Mounting my Tekonsha P3 (a ‘lil different)
Discussion in 'Towing & Hauling' started by Jacobsk, Jul 8, 2019.
  1. Jul 8, 2019 at 7:23 PM
    Jacobsk
    Jacobsk [OP] New Member
    Wisconsin
    2014 5.7 DC LTD BLK
    This forum rocks, it’s been a blast getting to know the in’s and out’s of these trucks since I started lurking before picking up my ‘14 DC back in April.
    Of course with all of the love for the P3, I had to order one, as my truck came with the tow package which excluded the factory brake controller.
    Before I went and bought a mount from ESP (which look really nice!) I figured I’d take a stab at chopping the stock bracket and fitting it into the dash panel which came stock on my truck.
    I wanted it to be as recessed into the panel as possible as there’s really not much room between my knee and the dash as it is, and having the controller protrude forward like everything I’ve seen to date seemed like it would get in the way.
    Then there’s the inevitable realization that you can’t really recess the P3 controller due to the location of the manual brake lever underneath, that is unless you have access to the lever even with it recessed :)
    7C9E5808-F86B-476C-966D-CA44EED69567.jpg 8611D82E-83F0-42A7-AD9E-0064B0D9075C.jpg 7AD31C19-2E1E-4706-A37E-8E3E5FA6B2DD.jpg
    The last image is of the backside before I cut the access hole underneath for the mechanical lever. I used 1/4” spacers, 3/4” long 8-32 screws, and the stock mounting bracket cut in half to mount the controller through the hole cut (Dremel) through the panel.
    So there ya go, something a little different for ya to noodle on!
  2. Jul 9, 2019 at 9:15 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    That is totally awesome! I wish I would have thought of something like that. Since I am so short, I have to have my seat all the way forward, and I hit my knee on the controller all the time.
  3. May 1, 2020 at 10:41 AM
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    Nice work! What did you use to cut the access panel? Do you know which brackets you bought for the interior mount?
