Morimoto XB LEDs Gen 2 High beam too powerful
Discussion in '2.5 Gen Tundras (2014-2021)' started by 400Lionel, Mar 3, 2025.
  1. Mar 3, 2025 at 2:11 PM
    400Lionel
    400Lionel [OP] New Member
    Lionel
    2019 Platinum - White
    currently stock
    Good evening,
    Today the Tundra went to the Cantonal road authorities for its first check.
    The technician found that when operating on high beams, the headlights are too powerful, as a consequence he failed the Tundra.
    Is there a way to reduce the light output via CAN bus programming or some bloc unit adjustment setting so that high beams are dimmer?
  2. Mar 3, 2025 at 2:50 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Too much light? What are the parameters on their testing? Can you borrow some halogens and swap them back? What state are you in...I know they're talking about changes in LED headlights in some municipalities...
  3. Mar 3, 2025 at 3:02 PM
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    Can you point your headlights down on the aim controller for when you trailer so less blinding?
  4. Mar 3, 2025 at 3:45 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    I'll trade you my factory LEDs for your Morimotos :rolleyes:
    I'm just a concerned fellow Tundra owner and really want you to pass :rolleyes:
    Nah, really though, what @littlebus01 said should do the trick:monocle: point them downward.
  5. Mar 3, 2025 at 3:47 PM
    TacomaTRD4x402
    Southern California
    Hopefully not California :mad: It WOULD be California though if I were to guess.:annoyed:
    HulkSmurf14[QUOTED] likes this.
  6. Mar 3, 2025 at 4:10 PM
    NEVERGIVEUP
    NEVERGIVEUP New Member
    Sounds like Switzerland
    HulkSmurf14 likes this.
  7. Mar 3, 2025 at 4:20 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    What? That doesn’t make sense. More than likely, they just need to be aimed properly.
    But to answer your question. No. There is no way to reduce the actual output.
    1lowlife and snivilous like this.
  8. Mar 3, 2025 at 4:20 PM
    TacomaTRD4x402
    Southern California
    Ohhh, dang, thought it was the states.
  9. Mar 4, 2025 at 7:50 AM
    400Lionel
    Lionel
    currently stock
    Indeed it is Switzerland and as Morimoto states: high beam output is 100% more low beam output is 30% more. So unfortunately it goes beyond the limits from their system. Thanks God the OEM ones were not discarded.This time it should pass the test ;-)
    snivilous and Ebrperk like this.
  10. Mar 4, 2025 at 8:03 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Where the hell can you drive this thing in Switzerland?
  11. Mar 8, 2025 at 11:24 AM
    400Lionel
    Lionel
    currently stock
    There are quite a few full size trucks on Swiss roads. Only in the mountains it is quite challenging to try to drive above 40km/h on these very twisty roads.
    Another benefit of Switzerland is its proximity to Germany where some parts of the Autobahn network are without speed limit. There, the Tundra is very comfortable up to 160km/h
    On the same sections of the Autobahn the Skoda superb V6 is very comfortable up to 240 km/h. So you can tell the difference between these vehicles.
    1lowlife likes this.
