Movable headlights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Capt.David, Oct 15, 2019.
  1. Oct 15, 2019 at 4:14 AM
    Capt.David
    Capt.David [OP] New Member
    David
    2017 Tundra SR5 4x4 5.7
    Just figured out why my headlights seemed to be aimed low. I found the headlight elevation adjustment control. Can anyone tell me the purpose of this? Other than if I lift the truck? Or maybe towing a heavy tongue weight trailer
  2. Oct 15, 2019 at 4:17 AM
    Stig
    Stig New Member
    No other reasons than those.
  3. Oct 15, 2019 at 4:17 AM
    War Machine
    War Machine SSEM # 5 3MW
    Both of your assumptions are correct.
    TokerJoker and GODZILLA like this.
  4. Oct 15, 2019 at 8:23 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    You’re not getting the whole answer.
    It also allows your truck to look up and down.
    They are still working on a side to side function.
    ...and bifocals for older trucks.
  5. Oct 15, 2019 at 9:37 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    To aggravate someone in front of you stopped at a traffic light... up/down up/down up/down...:)
  6. Oct 15, 2019 at 12:57 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    No Owner's Manual:confused:
    TokerJoker and Black Wolf like this.
  7. Oct 15, 2019 at 1:20 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  8. Oct 15, 2019 at 1:36 PM
    Capt.David
    David
    New to me 2017 truck. I found it by mistake. Was sitting in the driveway thinking I was adjusting the dash brightness. I've driven trucks since 1983 and never had the need to adjust my headlights vertically. My first truck was a 53 ford flathead V8 they didnt have that option
  9. Oct 15, 2019 at 1:38 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Its a lot of fun when you have a jackass cut you off and you can adjust your lights to shine perfectly into their mirrors....so I have heard
    CLowery, TokerJoker, GODZILLA and 5 others like this.
  10. Oct 15, 2019 at 1:41 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    That's why I like power mirrors, I can adjust them so the lights are reflected back at the car bright lighting me LOL..
  11. Oct 15, 2019 at 1:46 PM
    CMB
    CMB New Member
    Cecil County MD.
    We tow quite a ways every year for vacation. After loading up the bed with gear and hooking the boat on the back, lowering the headlights back down where they were just makes sense to me.:thumbsup:
    15whtrd likes this.
  12. Oct 15, 2019 at 1:47 PM
    Lake.Life24
    Shawn
    Upstate, NY
    I would never bright light a fellow tundra forum member
    TokerJoker and RLHULK[QUOTED] like this.
  13. Oct 15, 2019 at 1:48 PM
    Zero One Actual
    Oh you mean the VSLVA?
    The Variable Skirt Length Visual Aid?
    panicman and 773_eddie like this.
  14. Oct 15, 2019 at 2:11 PM
    Capt.David
    David
    I've since kept them in the highest position. Will see if I get flashed. My previous tacoma ( same year and SR5) seemed to have better high beams.
  15. Oct 15, 2019 at 3:08 PM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    My BMW automatically adjusted the headlights up and down depending on how level the car was and when going around corners would adjust them left or right as needed. I can only guess what it would cost to repair if ever necessary.
    Pudge likes this.
  16. Oct 15, 2019 at 3:43 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I replaced one headlamp assembly on a 2013 550xi it was 1700.00 just for the part
    Pudge likes this.
  17. Oct 15, 2019 at 4:39 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    It took me a while to figure it out too... going to upgrade the stock Halogen bulbs.
    my 2012 Lexus RX350 points the headlights left or right based on the steering wheel position - that freaked me out at first!
  18. Oct 15, 2019 at 5:30 PM
    rds95991
    rds95991 New Member
    I had one headlight go out and BMW wanted $400 for the job. Turned out the bulb was $30 or $40. I decided to try it myself. I had to removed the tire, fender lining, and bumper to get to it. Replaced the bulb and it worked. Put everything back together and the other bulb went out so I have to do the same thing to the other side.
  19. Oct 15, 2019 at 5:40 PM
    I bet you wish you still had that flathead Ford!
  20. Oct 15, 2019 at 5:45 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Our headlights do what!?!
  21. Oct 15, 2019 at 6:58 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I lowered mine in a drive though once, being nice. Don't do it often, being nice that is.
    Grumpy Uncle and TokerJoker like this.
  22. Oct 16, 2019 at 11:05 AM
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    I see a LOT of loaded pickups that don’t have easily adjusted headlights...or they don’t care.
    Annoying as hell, especially on long drives when patience is wearing thin.
  23. Oct 16, 2019 at 5:54 PM
    Capt.David
    David
    Yes indeed I do. We paid 800 for it in 1983. Hindsight 2020
