Muffler replacement
Discussion in 'Performance and Tuning' started by 14crewmax, Oct 28, 2020.
  1. Oct 28, 2020 at 6:56 PM
    14crewmax
    14crewmax [OP] New Member
    Oroville Ca
    2014 TRD off road crew max 4x4 silver sky metallic
    Stock
    I’ve read a lot of threads on here, but I want to know if anyone out there has changed just the muffler only and how does it sound, I know everyone is going to recommend the guy who makes the bolt on exhaust on here but I want to know if anyone has had success with just a muffler. I have a 14 tundra.
  2. Oct 28, 2020 at 7:01 PM
    I decided to keep the single exhaust setup this time around. Got a nice FlowMaster knock off for $26. Sounds great. Not annoying. No drone.
  3. Oct 28, 2020 at 7:09 PM
    Flowsound muffler: dual 2.25" inlets with single 3" outlet. Perfect. Popular with Jeepers. Found out about the Flowsound on a Jeep forum actually. Not a glass pack. A very great Flowmaster knock off, except Flowmaster doesn't make this size so actually not a knock off ;)
    BlackSheep and Rica25 like this.
  4. Oct 28, 2020 at 7:11 PM
    14crewmax
    Oroville Ca
    Stock
    I have read on here that you need 2.5 Inlets lol but if yours is 2.25 and it fits
    Rica25 and Black Wolf[QUOTED] like this.
  5. Oct 28, 2020 at 7:14 PM
    Fit perfect. Lined right up. Took less than 30 minutes to get it welded up! Only had to add a 2" extension. Quite pleased. No need to spend hundreds of dollars to keep your single exhaust setup that sounds great:thumbsup:
  6. Oct 28, 2020 at 7:16 PM
    biebs96
    PA
    Following
    Rica25 likes this.
  7. Oct 28, 2020 at 7:18 PM
    14crewmax
    Oroville Ca
    Stock
    How loud is it do you have a clip
  8. Oct 28, 2020 at 7:29 PM
    No clip. Phone clips never do justice anyways. Not too loud at all until you get on it. Sounds great at idle. Not overbearing. No low end torque loss either. Stock muffler simply doesn't cut it.
  9. Oct 28, 2020 at 7:42 PM
  10. Oct 29, 2020 at 4:51 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    You make a pretty convincing case, Matt. I think, with my newfound welding skills, I'm gonna have to give this a try. And for $28, this is one mod I don't even need to tell the wife about until she hears me pulling in the driveway :p
    Rica25 and Black Wolf like this.
  11. Oct 29, 2020 at 8:46 AM
    BlackSheep
    Scott
    Kansas City, MO
    Just measured my pipes. Sure enough, 2.25" inlets, 3" outlet that quickly reduces to 2.75". Has anyone else tried this muffler?
  12. Oct 29, 2020 at 9:02 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Changing just the muffler is good for changing sound, but replacing just the muffler will not increase power and it may actually decrease your engines performance.
    I researched this topic for about a year before I had Keith at @dirtydeeds fabricate a custom muffler system for my RCSB, the Y-pipe and using the correct diameter pipe along with the original tail pipe delivered to sound I wanted and the power gains I was looking for.
    GODZILLA, Rica25, Yoda1 and 3 others like this.
  13. Oct 29, 2020 at 9:29 AM
    Yep, a low cost setup. As you can see the Flowsound is not a glass pack. The cutout section shows the internals. It's not a straight thru design. I certainly have no loss of power, the opposite actually. Low end torque is quite fine. Sometimes less is more. Try it you will like it. If you don't....you only have $28 into it and elbow grease. :thumbsup:
    Rica25 and BlackSheep[QUOTED] like this.
  14. Oct 29, 2020 at 9:39 AM
    BlackSheep
    Scott
    Kansas City, MO
    What would be the effect of dumping the tail pipe just in front of where it turns up to go over the rear axle? Seems like it would be just as easy as welding in a short extension. Something like this...
    Rica25 likes this.
  15. Oct 29, 2020 at 11:09 AM
    14crewmax
    Oroville Ca
    Stock
    How do you know that do you have a dyno? And maybe some people like power in the high end rather then the low end. I’m not a engineer or expert but I build my own cars no matter what exhaust is on my tundra you are not going to see significant gains if your motor is stock and if you have a intake, your motor is still stock lol just looking to see what people have installed for a deeper tone, I might just experiment myself and try different ones since I can weld and cut and install myself
  16. Oct 29, 2020 at 12:07 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    We make just a muffler as well. Check out our site.
