Morimoto fog light help
Discussion in 'Lighting' started by WatTundra, Sep 30, 2016.
  1. Sep 30, 2016 at 5:12 PM
    WatTundra
    WatTundra [OP] New Member
    Kenny
    FTW, TX
    2016 MGM Tundra
    Stock as a rock minus tint
    So I took advantage of the 10% off buy and now getting around to installing them and I have a question. Is it possible to plug in the wires backwards? I turned on the lights and nothing so I grabbed the other fog light and it works when I plug it in.
  2. Sep 30, 2016 at 5:15 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    If so, is there a way of removing them and resetting?
  3. Sep 30, 2016 at 5:19 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    I can't get them to budge
  4. Sep 30, 2016 at 5:25 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    I wonder if the little black "clips" need to move to remove? Be back later, time to mess with everything
  5. Sep 30, 2016 at 5:32 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    I'm thinking I have the positive and negative swapped. The blades are seated just as far as the "good" one. Hopefully it's that they need to be swapped and not a bad light.
    It's getting to dark to finish tonight but I'll continue with the install tomorrow but I'm taking the "bad" light inside to try and get the wires switched.
    Thank you Ron!
  6. Sep 30, 2016 at 5:36 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Sounds about right. They are a bit of a pain to get back out, but you will be able to get them out to switch them. Good luck.
  7. Sep 30, 2016 at 5:54 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    The same thing happened to me when I did the install one worked and one didn't.
    The one that didn't work, I had the positive with negative when I plugged it in, and u can't just turn it around cause there's only one side that locks in when u plugged them together lol. So I had to remove does little metal connectors by moving back does little black clips deep inside and pushing down on does metal connectors and switch them sides, that's all I did and it worked. Good luck hope it works out for you.
    WatTundra[QUOTED][OP] likes this.
  8. Sep 30, 2016 at 6:37 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    It did work! Got it switched around and I'll do the install tomorrow!
    Another question, does it really only install with 1 screw? It just doesn't fit like factory. Sr5trdtundra how do you like yours?
  9. Sep 30, 2016 at 6:44 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    I love mine! Brighter than my headlights lol. And yes just one screw, it sucks cause someone can just come along and pop out the fog light disconnect and take it that easy. The stock ones where tighter cause of the connection in the back.
    WatTundra[OP] likes this.
  10. Sep 30, 2016 at 6:47 PM
    WatTundra
    Kenny
    FTW, TX
    2016 MGM Tundra
    Excellent news on the output but meh news on fitment. Cannot wait to see the difference! How easy or hard was it to adjust the light line once installed?
  11. Sep 30, 2016 at 6:54 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Pretty easy as they just pop out and the slack of the wires give you lots of room to screw in the adjustment, and ofcourse I used the wall in the garage.
    Great lights!
  12. Sep 30, 2016 at 7:04 PM
    5.7Literdreamer
    5.7Literdreamer New Member
    Brooks
    2011 4.6l. Procomp lift with 20" XD series Rockstars. I have the amp step boards wich I love. Bone stcok motor, K&N drop in filter.
    Did you get the relay form Toyota?
  13. Sep 30, 2016 at 7:27 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Relay? It's totally plug and play.
