Mounting brackets above rear tires
Discussion in 'Wheels & Tires' started by Superblurr, Mar 29, 2019.
  1. Mar 29, 2019 at 8:18 PM
    Superblurr
    Superblurr [OP] New Member
    '07 Limited
    Front bumper, winch, LED Lights, slotted rotors, & a Supercharger
    Hello Tundra Brothers!
    Does anyone know the brackets above the rear tires are for?
    Are they for a skirt or apron?
    The Sequoia has road nose shielding there.
    Is it because the frame is the same as the Sequoia?
    Just curious if I can lower the road nose.
    Thanks Brothers.
  2. Mar 30, 2019 at 11:34 AM
    CrewMaxT
    CrewMaxT New Member
    Alberta
    2018 CrewMax SR5
    Not sure what the brackets are for, but if you want a quieter cabin you can add sound deadening materials to your doors and floor. Tires will have an impact as well. I noticed the stock Bridgestone tires are very quiet compared to most all terrain tires. Also, adding a road noise shield in the bed area won’t do much good since it’s separate from the cab.
