MPG between 285/70/18 and 295/70/18 about the same?
Discussion in 'Wheels & Tires' started by Tundra234, Jan 17, 2021.
  1. Jan 17, 2021 at 4:48 PM
    Tundra234 [OP] New Member
    Even though the 295 is 10 lbs heavier per tire, is the fuel mileage about the same between these 2 sizes? I know the sizes are barely different between the two....both Ridge Grapplers.
  2. Jan 17, 2021 at 5:52 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    I would guess you loose at least 1-2 mpg. I think they say every additional pound of weight is more like carrying an additional 7lb.in your vehicle so in this case it’s an extra 300 lbs. I’ve used this spreadsheet to compare different tire sizes and weights. While tire size impacts MPG, it almost all comes down to tire weight at the end of the day.
    http://the-welters.com/racing/rotational.xls
  3. Jan 17, 2021 at 5:59 PM
    TheBeast The Beach
    I'm at 13 mpg with 295....
  4. Jan 17, 2021 at 7:06 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    10lbs per tire alone won’t do that much, but the extra height is what you will feel.
  5. Jan 17, 2021 at 7:11 PM
    Its less than 1/2 inch between the two.
  6. Jan 17, 2021 at 7:55 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    13.6 w/ 295’s
  7. Jan 17, 2021 at 7:58 PM
    Damn. I might just cancel tomorrow's appointment and order 285's again.
  8. Jan 17, 2021 at 8:06 PM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    What’s your mpg w/ 285’s?
  9. Jan 17, 2021 at 8:31 PM
    I reset the average trip today and 13.6 miles at an average speed of 62 was 15.4 mpg. It was all drive time except for 3 stop signs in the first mile.
  10. Jan 17, 2021 at 8:34 PM
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Nothing but good stuff.
    Running 75-80 on the highway around 14.5-15
  11. Jan 17, 2021 at 9:04 PM
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
    No matter what anyone says, 10 lbs per tire is a lot. Physics will always win. I wouldn’t put too much stock in mpg numbers, as these vary wildly depending driving style, altitude, payload, etc..
    dpast88 and Hbjeff like this.
  12. Jan 18, 2021 at 3:37 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Are you set on the RGs? You could get the Cooper AT3 XLTs or Toyo AT3s in the 295/70r18 and your mpgs would be about the same. Weights are the same as your 285/70r18 RGs.
  13. Jan 18, 2021 at 4:03 AM
    Did you recalibrate your speedometer for the bigger tires you are running? If not, then you are actually travelling further than the computer thinks, and actually getting slightly better fuel economy than it reports to you.
    Elduder likes this.
  14. Jan 18, 2021 at 5:09 AM
    The RG's are the only thing available in the area. Everything else would have to be ordered. Yesh I saw the Toyos are about 4 lbs heavier than the 285's.
  15. Jan 18, 2021 at 8:23 AM
    FXFormat
    FXFormat New Member
    I'm about to get new tires, will run 285/75/18 (35" tire). Good year duratracs put in the weight at 60lbs, i can live with that, duratracs are good tires.
    I'm currently running 305/65/18 KO2s and they are beginning to look small, and they weigh 63lbs as well.
