More Tundra Brake Issues
Discussion in '2nd Gen Tundras (2007-2013)' started by CarGal48, Jun 23, 2025 at 2:16 PM.
  1. Jun 23, 2025 at 2:16 PM
    CarGal48
    CarGal48 [OP] New Member
    Yesterday
    2012 Silver Tundra
    None
    Hi Tundra folks! I’m new here and hoping someone can help me diagnose my brake issues. I’ve been dealing with the “warped” rotors issue for about 3 brake changes now. I finally landed on the calipers not fully releasing and heating up the rotors but that does not seem to be the case. This time I replaced both front calipers, rotors and pads. I literally drove it out of the garage and tested it on a hill on a nearby highway and the vibrating had not changed at all. I’ve literally checked steering linkage, tires, tow in, alignment and done a full replacement and it’s still god-awful. I even tried a couple power slides in the grass just in case something is stuck in the ABS unit. I mean why not?! I’m to the point of burning sage and calling on the spirits of my dead ancestors. Anyone got any ideas?
  2. Jun 23, 2025 at 4:55 PM
    Tundrasam97
    Tundrasam97 New Member
    Sam
    Qc, Canada
    2010 black tundra SR5 DCSB 3ur-fe
    Bilstein 5100
    A dial indicator would show you if you have any runout on the hub face. My guess would be:
    -bent hub
    -bad wheel bearing
    -uneven hub/rotor mating surface ie. Rust flakes
  3. Jun 23, 2025 at 6:48 PM
    1794Rookie
    1794Rookie New Member
    Friday
    White 2017 1794 Edition
    Stock
    I feel for you. I hope it gets figured out. I have a little vibration, I hope it’s not that.
  4. Jun 23, 2025 at 8:36 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Do you have aftermarket wheels?
    Have you had the wheels/tires balanced?
  5. Jun 23, 2025 at 8:46 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I second the hub
  6. Jun 23, 2025 at 8:46 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    I would have the rotors put on a lathe to check for whether they are true.
    I have seen new rotors, and drums be off.
    Not saying that's your issue, but is a possibility.
  7. Jun 23, 2025 at 10:00 PM
    blenton
    blenton New Member
    I agree with all of the above.
    - What brand rotors are you using - Toyota OE or aftermarket?
    - Do you have aftermarket wheels?
    - How do your tires look - any excessive or abnormal wear?
    - How are your tie rods?
    - How is your alignment? When was the last time it was aligned?
    - How many miles on the truck?
    - Have the hubs/wheel bearings ever been changed?
    - What are your lug nuts torqued to?
    IME, "warped" rotors are rarely actually warped. If you pulled out of the garage and immediately had the same shimmy and shake issue, it's not warped rotors. It's something else as has been suggested above.
    I've got over 250k miles on factory rotors, with lots of hills, towing, and hauling. The only time I had an issue with the brakes is when the tire jockey went whole hog and ran down the lugs to well over 600 lb-ft, destroying the lugs and my rotors. I had to cold chisel the stainless steel cover off the lug nuts just to remove the wheels. So besides that, I've only changed the rotors once with another set of Toyota OE rotors from the dealership.
    I'm saying the factory brakes are quite good. Aftermarket parts on the other hand... can be hit or miss. But immediately after changing rotors, pads, and calipers - you are barking up the wrong tree. I would suggested looking elsewhere for the issue.
  8. Jun 24, 2025 at 6:05 AM
    CarGal48
    Yesterday
    2012 Silver Tundra
    None
    Thanks folks! Wheels are factory. Tires have been balanced and wear is good. I rotate regularly. I buy high-end replacement parts not cheap junk but I’m aware parts these days are not what they once were. I have checked runout. The only things I have not checked is to see if there is rust on the hubs and torque on lug nuts. It’s definitely not too much torque. But it looks like it’s supposed to be 97lbs-ft. I think I’m hitting 80. I’m not sure that’s enough to make this big of an impact. But we’ll see… Stay tuned folks!!
  9. Jun 24, 2025 at 7:54 AM
    Dr_Al
    Dr_Al New Member
    Al
    I had to take a grinder to the ends of the brake pads on my Tundra. I don't know if they were OEM or aftermarket but they were rubbing on the calipers. At first it was wheel hop but as it got worse it started getting hard to brake. At first I assumed it was from the rotors getting rusty (it sits for long periods of time) but I finally figured it out. A few seconds with an angle grinder and now the pads slide into the calipers with just a bit of play. Both the brake hop and the hard braking are a thing of the past.
    1794Rookie likes this.
