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    You have any mods ? Gonna have to get the ecu scanned and see what’s up
    When the check engine light is set off for whatever reason it turns the gauges into a Christmas tree. Looks worse then it prob. Is
  3. Dec 16, 2018 at 7:31 PM
    This summer I had check engine, ABS, 4hi and traction control going off and it was just a speed sensor. So hopefully yours will be an easy fix also.
  4. Dec 16, 2018 at 7:32 PM
    Sounds like a wheel speed sensor. Any recent work around there? You’re in NY- possible ice covering it?
  5. Dec 16, 2018 at 8:15 PM
    Drummondj
    James
    Vernon Ny
    MBRP exhaust
    I recent replaced the pad and rotors. I’m also hoping that maybe something got wet cuz I was driving it all morning then it sat for a few hours while it rained and started to get foggy outside. I’m just really hoping it’s not the Air injection pump. I unhooked the batterie and I’m gonna let it sit while I’m at work cuz it’s a 12 hours shift so I’m hoping it will clear up and stay that way. If not a I’ll get the codes looked at. I have my figures crossed that it’s just a sensor not the pump
  6. Dec 16, 2018 at 8:17 PM
    U performed work around the tire area. Bet it’s a speed sensor. If it needs replacing, it’s around $170 each or so
    Prostar 190 likes this.
  7. Dec 16, 2018 at 8:29 PM
    Drummondj
    James
    Vernon Ny
    MBRP exhaust
    Ok that’s would be awesome! I’ve spent a lot a cash for Christmas so I don’t need a big project now lol thanks guys I’ll keep you updated on what I find out after work!
  8. Dec 16, 2018 at 10:01 PM
    Drummondj
    James
    Vernon Ny
    MBRP exhaust
    Nope I don’t have anything done to the truck. The first few truck I had lift kits and all kinds of other stuff but after a while of having to replace brand new parts I stopped adding mods.
  9. Dec 17, 2018 at 1:13 PM
    Drummondj
    James
    Vernon Ny
    MBRP exhaust
    I hooked up my tundra and it did throw a p2442. I brought it the local dealer and it’s going to be covered!!
    T-Rex266 and NewImprovedRon like this.
