Morel / JL Audio build Question on 3rd gen
Discussion in 'Audio & Video' started by tanabersx, May 31, 2018.
  1. May 31, 2018 at 11:05 AM
    tanabersx
    tanabersx [OP] New Member
    Miguel
    Puerto Rico
    2017 Tundra DC SR5 XP
    So, here is my build: 2017 DC
    - Morel Tempo Ultra 602 Components Front/Rear
    - JL Stealthbox
    - JL Fix 86 sound procesor
    - JL VX1000/5i 5 channel amp w/ DSP
    - A couple of other things like sound deadening, sail panels, remote, harness, etc. etc.
    The question is, Will I be able to fit the Fix 86 and amp under passenger seat? The amp is about 12x3x7". Any suggestions/pics on amp and Fix 86 placement.
    THANKS!!
  2. May 31, 2018 at 11:55 AM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
  3. May 31, 2018 at 11:55 AM
    Beerdude77
    Oh and buenas!
  4. May 31, 2018 at 12:33 PM
    tanabersx
    Miguel
    Puerto Rico
    Thanks!! I'll be buying one of those. Maybe I can make both fit with some mods.
  5. May 31, 2018 at 12:52 PM
    Beerdude77
  6. May 31, 2018 at 1:12 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Why are you running the fix86 and the VX? You should be fine with the Fix and a regular 5 channel amp. Or if you want more tweakability, add the twk.
    My build has some pictures of what it looks like with the front passenger seat out. Link is in my signature.
  7. May 31, 2018 at 1:21 PM
    Beerdude77
    Good catch @Danimal86 I hadn't even noticed that amp has a DSP in it already. He may not even need the TWK as it appears you can make the same adjustments in the amp via the JL TUN software.
  8. May 31, 2018 at 3:06 PM
    tanabersx
    Miguel
    Puerto Rico
    Thats right!! The VX has the TWK software in it but still need the FiX to do the signal processing. The FiX has some tunning options but not as extensive as the VX/ TWK software.
    chefhow likes this.
