MPG slowly dropping
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Toytun55, Feb 17, 2024.
  1. Feb 17, 2024 at 7:56 PM
    Toytun55
    Toytun55 [OP] New Member
    2016 Toyota Tundra Crewmax
    We bought truck last year with 21,000 miles on it. Now at 31,000. Issue is digital mpg showed 15.9 when we bought it. Now as of today digital mpg is 15.1. Slowly continuing to go down. Mostly drive in small town setting. No lead foot. What may be the cause?
  2. Feb 17, 2024 at 8:02 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Short trips kill mpgs... sad but true. In town I average about 14mpg with conservative and aggressive driving.
  3. Feb 17, 2024 at 8:04 PM
    white_pro21
    white_pro21 New Member
    2021 super white TRD PRO
    You won't get better mpg in winter. Also check your air filter.
    Toytun55[OP] likes this.
  4. Feb 17, 2024 at 8:04 PM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    I really wouldn’t worry about a variance or .8 mpg over the course of 10k miles. The digital read out isn’t the most accurate either. You could be logging more idle time, more around town, etc. Not to mention atmospheric changes, fuel grade, etc.
  5. Feb 17, 2024 at 8:05 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Change all diff and transfer case oil
  6. Feb 17, 2024 at 8:06 PM
    Toytun55
    It seems odd to just keep steadily dropping. The tire pressure light is on. Had Les Schwab put new tires on a few months ago.
  7. Feb 17, 2024 at 8:07 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Same size or 10 ply???
    Slag_Dynamics likes this.
  8. Feb 17, 2024 at 8:07 PM
    Slag_Dynamics
    Arizona
    Gone
    Same size tires as before?
  9. Feb 17, 2024 at 8:09 PM
    Toytun55
    No bigger.
  10. Feb 17, 2024 at 8:10 PM
    Slag_Dynamics
    Arizona
    Gone
    If they’re bigger, there is your MPG discrepancy.
  11. Feb 17, 2024 at 8:13 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    You need hand calc or some kinda recalibration to be accurate.
  12. Feb 17, 2024 at 8:49 PM
    Toytun55
    Thank you to all of you for quick responses and very helpful feedback!
