Morimoto XB LED Fog Lights (Plug N Play)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Aug 19, 2016.
  1. Aug 19, 2016 at 12:56 PM
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    CURRENTLY ON BACKORDER UNTIL 9/16/2016
    You can place an order still and your order will be shipped once we receive them.
    Morimoto XB LED Fog Lights now available for $170 + 10% off and free shipping for being a Tundras.com member. Use coupon code "tundras10" (http://retrofitwholesale.com/product/toyota-oval-morimoto-xb-led-fog-lights/)
    These fog lights are an excellent upgrade for your Tundra. Not to mention they will last longer than your truck does (unless you have another million mile tundra)
    MORIMOTO XB LED FOG LIGHTS (TYPE T)
    No Comparison: Stock sucks! But the new Morimoto XB LED projector fog lights: Look great. Are well-built. Perform like champs. Have a virtually infinite life span. An unbeatable warranty, And best of all you won’t need to sell your soul to afford them!
    Designed: To fit many modern applications from Toyota; these complete housings will mount behind the bumper with all of the stock mounting points. Their aim can also be adjusted just like stock with the integrated assembly that’s cast into their shell. Check the compatibility section below for a list of known applications.
    Powered: by three Philips Luxeon-T 5000K LED’s that produce around 1200 raw lumens per side. The projector based optics inside concentrate a total of 2400 lumens of pure white light into a beam that’s super wide and perfectly distributed for use as a fog light. They are SAE, DOT, and ECE approved.
    Well-Built: Their durable polycarbonate lens should resist the test of time, keeping the housings looking new. The powder-coated cast aluminum housing is light-weight and much stronger than comparable plastic alternatives. Doubling as the heat-sink for the LED’s, the housings completely protect the internals from moisture and road debris.
    Plug n Play: Wiring is easy too! The XB LED Fogs are designed to work without any special wiring. They will plug into the factory power outlets for the stock fog lights and each fog light includes all necessary connectors, rubber seals, and pigtails for a plug n play install.
    PermaFrostTRD, Ryan Mc. and omaguz like this.
  2. Aug 19, 2016 at 2:38 PM
    omaguz
    omaguz New Member
    omar
    Puerto Rico
    2015 Magnetic Grey 1794 Tundra Crew Max
    I've owned mine for over a year and they have performed flawlessly. I'll post night pics later today!!!:thumbsup:
  3. Aug 19, 2016 at 3:25 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    following
    geno0506 and omaguz like this.
  4. Aug 19, 2016 at 3:54 PM
    eledobleu
    Orlando, FL
    Ive had mine since they were first released. Nothing can compare to how amazing these fog lights are! You would think these should be standard on these trucks.
    If your having a hard time seeing at night, these will definitely help increase visibility.
    omaguz likes this.
  5. Aug 22, 2016 at 9:47 AM
    kemosabee
    kemosabee New Member
    James
    Pagosa Springs
    07 Tundra
    Hmm, tempting...
  6. Aug 22, 2016 at 9:51 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I want these... do they fit first gens?
    timesinfinity likes this.
  7. Aug 22, 2016 at 9:52 AM
    hdzeke
    hdzeke New Member
    2014 Black Tundra CM 4x4 TRD
    I put a set in about a year ago, well worth the money in my opinion!
  8. Aug 22, 2016 at 10:05 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Very cool. I haven't looked back there, how easy/difficult is it to install these? Also, being they are brighter white, will they look bad and contract with the factory headlights?
  9. Aug 22, 2016 at 10:14 AM
    kemosabee
    James
    Pagosa Springs
    07 Tundra
    Damn, looks to be only "Tundra 2014+"
  10. Aug 22, 2016 at 3:59 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Not for 2nd gen :(
  11. Aug 22, 2016 at 4:35 PM
    rons23
    Ron
    Kill Devil Hills
    Haha. Steve, hey did you happen to see the new Ap poll, was wondering who was ranked #1, let me know bro. Thanks
    NewImprovedRon likes this.
  12. Aug 22, 2016 at 4:42 PM
    rons23
    Ron
    Kill Devil Hills
    Lol! Well its been a while since a preseason #1 won the championship. Bama needs to change that.
    SouthBoundSteve likes this.
  13. Aug 22, 2016 at 4:45 PM
    eledobleu
    Orlando, FL
  14. Aug 22, 2016 at 4:59 PM
    rons23
    Ron
    Kill Devil Hills
  15. Aug 22, 2016 at 5:26 PM
    eledobleu
    Orlando, FL
    Yes but dont worry we are expecting a shipment this week! These Fog lights have been selling like Hot cakes recently! You will be notified once your order has shipped!
  16. Aug 22, 2016 at 5:29 PM
    eledobleu
    Orlando, FL
    No problem buddy! If you have any questions feel free to ask!
  17. Aug 22, 2016 at 5:32 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Let us know when first gen lights are available;)
  18. Aug 22, 2016 at 5:35 PM
    eledobleu
    Orlando, FL
    Will do buddy!
  19. Aug 22, 2016 at 5:37 PM
    rons23
    Ron
    Kill Devil Hills
    So these fog lights are plug n play, no resistors or extra wiring. Just remove factory lights and plug new ones in factory plug?
  20. Aug 22, 2016 at 5:48 PM
    eledobleu
    Orlando, FL
    Yes sir that is correct! No resistors, no extra wiring. Just a simple swap! That + its performance is why people love the Xb LED fog light series
  21. Aug 22, 2016 at 5:51 PM
    rons23
    Ron
    Kill Devil Hills
    What's your thoughts on the difference between color temp. I have 6500k in my hid projectors, just want them to blend, am I making sense
  22. Aug 22, 2016 at 5:56 PM
    eledobleu
    Orlando, FL
    These are a pure white lights. Your 65k HID's will be definitely be more blue. A perfect match for these are 5k or morimotos 55k. Though most people wont be able to tell the difference, you will for sure! Thats if your looking at your truck.
    As far as light on the road, you wont be able to tell a difference. The light output wont be much different when it hits the road.
  23. Aug 22, 2016 at 5:59 PM
    rons23
    Ron
    Kill Devil Hills
    Oh ok, I think there 6000k, anyway thanks. Are you doing group buy, or is it just member discount. Just curious
  24. Aug 22, 2016 at 6:07 PM
    eledobleu
    Orlando, FL
    Just a member discount. There will more than likely be a group buy soon!
  25. Aug 22, 2016 at 6:10 PM
    rons23
    Ron
    Kill Devil Hills
    Thanks eledobleu, these will be on my list fo sho
  26. Aug 22, 2016 at 8:29 PM
    ToyotaTundraMike
    2015 Tundra
    If my truck didnt come with fogs originally (SR package), what would it take to install these?
  27. Aug 23, 2016 at 8:04 AM
    eledobleu
    Orlando, FL
    You would need to convert your truck accept the OEM fogs, Or extend the power and ground wires on the fog lights and tap into your headlights or parking light or via switch.
  28. Aug 23, 2016 at 8:26 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Did the price on these just got up $10. Pretty sure they where $160 the other day, humm.. Maybe I'm thinking of something else I was looking at.
  29. Aug 23, 2016 at 8:29 AM
    eledobleu
    Orlando, FL
    Yes the price has increased to $170. I had to make changes based on my supplier polices. Because of this the discount has increased from 5% to 10% to make up for the $10 increase.
  30. Aug 23, 2016 at 8:31 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    That was my next question, I thought it was only 5% before. Awesome, Thanks. I'm on the verge of picking this up. Trying to prioritize my mod needs/wants, ha.
