More Wheel/Less Tire Vs. More Tire/less Wheel
Discussion in 'Wheels & Tires' started by l3LUEFALCON, Oct 9, 2018.
  1. Oct 9, 2018 at 3:36 AM
    l3LUEFALCON
    l3LUEFALCON [OP] RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
    What puts more stress on the transmission?
    More Wheel/Less Tire or More Tire/less Wheel combination of the same diameter.
    Example (Take with a grain of salt)
    lets just say they were exactly the same diameter.
    dcsleeper408 likes this.
  2. Oct 9, 2018 at 3:50 AM
    PermaFrostTRD
    Northern NY
    I have no idea, but if I were to guess I’d lean towards less weight of the wheel tire combo being better for the tranny. All other things being equal. Hopefully someone with some actual knowledge will chime in.
  3. Oct 9, 2018 at 5:20 AM
    trdprobped17
    trdprobped17 New Member
    Both! Less tire with more wheel isn’t the best thing for pickup trucks. Especially, if you go low profile tires. You will feel everything....it may even knock out the fillings in your teeth:). On the other hand, the more tire that you have, is the more cushioning for your wheels and truck.
  4. Oct 9, 2018 at 5:35 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Unsprung weight is the enemy of your power-train and ESPECIALLY braking system, it also impacts suspension damping and steering. The heavier the wheel/tire combo, the harder everything has to work. Harder to get stuff moving and or responding, then when it does, it's a real bear to stop it.
    So, generally speaking, a larger wheel will have more weight than a smaller one of the same construction/material. That's a general statement until you start getting into exotic materials.
    l3LUEFALCON[OP] and Rex Kramer like this.
  5. Oct 9, 2018 at 4:51 PM
    l3LUEFALCON
    Josh
    North Houston Area
    IDK either. I wish I listened more in physics class. But your response sounds reasonable @Jengel451.
  6. Oct 9, 2018 at 4:53 PM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Me personally like more tire less wheel.
    equin and dcsleeper408 like this.
  7. Oct 9, 2018 at 4:59 PM
    Jengel451
    The Bitterroot, MT
    And I think I went into the weeds a bit. Final answer is lighter is better. So the answer really has to do with tire and wheel construction, weigh the combo of each size and youll have your answer.
