Most gauges not working. Speedo down
Discussion in '2nd Gen Tundras (2007-2013)' started by erknicstone, Sep 12, 2019.
  1. Sep 12, 2019 at 7:30 PM
    erknicstone
    erknicstone [OP] New Member
    2007 5.7L Limited
    Howdy all! 2007 5.7L Limited.
    ABS light on, brake light on, airbag light on. No gauges(speedo, odo, tach, oil, temp.) except, voltmeter and fuel. Odometer not counting and no limp mode. No temperature by clock. The Cluster has lights and the gauges sometimes work on random days. The next day I turn the key and it will have the issue and gauges are down. Once in a while I can put it in park and it will start working again. However, I can go down the road and all of a sudden it will quit again. The last few days its been down every day except once today. Once I went over the railroad tracks the gauges went down. Seems like a short to me?
    I checked the fuses, they are fine. I also disconnected the battery to reset computer and it didn't help. Also it really hasn't been soaked with water or anything, I live in a really dry climate.
    Any help would be greatly appreciated!
  2. Sep 12, 2019 at 8:01 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Sounds like 1 or more connections loose somewhere. Maybe a mouse problem?
    15whtrd likes this.
  3. Sep 25, 2019 at 1:38 PM
    erknicstone
    2007 5.7L Limited
    Yeah, that's what I'm thinking. Just wondering where to start? Someone's got to have had this problem? Wondered if ABS light on, brake light on, airbag light on would indicate the area of the problem?
  4. Sep 25, 2019 at 2:02 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Check your battery and I don’t mean just checking the voltage, that’s not a very good measurement. You need to check it with a load on it...parts store should do this
  5. Sep 25, 2019 at 2:37 PM
    erknicstone
    2007 5.7L Limited
    I'll give that a shot. It's just weird how the gauges can work and then while hitting a bump they (speedo, odo, tach, oil, temp.) will quit, all others ok. Like I mentioned, sometimes I can put it in park and they will start working again. That's why I suspect some sort of short. ???
  6. Sep 25, 2019 at 2:49 PM
    Jrharvey02
    You’re prolly right, but...check the easy stuff first. I’ve read numerous posts on here about tundras dashes lighting up like an Xmas tree...sometimes it’s the battery...
  7. Jul 27, 2023 at 9:36 AM
    gjb777
    gjb777 New Member
    Gabriel
    08 Sequoia Big Blue
    Custom paint, wheels, icon suspension, JBA uppers, Katzkin interior, rigid lighting, Kicker System
    Ever figure out the culprit? Having same issued
  8. Jul 27, 2023 at 9:40 AM
    OP hasn’t seen on here since 2020
    FrenchToasty likes this.
  9. Jul 27, 2023 at 10:40 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    It’s a disconnect or loose connection with the CAN bus, communication network. Everything he describes as not working is driven by messages and data on the CAN. The network runs on two wires, a high and low. It is what links all the ECUs of the truck together.
    I think others have reported a bad wheel speed sensor or short in wheel speed sensor wiring can take the network down. The wheel speed sensors report data to the network to run the speedometer.
  10. Aug 3, 2023 at 10:39 PM
    gjb777
    gjb777 New Member
    Gabriel
    08 Sequoia Big Blue
    Mine was a bad steering angle sensor
