More Sump Woes
Discussion in 'Home Improvement' started by Outbound, Nov 28, 2019.
  1. Nov 28, 2019 at 10:08 AM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    I never got a chance to fully address drainage for my sump as mentioned in a thread earlier this year. So now I've disconnected my sump discharge hose for the winter due to it freezing up. However, now my discharge outlet is dumping a few gallonsnor more of water per day right next to the house.The Woman noticed this today, along the basement wall near the sump outlet.
    Obviously I need to direct the water flow farther away from my foundation. My neighbour's house is about 15ft from my outlet. Ideally I would direct the water farther out and down the lawn where my hose goes in summer. The problem I'm worried about is freezing, temps drop to -40C here at times. I'm thinking of using some downspout material and running it out down the yard. Ground is currently frozen under snow, so new digging isn't possible.
    Suggestions?
  2. Nov 28, 2019 at 12:43 PM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    If you could dig a French drain it would be one of your better options.
    If you press with your plan, running some heat tape and insulating the drain would help a bit. Google heat tape for pipes. There are quite a few options and styles.
    MS22 likes this.
  3. Nov 28, 2019 at 12:53 PM
    koditten
    Kirk
    Midland of the Mitten
    Do you have city sewer? I know it's not allowed, but if there was no choice, I'd chance it to save my foundation.
  4. Nov 28, 2019 at 3:38 PM
    Outbound
    Aaron
    Northern Alberta
    A french drain is my primary plan, but wasn't able to get to it before the temps dropped and the snow flew. It'll have to be a spring time project now. I ended up grabbing some 2" PVC pipe and running it out away from the house. Hopefully the straight run and larger diameter will prevent freeze up. I'll have to check it daily though.
  5. Nov 28, 2019 at 5:23 PM
    Outbound
    Aaron
    Northern Alberta
    Well, good thing i checked the sump out. Looks like the pump failed. Now to figure out how to swap a pump out under freezing water.
  6. Nov 28, 2019 at 5:28 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    That sucks! But maybe the pump is “froze up” because the frozen water?
  7. Nov 28, 2019 at 5:49 PM
    Outbound
    Aaron
    Northern Alberta
    Doesn't seem like it. The water is "freezing" cold, not actually ice. It's cold enough my hand and arm are numb after sticking them down there though...
  8. Nov 30, 2019 at 9:38 AM
    Ps3udonymous
    I'd say get that water out of there first. Bucket, shop vac, anything. Then work on the pump.
    FrenchToasty likes this.
  9. Nov 30, 2019 at 10:45 AM
    Outbound
    Aaron
    Northern Alberta
    There was way too much water in there I sucked. 20 gallons out with my shop vac and the level didn't drop at all. Ended up cutting the pipe and installing a coupler above the water line and then running the vertical pipe down to the new pump. The new pump was running constantly for about 3 hours getting all that water out. It's all back to normal now.
    Next I get to replace a wax seal on one of my toilets that we noticed was leaking...
    Boosted4runner and FrenchToasty like this.
  10. Nov 30, 2019 at 11:23 AM
    Adam New Member
    the joys of home ownership.
  11. Nov 30, 2019 at 4:04 PM
    Outbound
    Aaron
    Northern Alberta
    Yup. Still better than renting.
    Boosted4runner, landphil and Wsteven like this.
  12. Dec 13, 2019 at 9:48 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Holy shit!!!
    Did you get this figured out?!
    Crossing my fingers for ya!
    Outbound[QUOTED][OP] likes this.
  13. Dec 13, 2019 at 10:20 PM
    Outbound
    Aaron
    Northern Alberta
    Yeah, the new pump is working and everything is back to normal. I picked up a sump alarm as well so an alarm will sound and I'll get a notification on my phone next time the water gets too high. Definitely need to install a second pump though just to cover my bases, so I'll deal with that in spring.
    The leaking toilet wasn't the toilet at all. It was the vent line that runs up the inside of the wall out to the roof I think. No attic access to it and no way to trace it back without tearing walls apart. Most likely condensation but yet another thing to figure out in spring. Got cloths packed around where the water was dripping out so that's controlled now.
  14. Dec 13, 2019 at 10:41 PM
    Boosted4runner
    WA
    Awesome you have the new pump in and all is well! Good call on the alarm. Our septic has one.
    I’m sure this doesn’t pertain to ya, but I had a vent pipe that ran through an exterior wall and drained outside from my tankless hot water heater. It froze up from cold temperatures, which clogged the pipe, and then forced the water out of a seep hole on the tankless heater. I had water on an inside wall, and all over the floor under the tankless unit.
    I ended up insulating the vent pipe and then projecting it from the wind, which stopped the line from clogging and freezing.
  15. Dec 14, 2019 at 8:36 AM
    Outbound
    Aaron
    Northern Alberta
    We have a tankless heater as well, but this pipe doesn't connect to it. It conects into the drain line from my kitchen sink. It's a 3" pipe too. I'm going to have to climb up on the roof in spring and see where it exits the house. Due to our yard shape and the height of the house, I can't see anything from ground level.
  16. Dec 14, 2019 at 9:54 AM
    Twinky
    07 double cab work horse
    I guess there's no way to tell if a previous owner tied into that vent incorrectly?
  17. Dec 14, 2019 at 10:08 AM
    Outbound
    Aaron
    Northern Alberta
    Not really. I can't get to the point in the attic where the pipe comes up. Other than opening up a wall, there's not much to be done. The only tie in visible is the vent into the drain line. This house is only 6 years old as well, and based on what I know of the previous owners they weren't really the mod/diy types.
    My brother is a plumber and he said that since it only started dripping when the weather got cold is that it's most likely condensation or snow getting in from where the vent exits out on the roof. When he comes up to visit in spring, he'll have a look and might be able to scope it with a camera or something.
  18. Dec 14, 2019 at 10:51 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Every time I've seen a leak (granted not many) it was the boot around the vent on the roof.
    Twinky likes this.
  19. Dec 14, 2019 at 11:59 AM
    Twinky
    Yeah a 6 year old house should be up to code. Water issues definitely can be tough to figure out or address.
    I personally don't come across that type of construction in my area. Not a lot of basements.
