More surprise "minor" omissions...
Discussion in '3rd Gen Tundras (2022+)' started by raylo, Feb 12, 2023.
  1. Feb 12, 2023 at 6:17 AM
    raylo
    raylo [OP] not so new member
    Frederick, MD
    I was just over in another thread praising Toyota for resale and build quality. But to be fair I have to complain again about some of their cheesy omissions. First was the lack of seat memory function even though I have the fancier 8-way softex seats, Advanced Off-road tech and all that. The latest issue I have discovered is lack of retained accessory power, even though I have the aforementioned AOR tech package and "premium audio" and a bunch of other options. I haven't had a vehicle without RAP for 30 years. This is not even remotely an option that I would go looking for since I would have just assumed it was standard. I am guessing that upper trims have this? So one would have to buy an upper trim to get a couple of relays and a timer board? LOL.
    This is just a heads up for buyers who like me find that the SR5 trim can be pretty well optioned but will still apparently lack a couple of minor conveniences that many of us have become accustomed to.
  2. Feb 12, 2023 at 6:24 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    An example of RAP is the ability to close your windows after the drivers key is turned off. I don’t have a 2023, but Toyota usually disables the function as soon as a door is opened.
    GODZILLA and Keon like this.
  3. Feb 12, 2023 at 6:46 AM
    raylo
    Frederick, MD
    Exactly. It also lets you shut the engine off and keep listening to the radio until you open the door to exit. Without RAP the radio shuts down and you have to manually go back into ACC mode. So if you pull into the driveway with something that you want to hear playing, let it idle until you are done.
    Also, to be fair, being winter I have not tried to roll a window up after killing the engine. I'll try that later today.
  4. Feb 12, 2023 at 7:14 AM
    DeafJam
    DeafJam New Member
    Louisiana
    2023 Toyota Tundra Hybrid, 1794 edition
    Cosmetics for for a pavement princess.
    I don’t think I’ve had a car in the last ten years that has had this. Three Toyotas and two BMWs. Anything older I cannot speak to as I don’t remember.
    The upper trims do not have this either as I believe my windows perform the same on my 1794.
    This is a design philosophy decision from a battery preservation and operations / safety perspective as it cost nothing to implement the opposite.
    raylo[OP] likes this.
  5. Feb 12, 2023 at 7:25 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    3 GM’s - a 15 Canyon, 11 Cruze and 14 Encore had it
    16 Subaru does not
    1st world problem
  6. Feb 12, 2023 at 7:45 AM
    raylo
    Frederick, MD
    Exactly. I was just looking at other Toyota RAP discussions and it seems this is a Toyota design "philosophy" as Jam noted. Another head scratcher, but oh, well.
  7. Feb 12, 2023 at 7:49 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    My 22 SR5 I can roll down windows for a period after turn it off. Have not tried radio. I don't really care about that
  8. Feb 12, 2023 at 8:07 AM
    raylo
    Frederick, MD
    Radio shuts off instantly.
  9. Feb 12, 2023 at 8:19 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    I believe you can shift the truck to N and then turn the truck off and still listen to the radio? At least my wife's 2021 Highlander is that way. Try it?? Just remember to put it back in park when you exit lol. I think the vehicle will remind you tho
    GODZILLA likes this.
  10. Feb 12, 2023 at 12:32 PM
    mountainpete
    Have you tried turning the radio back on again after the engine is shut off, but the door is still closed?
  11. Feb 12, 2023 at 7:43 PM
    22whatwedo
    The Open Road
    Trying to remember what my 2002 Tacoma did
    Coasty likes this.
  12. Feb 12, 2023 at 7:47 PM
    Put it in neutral when you shut it off instead of park. No toyota keeps power when shut down in park. It's not on higher trims. This is known and you should have done more research instead of assuming things you like are standard. As for seat memory, you bought an SR5. That's a step above base, and seat memory is and always has been a luxury trim feature. You should have bought a higher trim or a different brand.
    Gene5253 likes this.
  13. Feb 13, 2023 at 9:02 AM
    nodak67
    nodak67 New Member
    JR
    this goes way back to even my 2014 4runner limited with PTS.
    but then again this inherent to all toyota push to start vehicles.
    and PT barnum strikes again on someone, guess someone should have researched a tad more :)
    *not directed at the person i quoted
    GODZILLA[QUOTED] likes this.
