Mounting tv on brick
Discussion in 'Home Improvement' started by Ps3udonymous, Nov 27, 2018.
  1. Nov 27, 2018 at 5:56 PM
    Ps3udonymous
    Ps3udonymous [OP] Who is the smart ass that changed the title?
    Anyone have some advice for mounting a tv to a brick fireplace? Such as anchor to mortar or brick, which anchors are best.
    It's a 65" tv, weighs around 50 pounds
  2. Nov 27, 2018 at 6:16 PM
    Tapcon screws are probably your best bet.
  3. Nov 27, 2018 at 6:44 PM
    Ps3udonymous
    I'm thinking similar, however I wanted to see if we had any people who have done the same thing I'm doing and what their plan was and how its working
  4. Nov 27, 2018 at 6:47 PM
    wilsonos2
    wilsonos2 New Member
    Don
    2018 Tundra Sport
    3” lift, 33” tires
    lag and lag shields. Id go in brick if you don't care about holes later when the TV comes down.
  5. Nov 27, 2018 at 7:01 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Tap cons are your best bet.make sure they are long enough to get a good bite into the brick. Also,be sure to use the right size masonry drill bit for the right size tap cons
  6. Nov 27, 2018 at 7:05 PM
    Ps3udonymous
    You mean the lead ones, or the plastic drywall anchor looking ones?
  7. Nov 27, 2018 at 7:06 PM
    Ps3udonymous
    Should I shoot to punch through the back side of the brick, or just the front face?
  8. Nov 27, 2018 at 7:09 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    For masonry use lead no plastic
  9. Nov 27, 2018 at 7:26 PM
    tenntundra
    Walter
    Tennessee
    I agree
  10. Nov 27, 2018 at 7:57 PM
    Coryip
    Coryip New Member
    Cory
    2014 Tundra DC XP
    The mount usually comes with the plastic anchors and lags needed for masonry, some are better than others. I have no problem using them and done properly will hold any TV. Tapcons will also work but not my first choice. Have hung a few hundred on masonry and never an issue.
    NewImprovedRon likes this.
  11. Nov 27, 2018 at 8:04 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    @1UPPER
    Have used heavier plastic anchors with no issues.
    1UPPER likes this.
  12. Nov 27, 2018 at 8:10 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    I love these for attaching to concrete block or brick. Drill a hole and hammer it in. Done!
  13. Nov 27, 2018 at 8:16 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    @Areith762 did this at his house IIRC. Might have some ideas.
  14. Nov 27, 2018 at 8:24 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    The ones we use for work to anchor into concrete are RedHeads. They sell them at home depot.
    You can use tapcon screws but you need a roto hammer or hammer drill to drill into masonry. Drill to size of tapcon, epoxy (optional), then screw in.
    Home depot also has threaded sleeves you can buy. Drill hole, epoxy (optional), hammer in sleeve, thread bolt.
    You do not want to go thru the brick.
  15. Nov 27, 2018 at 9:17 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I hung a 65” for a customer on a stone fireplace like 15’ in he air. Tapcon and a locktite glue that came in tube. Put 3 on top and 3 on bottom. With washers. I would go in the brick. Those other anchors seem nice should work that’s just not what I used. And it was terrifying hanging that thing that high up I wish I had pictures but I lost them on my old phone
    1UPPER likes this.
  16. Nov 27, 2018 at 11:22 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    I had my home builder add some horizontal studs above the stone fireplace for me to mount to. Made mounting my TV much easier. I believe I used 6" lag bolts through the mortar and into the studs. Kind of hard to see in pics with the TV mounted.
    Prostar 190 and T-Rex266 like this.
  17. Nov 28, 2018 at 4:23 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I would either do like @Alexstundra suggested, or I would find the location of my studs behind the brick and use longer lag bolts to fasten into the studs. The lag bolts would need to be 6”-8” long and this could be risky if you don’t know what behind the stone. Like hitting a possible electric wire or something you can’t see. Do you have any photos of the fireplace or brick?
  18. Dec 2, 2018 at 8:36 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I mounted a 50 in tv to a brick fireplace for my dad I predrilled and used the blue masonry screws. It worked great.
  19. Dec 18, 2018 at 3:29 AM
    Ps3udonymous
    Update
    Tv was mounted this weekend. Used four 5/16" tapcons. Was worried they would crack the brick when tightening up but so far they've been alright. I wish I could post pics but I havent been able to figure that part out. Thanks all for the suggestions.
    Prostar 190 likes this.
