Moron of the Day!!!
Discussion in 'General Tundra Discussion' started by david91680, May 26, 2019.
  1. May 26, 2019 at 6:15 AM
    david91680
    david91680 [OP] 2019 Cement SR5 4X4 Crew Cab
    David
    Hickory, NC
    2019 SR5 4X4 Cement Crew Cab
    Well what a way to start!!! New Tundra owner and wanted to get the opinion of others. Literally had my Tundra 6 days and garage door came down on it yesterday.
    Hadn’t been using the garage opener because the Tundra is too big for my garage to close. So the opener is laying on the middle console and my son hits the button while I’m on the phone. I see the door coming down in he rear view mirror but it’s too late.
    Obviously looking for the best body shop in my area. Don’t really care about the costs. Mainly curious to see from other what luck will I have restoring this truck to looking new again.
    Just a nightmare scenario.
  2. May 26, 2019 at 6:23 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    ALWAYS put something in front of the sensor if you're working in the garage door area even if the opener is not in a place where it can easily be touched.
    TheBeast likes this.
  3. May 26, 2019 at 6:23 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    So your garage door came down in 4 different spots?
    Heff, bdpeelgren, Darkness and 6 others like this.
  4. May 26, 2019 at 6:25 AM
    Total bummer man.
    A good rated body shop will make that look great again. I’m sure there are plenty in NC.
  5. May 26, 2019 at 7:00 AM
    david91680
    David
    Hickory, NC
    I added the tailgate and back panel scratches. Once the door rested on the bed instead of simply using the door opener to relift the door I in a rage pushed the door up and then the door came off the rack.
    The sensor comment is a great idea. My sensors are lower to the ground and obviously didn’t pick up the tailgate.
    However in this situation I was about to back out once I got off the phone.
    Any body shop experts know how extensive the work will be?
    Passenger side cab is the worst. Actual dents. Tailgate and back panels scratches.
  6. May 26, 2019 at 7:07 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Think cost may justify an insurance claim.
    Most dealerships have great body shops
    Tundyfundy and Sunnier like this.
  7. May 26, 2019 at 7:10 AM
    david91680
    David
    Hickory, NC
    Yeah. Going through insurance for sure. I know it won’t be cheap. It’s a brand new care. Honestly I don’t care what it costs. I want it fixed. Just was curious what all would need to be done.
    With Memorial Day, I won’t see a shop until Tuesday. So I’m just trying to get some ideas because im sick and won’t feel better until it looks new again.
  8. May 26, 2019 at 8:30 AM
    ktmsmitty
    ktmsmitty New Member
    Ed
    Murfreesboro, TN
    2019 Toyota Tundra SR5
    Coming REAL soon.............
    Looks like paint only, no metal damage? Either way a good body shop and you will never know that it happened. Only in your nightmares! Sorry for this David.......that sucks.
  9. May 26, 2019 at 8:53 AM
    Welcome from NY.
    Sorry to hear about the damage. I would go through your home owners insurance.
    Where are you from? (Edit your profile) Maybe somebody in your area can reccomend a good shop.
  10. May 26, 2019 at 9:02 AM
    david91680
    David
    Hickory, NC
    The passenger side of the cab is a little dented. 2nd pic. Rest is paint.
    ktmsmitty[QUOTED] likes this.
  11. May 26, 2019 at 9:02 AM
    david91680
    David
    Hickory, NC
    Hickory, NC
    SoCalPaul likes this.
  12. May 26, 2019 at 9:24 AM
    There's a few members down that way, hopefully someone will chime in.
    I'd like to move down to the Lake Norman are in about 3 years, beautiful area.
    YeeYeeTundra likes this.
  13. May 26, 2019 at 9:44 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Man, sorry to see that. I’m sure you’ll get it back to new. On a side note, how much down pressure does that door have? That has to be some serious force to cause that. You might want to adjust if possible.
    My wife has closed the door on her Highlander tail gate three times and all three left very minimal damage.
  14. May 26, 2019 at 10:36 AM
    Trooper2
    JR
    The back of cab will take some body work; pop out ftom inside, possibly drill tool and pull, then bondo or filler to smooth out. Shouldn't be able to tell when finished. Possibly similar on rear corner above taillight.
    As mentioned, check into you home owners insurance as well.
  15. May 26, 2019 at 12:03 PM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    Thats too bad bro. Bummer. Did you have the truck Backed in, only partly in the garage because the front wont fit? Or was it just too long for your garage and the back sticks out?
  16. May 26, 2019 at 12:25 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Live with it until someone hits you(it will happen). Then their insurance can pay.
  17. May 26, 2019 at 12:26 PM
    david91680
    David
    Hickory, NC
    Yeah just pulled it in ....front side in and kinda catty cornered. Just was getting it out of the 95 degree heat. Was going to be leaving soon.
  18. May 26, 2019 at 12:30 PM
    BlueDream
    95 already? where you at Arizona or South nevada? Its Raining and 45 here in No. cali
  19. May 26, 2019 at 1:16 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I was born in So Cal, but both my parents families are from the Hickory / Conover area for 300 years. Hunsucker, Huffman, and many others.
  20. May 26, 2019 at 1:41 PM
    GNTundra
    Gino
    2013 White
  21. May 26, 2019 at 1:51 PM
    soobaroo
    soobaroo New Member
    Gene
    2019 Tundra SR5
    You aren’t the first to have that happen so don’t let it get to you. It will look fine after it’s repaired. I had a new Mazda pickup half way in the garage. Went to turn the light on but hit the door opener instead. The door came down on the top of the box rails and did no damage. Unfortunately for me this was an old opener with no safety features. The door kept trying to come down and shattered beyond repair. That screw up cost me a new garage door which wasn’t cheap.
    Tundyfundy likes this.
  22. May 26, 2019 at 4:42 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    When I first bought my Tacoma years ago I had it a week and a kid backed into it.
    I thought it was totaled but the place made it look perfect.
    Trust me, that is nothing.
    Trooper2 likes this.
  23. May 26, 2019 at 6:03 PM
    david91680
    David
    Hickory, NC
    Thx for the pick me up guys
    Wild SoCalPaul. Small world. Hickory and Conover to Cali
  24. May 26, 2019 at 7:19 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Not to far from me
  25. May 26, 2019 at 7:51 PM
    War Machine
    War Machine SSEM # 5 3MW
  26. May 26, 2019 at 7:59 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Man hate that happened to your new truck.
    Welcome from Western NC.
