Mount & balancing new tires
Discussion in 'Wheels & Tires' started by PermaFrostTRD, Dec 5, 2016.
  1. Dec 5, 2016 at 3:04 PM
    PermaFrostTRD
    PermaFrostTRD [OP] Tumescent Member
    Northern NY
    Just had my 275/70 r18 BFG A/T KO2's delivered to the house today. Going to have the dealership mount and balance them $79.99 out the door. Service manager or rep asked me if I "wanted to get the alignment too so the tires wear evenly?""
    Am I just being *sold* an alignment? The truck rides great and is in perfect alignment now. I'm not changing suspension or steering geometry at all so shouldn't the truck *remain* in proper alignment? To me this seems like the equivalent of a tire rotation. No alignment when that's done.
    Thanks in advance for your help!
  2. Dec 5, 2016 at 3:07 PM
    Front end suspension wasn't touched right? If not, then no.
    FlashCulprit likes this.
  3. Dec 5, 2016 at 3:14 PM
    PermaFrostTRD
    Northern NY
    Correct. Well, it won't be touched. Appointment is this coming Saturday
    Thanks!
  4. Dec 5, 2016 at 3:47 PM
    CVFE
    CVFE I've got nothin'!
    2016 Tundra Limited, black
    4" Rough Country Lift 22" Fuel Mavericks 35" Black Bear Mud Terrain Tires Fender Flares
    If you have to get an alignment, pay an extra 50 bucks and Firestone does a lifetime alignment. You can take it in for alignment as much as you want and it doesn't cost a penny more.
  5. Dec 5, 2016 at 4:04 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    well I don,t want to bust any balls but I would stay away from Firestone for any thing car or truck related...Just my 2 cents
    Sixpack likes this.
  6. Dec 5, 2016 at 4:17 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Especially tires for a ford explorer.
    Law323 likes this.
  7. Dec 5, 2016 at 4:18 PM
    csuviper
    Broomfield, CO
    What is the stock tire size on your truck?
  8. Dec 5, 2016 at 4:57 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    When was the last alignment you have had? How do you know it's in perfect alignment?
    Did you tire size change?
    ~$100 is not bad to be on the safe side for a set of $1000 tires, but if the alignment checks out fine then you may be a bit frustrated.
    PermaFrostTRD[OP] likes this.
  9. Dec 5, 2016 at 5:10 PM
    PermaFrostTRD
    Northern NY
    275/65 r18
    Adding an inch to the diameter with the new boots.
  10. Dec 5, 2016 at 5:11 PM
    PermaFrostTRD
    Northern NY
    Fair point. It was CPO when I bought it at the end of august / beginning of sept. Aligned at then. Doesn't drift, rattle, wobble, pull, anything.
