MPG - 13.5????
Discussion in '3rd Gen Tundras (2022+)' started by HulkHog, Jul 8, 2024.
  1. Jul 8, 2024 at 11:39 AM
    HulkHog
    HulkHog [OP] New Member
    2024 Limited Nightshade - 3” dealer lift w/ 20 in. wheels; Nitto RidgeGrappler 35x12.50R20LT
    Toook a trip to nashvegas for da 4th. Got bout 13.5 MPG.
    Got 20 in wheels and 35s on her but I was hoping for better mpg.
    Drive modes?
    Auto stop/start?
    Other???
    y’all getting about 13-14 mpg average?
    thanks for the HEPP!
  2. Jul 8, 2024 at 11:46 AM
    Gman6112
    Gman6112 New Member
    Gerald
    I got 14 in my non hybrid on 35s and that was staying out of hard acceleration and freeway cruising in eco mode.
  3. Jul 8, 2024 at 11:50 AM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    are you really surprised after putting 35s on it….?
    cmiles97, LimitedLuck, raylo and 9 others like this.
  4. Jul 8, 2024 at 11:52 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Should be at least 55 MPG, right?
    cmiles97, digitalwiz, Mater and 5 others like this.
  5. Jul 8, 2024 at 11:55 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    be a better eco driver?
    i get much better than that. with lift, 35s, RTT, and all the armor
  6. Jul 8, 2024 at 11:57 AM
    HulkHog
    gotcha. Loved mine off the lot with the dealer installed mods and tires etc but I haven’t had a vehicle with that stuff before so I figured that was the deal. Oh well love it anyway right!?
    Thank for da hepp!!!
  7. Jul 8, 2024 at 12:20 PM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    I did a 1200 mile road trip recently and best I got was 18.5 mpg with 34” tires on my truck. Otherwise it is stock. 18.5 was on highways with a speed limit of 65 mpg. Once I hit highways over 70 it dropped down to 17. Got into the mountains and it went down to 16.5. Supposedly the mpgs will improve after around 10k miles from what I read. So we shall see. It’s a heavy truck so I really didn’t factory in gas mileage when buying.
  8. Jul 8, 2024 at 12:21 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    Are you calculating your mileage taking into consideration the larger diameter tires affect on mph and distance travelled?
    wxman91 likes this.
  9. Jul 8, 2024 at 12:32 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    From the way you type I'm thinking you got 16mpg but just couldn't read the gauges correctly.
    Sorry, couldn't resist. 35's and a heavy foot could without a doubt be a big contributing factor.
  10. Jul 8, 2024 at 12:37 PM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Did you reset the mpg's before your trip?
    I get that mpg running around town but as soon as I get out on the open road I'm consistently getting 19-22 mpg depending on speed, trip length, and such. I pretty much run Eco in the drive mode and I don't have a heavy foot on the accelerator. I also use the cruise if I'm on a long trip on the interstate.
    HulkHog[OP] likes this.
  11. Jul 8, 2024 at 1:11 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Sounds about right given the lift, the 35's and assuming less than fully "broken-in" mileage.
    No matter where it finally shakes out at, you'll typically give up 2 to 3 for the lift and 35's.
    LOTS of threads in here about mileage, and the effects of lift/big tires.
    My mpg's took a serious turn for the better at just over 3K miles. Others have said it takes 5 to 10K.
    I'm at stock height and lightweight, wimpy 20" Falkens and I'm getting a really consistent 19-20 commuting 12 miles to work. A few stops but mostly 55-63 mph.
    Road trip over the long weekend with combined passengers/payload of ~1K# and minimum 65 to quite a bit of 75-80 and I still averaged 21-22.
    Disclaimers:
    I burn non-E 91 in it exclusively. Corn fortified fuel will affect your mpg and I'm not too hip on long-term effects of ethanol.
    Auto start-stop disabled. Hate it.
    "Standard" cruise control only. Adaptive cruise applies the brakes too much and mileage suffers.
    Sport driving mode when commuting, Eco on highway road trips, Normal everywhere else.
    As @NickBrewer mentioned a few replies above mine, you're doing slightly better than you think you are if you haven't taken the increased tire diameter into account.
  12. Jul 8, 2024 at 1:12 PM
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    Yeah the truck is calculating less distance than what you are actually traveling so the mpg's will be underestimated as well so it's probably closer to 14.5.
  13. Jul 8, 2024 at 1:33 PM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    what was cruising speed? Last week was 380 miles and I hand calculated 19.6mpg on 37s.
  14. Jul 8, 2024 at 1:37 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    I'm in the 14-15 range with a hybrid and 35" tires. I was expecting better, since my non-hybrid F150 with 35" tires previously averaged 17-18. And I drive them both the same, not a heavy foot. Towing my side x side on the trailer, approximately 3,400 lbs, I get 10. I used to get 12 with the F150. I think the problem is gearing on these trucks. The F150 had 3.55s in the rear and the Tundras have 3.31s. Add the taller tire and it reduces the final gear ratio. I believe the turbos have to kick on more often due to the high gearing. 3.55 or 3.73s would be great and probably tick mileage up a little to reduce the turbo use. I do love the truck though, don't flame me as a complainer.
