Mud Flap Question
Discussion in 'General Tundra Discussion' started by SCTundraOwner, Dec 25, 2020.
  1. Dec 25, 2020 at 8:37 AM
    SCTundraOwner
    SCTundraOwner [OP] New Member
    Ron
    2020 Tundra Limited CrewMax
    Hi all - I had my 2020 Limited lifted and am trying to figure out the best way to keep from having rubbing on my mud flaps. It has a 4" Rough Country lift with 20x9 +1 offset Fuel rims. Tires are 35x12.5-x20 All Terrains.
    I have cut a gap in both sides but the driver side is really the only one that rubbed. I'm not fond of how it looks with the window cut and have thought about replacing them and using a strong hold 3M adhesive to hold them back out of the way.
    Any thoughts are greatly appreciative!!
  2. Dec 25, 2020 at 9:54 AM
    Welcome from NY.
    Some people have used a heat gun and pushed it back.
    Any pictures?
  3. Dec 25, 2020 at 9:56 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Take 'em off...:thumbsup:
    Welcome to the forum..
  4. Dec 25, 2020 at 10:24 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada . What mudflats are on there now ?
  5. Dec 25, 2020 at 1:11 PM
    SCTundraOwner
    Ron
    The stock mud flaps are on there now, it went ahead and took them off but would definitely be welcome to any insight. I tried molding them with my heat gun yesterday but that didn't really work. I did cut a window in both of the front flaps but aren't overly happy with the way that looks.
  6. Dec 25, 2020 at 2:00 PM
    biebs96
    PA
    You could always trim them down for a sleeker factory look.
    I trimmed mine down..
  7. Dec 25, 2020 at 7:11 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have a set for sale, good condition if you want.
  8. Dec 28, 2020 at 9:04 PM
    DodgerBlues
    DodgerBlues New Member
    Ryan
    Parker, Colorado
    2018 Cement TRD Offroad Tundra CM
    de-badged, 6112/5160 Bilstein’s 295/70/r18 toyo r/t Kmc 544
    How do you like the rough country 4” lift? Looking at it for my truck.
  9. Dec 29, 2020 at 7:50 PM
    SCTundraOwner
    Ron
    I've been extremely pleased with it. My ride has not changed one bit from stock to the lift which was important for me since we tend to take my truck on road trips.
  10. Dec 29, 2020 at 8:03 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    if you are talking about the front tire / front... (attached to bumper) i believe i see the "window cut" you made, you may want to consider front bumper shims (or washers) to shift your front bumper forward 1/2".
    i have no idea based on offset and tire size if this will absolutely resolve any rubbing, but it will give you 1/2" additional clearance.
    i needed shims to keep from rubbing front tire / front. running a 3/1 readylift with 34's and 1.25 wheel spacers. instead of factory +60 offset, i am now closer to a +29 / +30 offset.
    i was not able to run the front tire / rear mud flaps though (ones attached near the body mount and where some perform the bmc) with out rub.
