Moonroof Won't Open
Discussion in 'Electrical' started by pcdoctor911, Jun 25, 2024.
  1. Jun 25, 2024 at 9:33 PM
    pcdoctor911
    pcdoctor911 [OP] New Member
    Ron
    2015 Black Tundra Crewmax Limited TRD
    Hi All,
    My 2015 Tundra moonroof won't open. I hear 2 clicks when I press the switch but that's it. I don't know if there's a manual way to open and close it so I'm hesitant to play around with it too much as it's rainy season here in Florida and I don't want it to get stuck in the open position.
    Any help would be greatly appreciated.
    Thanks
  2. Jun 26, 2024 at 5:07 AM
    ljburns
    ljburns New Member
    I had this happen a few weeks ago in a 2014. There are some videos on how to clean the motor. It is located behind the cab light by the windshield. I think I found the how to on this forum. Pretty easy. Took about 10 minutes from start to finish. Make sure to have a can of electrical contact or MAF cleaner handy.
    Edit: actually, my problem was that the sunroof opened but would not close. Cleaning the motor fixed that problem.
  3. Jun 26, 2024 at 6:37 AM
    pcdoctor911
    Ron
    Thanks for your reply Ijburns Even though I do hear 2 clicks when I press the switch I thought that it would make sense to check the fuse first, but I can't figure out which fuse it is from the labeling.
  4. Jun 26, 2024 at 6:40 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Take a peek in your owner's manual; there are instructions within it for a reset procedure whenever you are experiencing issues w/functionality.
  5. Jun 26, 2024 at 6:57 AM
    pcdoctor911
    Ron
    Never mind. Found the fuse. All it took was putting on my glasses and reading the label on the first fuse.
  6. Jun 26, 2024 at 7:36 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    DId replacing the fuse fix it?
  7. Jun 26, 2024 at 12:41 PM
    pcdoctor911
    Ron
    Thanks Trpleconpanna. Did try the reset option. Didn't work.
    Thanks for checking in 1lowlife. Wife took the truck to pick up a friend at the airport. Won't know till tomorrow, and only if the back is feeling up to contorting under the dash.
