Mountain towing capacity
Discussion in 'Towing & Hauling' started by Mtnfolk, Aug 4, 2018.
  1. Aug 4, 2018 at 11:24 AM
    Mtnfolk
    Mtnfolk [OP] New Member
    Gil
    Trading our 2016 Tacoma for a 2018 Tundra 5.7 8 cyl 4WD because of towing issues. The new Tundra says it’ll pull 9900#. The Tacoma capacity is 6400 but that clearly doesn’t apply to mountain driving. It was work to pull 2000#. I really don’t want to spend a bunch to find out the Tundra has the same problem. Comments?
  2. Aug 4, 2018 at 11:31 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I have towed a 3000# trailer without breaking a sweat, but not in the mountains. You can check out the TFL youtube videos on the Tundras towing characteristics. Little disappointed in the Tundras payload capacity though, 1200lbs for CM 4x4 with accessories. 5.7l Engine and Transmission are beastly compared to my older F150 5.4l 4x4, luv the low rpm torque band.
    Mtnfolk[OP] likes this.
  3. Aug 4, 2018 at 11:54 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    I towed 6k lbs up to ~4500ft, with absolutely no issue. I do have the TRD Dual exhaust so it did shift down quite a bit, but there is no lack of power that's for sure.
    I was also loaded down with probably another 1k in the truck. Was probably a bit over the limit, but it handled like a champ.
  4. Aug 4, 2018 at 12:31 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    I have pulled the #3,500 pound mark through the mountains with no issues. The truck would definitely handle a lot more weight
  5. Aug 4, 2018 at 12:32 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO.
    Where do you live?
    And what are you towing?
  6. Aug 4, 2018 at 1:17 PM
    Mtnfolk
    Gil
    We're in Glenwood. Selling our wonderful Adrenalin Blast off-road camper and buying a T@B400.
  7. Aug 4, 2018 at 2:19 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Whats the weight of that camper?
  8. Aug 4, 2018 at 2:33 PM
    Mtnfolk
    Gil
    2700 dry. 3000 with stuff. Plus gear in the truck.
  9. Aug 4, 2018 at 2:35 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Shit, you won’t even notice it’s back there. I tow my boat at 3300 pounds at 9500 ft around Hartsel area and can’t even tell it’s behind me.
  10. Aug 4, 2018 at 2:43 PM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    I’ve pulled 9000# through the mountains no problem. Be sure to use the tow haul button. Use a good weight distribution hitch. Adjust the electric brake controller until it locks the tires on the trailer and then back off a bit from there. Prepare yourself for roughly 8 MPG on a good day pulling.
  11. Aug 4, 2018 at 2:45 PM
    Mtnfolk
    Gil
    Thanks. This is really helpful.
  12. Aug 12, 2018 at 8:24 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    You are about 800 lbs more than my Aliner. I just finished a trip (300 miles one way) across a 3300 and 4200 passes at highway speeds. No problem. The tough one was the last few miles to my buddy’s ranch, at 4100 ft going on dirt and 2 track. No problems, except for the dust. Some of the road was at 9% grade. It was a good breakin for the 4 wheel drive. I never used the tow mode as it was not a struggle. Used manual mode to keep it in 1 and 2 on he way down to save the brakes.
    I heard a quote “go as fast as necessary but slow as possible”. No rush to go over rough sections, watch out for big rocks, sharp rocks and holes. 4BD32816-9665-4BB5-970B-80E213678F04.jpg
  13. Aug 12, 2018 at 8:37 AM
    This shouldn’t even be an issue in CO.