    Dirtydeedsindustries.com
    Rica25, Rex Kramer and BlackSheep like this.
  17. Oct 29, 2020 at 12:10 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    My truck came with some jank pile of shit that wasn't supported correctly, and eventually one of the outlets off the muffler fell off and essentially did what you have drawn. It made it way louder in the cab since the exhaust noise was kind of contained underneath the truck. Personally I wouldn't recommend it regardless if you like a loud truck, because it's really just louder for you and not anyone else.
    BlackSheep[QUOTED] likes this.
  18. Oct 29, 2020 at 1:03 PM
    drowhawk
    drowhawk New Member
    '19 Tundra SR5
    What if nobody in the general public cares/wants to hear your truck? This mod is perfect.
    Rica25 and BlackSheep like this.
  19. Oct 29, 2020 at 1:19 PM
    Rex Kramer
    Georgia
    Do you have a dyno... can I borrow it?
    It's common knowledge that these engines are good for an extra 3 to 10 peak hp with no loss in low end torque when you replace the restrictive factory muffler and continue using the stock tail pipe... you can extract a little more power if you also add a less restrictive filter element like the AFE drop in dry filter.
    Rica25 likes this.
  20. Oct 29, 2020 at 1:26 PM
    Rex Kramer
    Georgia
    I ran this configuration for almost a year, it was a little louder and produce a raspy sounds at high rpms. It also robbed me of some low end torque off the line power... the BAMuffler system I have now solved those problems and it sounds sweet.
    You can see the turn down ahead of the axle in this picture.
    Rica25 likes this.
  21. Oct 29, 2020 at 1:27 PM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    I did a magnaflow replacement muffler. Very quiet + drone. I now have a DD 6 and am very happy
    Rica25, biebs96 and Rex Kramer like this.
  22. Oct 30, 2020 at 5:53 PM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    I ordered DD system today after much research.
    Rica25 and Rex Kramer like this.
  23. Nov 5, 2020 at 6:14 AM
    BlackSheep
    Scott
    Kansas City, MO
    I got impatient and welded this up a couple days ago. Probably should have waited until i got the inlet pipes off the truck, because I'm going to have to take it all down and clean up the welds on the tops of the pipes on a table. But, it's functional. Sounds pretty good, I think. Definitely has an aggressive tone when I get on it but is pretty quiet otherwise. For $40 and a few hours of work, I'm pretty happy. Could never quite pull the trigger on a DD or TRD system, so much $$$
    Black Wolf and Rica25 like this.
  24. Nov 5, 2020 at 1:34 PM
    14crewmax
    Oroville Ca
    Stock
    Which muffler is that?
    Rica25 likes this.
  25. Nov 5, 2020 at 1:38 PM
    BlackSheep
    Scott
    Kansas City, MO
    It's the one Matt @Black Wolf linked in post #9 of this thread. I just painted it black with high heat grill paint lol cuz as he indicated, it's not stainless, and I don't want it to rust away anytime soon.
  26. Nov 5, 2020 at 3:05 PM
    Mine sounds pretty good at idle too. Not loud but a nice low rumble sound.
  27. Nov 5, 2020 at 3:21 PM
    BlackSheep
    Scott
    Kansas City, MO
    I tried recording a clip, but as you mentioned, they just don't give an accurate representation of the sound. I had my wife drive it last night when she took our son to football practice so I could hear it pull away. It is pretty much the exact sound I wanted. It's a low rumble at idle, but accelerating at 2,500-3k rpms it's perfect. Not obnoxious, but obviously louder than stock with a tone that's appropriate for a big truck.
  28. Nov 5, 2020 at 3:23 PM
    Yeah, I took a chance and ended up quite pleased. Exactly the sound I hoped it would be. Glad I stumbled across that forgotten Jeep forum that had a thread about these. I'll try to find it again. I might have bookmarked it.
  29. Nov 6, 2020 at 10:46 AM
    14crewmax
    Oroville Ca
    Stock
    I just got a flow master super 44 I’m going to have it welded in sometime next week I’m going to run 3 inch mandrel bent piping over the axle, I will keep you guys updated
    Meanjoe, BlackSheep and YardBird like this.
  30. Nov 10, 2020 at 7:06 AM
    14crewmax
    Oroville Ca
    Stock
    I got a Flowmaster super 44 installed with 3 inch mandrel bent pipe over the axle with a 4 inch tip and it sounds good to me I very happy with the sound. It’s deep and not excessively loud but you have definitely hear it especially when you get on it
    Meanjoe and BlackSheep like this.
