Mounting point King rear resis?
Discussion in 'Suspension' started by smslavin, Aug 18, 2017.
  1. Aug 18, 2017 at 6:56 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Current plan is to try and tackle my suspenion install tomorrow. I think I've got a clear idea on everything except for one item. Where do I mount the reservoirs for the King rear shocks?
  2. Aug 18, 2017 at 7:10 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    They will show up with some brackets. For the front reservoirs you'll unbolt some swaybar mounting bolts and in the rear there are two convenient holes on the bed for a bracket. I think on the third gen you'll have to trim a little bit of plastic but the instructions have a lot of good pictures.
  3. Aug 18, 2017 at 8:05 PM
    smslavin
    Hudson Valley
    Some stuff
    Perfect. I didn't realize there were holes already in the bed. Thanks.
  4. Aug 18, 2017 at 8:50 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
  5. Aug 18, 2017 at 8:50 PM
    Good luck tomorrow. Flight must have not been really delayed.
    I checked my welding setup. Gas, hood, rod, and low on beer. Good. To. Go.
    Sefferston and Law323 like this.
  6. Aug 18, 2017 at 8:56 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    There's a couple of holes on the frame that works for resi mounting.
    Only problem you MAY run into is the bolt provided might be too big or too small. That's how it turned out on my rear resi's from Toytec. Nothing a smaller bolt with a locking nut won't fix.
    Simple run to HD or Lowes.
    NewImprovedRon and ColoradoTJ like this.
  7. Aug 18, 2017 at 9:18 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Easy. Mount them in my garage.