    HulkHog[OP] and wxman91 like this.
  15. Jul 8, 2024 at 1:40 PM
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    I just came back from a couple of road trips. One was ~400 miles, averaged 18 mpg corrected. That was 80-85 mph. The other was up the mountains ~200 miles, averaged 16.7 mpg, about 75 mph.
    Around town I'm about 16.5
    Colotundie likes this.
  16. Jul 8, 2024 at 1:47 PM
    wxman91
    Montana
    I'm hoping an upgraded gearing becomes available from someone in the future.
  17. Jul 8, 2024 at 2:37 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    “How to get v8 fuel economy from a v6.”
    Lift creates excess drag.
    35s weigh ~25lb more each.
    Now your v6 has to make more boost to get going (heavier tires) and to keep going (excess drag).
    Thank you for coming to my ted talk.
  18. Jul 8, 2024 at 2:51 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Im just here for the replies :)
  19. Jul 8, 2024 at 2:52 PM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Yeah, I get 17-18 mpg but I am on not quite 35s but 34.5s and no lift with a hybrid so I would say that is right.
  20. Jul 8, 2024 at 3:24 PM
    HulkHog
    I did, on return trip I reset on the way out of town, so two hour trip.
  21. Jul 8, 2024 at 3:25 PM
    HulkHog
    70-75
  22. Jul 8, 2024 at 3:27 PM
    HulkHog
    Thanks man, very helpful for me since I’ve not had a truck outfitted like this before. Appreciate you taking the time to reply.
  23. Jul 8, 2024 at 7:40 PM
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    I get 11.5-12.0 mpg towing a 6000lb travel trailer going 70mph……. I get about 17.5-18.0 mpg when not towing… mixed driving. My calculated and truck’s stated mpg are within tenths of a mpg of each other too.
  24. Jul 8, 2024 at 9:53 PM
    HLR_NM
    HLR_NM New Member
    Harry
    Ditto. Just averaged 12 from Alamosa to Santa Fe pulling about 5k of camper, 65 speed limits and pushing 80 passing the slowpokes. In normal day to day, 17 mpg.
    I find it hard to believe that 35’s could knock that much off the mileage. Once you do the math for the speedometer change it probably won’t be that bad.
    Then again, OP modded their Tundra :spending:
  25. Jul 8, 2024 at 11:11 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I made it so that my Tundra gets worse fuel economy and now my Tundra gets worse fuel economy...is how i interpreted the question.
    Hella Krusty and Spartanfam like this.
  26. Jul 9, 2024 at 3:07 AM
    Midnight Rider
    Midnight Rider None of the above.
    Dave
    Wright City MO
    2023 Platinum Crewmax 4x4
    Cup grips & a 2 decals.
    Mine’s a non hybrid, bone stock. Just did a 500 mile trip over the weekend, averaged 21.4 mpg hand calculated.
    BoulderGT3 likes this.
  27. Jul 9, 2024 at 3:40 AM
    awpk03s
    awpk03s New Member
    Stock height and tires here, on 15 mile commute ranging from 35-65 mph with several stops, I can baby it to 18s but average 16-17. On a longer drive at 60-70 speeds without lot of stop and go, like country roads (not highway where I’m doing 80+) I can get 20-21.
    Tyrus001 likes this.
  28. Jul 9, 2024 at 7:03 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    @HulkHog you are far far far from the first person to ask this exact question.............
    As has been reiterated over and over before you, you lifted a brick in the air and now it has more drag, you likely bumped up to a 12.5" wide tire so considerably more rolling resistance, and then the 35" tires probably weighs 25+ lb's per corner. What did you expect to get? Near what it was before?
    You also need to adjust your mileage for your 35's and not sure exactly what size you got but you're probably in the neighborhood of about 7%-10% off so you can add another 1-1.5 mpg to that 13.5 to get about 14.5-15 mpg actual based on the real distance traveled being further than your odometer reads. Try a mileage tracker on your phone on the next road trip to see how far off odometer to real mileage actually is.
    I personally saw a 2-4 mpg jump in mileage around 10k miles.
    You wanted a lift and 35's so now you just have to ignore the gas pump or put it back to stock.
  29. Jul 9, 2024 at 7:15 AM
    Terndrerrr
    Music City
    6UR-FE
    I’m running 285/75R18s. These are 34.8” tires (35.1” depending on the wheel it’s mounted on).
    The stock tires the speedometer is calibrated for are 275/65R18. My current tires on paper are 8.4% larger (tiresize.com).
    Due to inflation pressures and the way the larger LT tire disproportionately deforms* as it rolls, the difference between my speedometer and actual GPS speed is 5%, not the expected 8.4%.
    Get a free GPS speed app, and check it against your dash at several speeds.
    *I suspect the larger E load LT tire deforms more because the PSI we run them at (~38-40) is lower as a % of its max inflation compared to the SL load tire specified on the door jamb.
    Saltyhero13 and HulkHog[OP] like this.
  30. Jul 9, 2024 at 9:58 AM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    MPG posts should be banned.
