Motor Swap for 2011 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Yhello, Dec 24, 2023.
  1. Dec 24, 2023 at 1:11 AM
    Yhello
    Yhello [OP] New Member
    Greetings to you all. I'm glad to be here. Please I need help to know which of the lower model of Tundra motor is good to swap with my 2011 Tundra 5.7L Engine limited edition.
  2. Dec 24, 2023 at 1:29 AM
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    Any tundra 5.7 motor will work its going to be 10-15 k depending on junkyard motor or reman.
    Yhello[OP] likes this.
  3. Dec 24, 2023 at 5:08 AM
    treeandsome
    treeandsome New Member
    WHAT HAPPENED TO YOURS?
    4x4WarriorOfRocks and Ricos like this.
  4. Dec 25, 2023 at 11:25 PM
    Yhello
    All the lights are on with check enginelighton dashboard. It always misfire and won't move whenever I stopped at stop sign unless I restart it.
  5. Dec 26, 2023 at 1:44 AM
    Sinbad2323
    Sinbad2323 New Member
    None of this is a reason to replace your engine without further diagnosis.
    blackdemon_tt and Wsteven like this.
  6. Dec 26, 2023 at 6:05 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I agree with @Sinbad2323 further diagnosis is required. If it's already at a shop, I'd take it to another shop. 5.7l are pretty similar across the board. What is the mileage on the engine? Has any maintenance been done? Have you checked the transmission fluid level?
  7. Dec 26, 2023 at 6:08 AM
