Moog Greasable Camber/Caster Kit?
Discussion in '2.5 Gen Tundras (2014-2021)' started by buckrub71, Jun 24, 2020.
  1. Jun 24, 2020 at 3:34 PM
    buckrub71
    buckrub71 [OP] Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    Hey fellow forum members. I am getting ready to install replacement LCAs on my 16 1794. Have any of you used or have firsthand feedback on the Moog greasable camber/caster kit ( MOOG K100381 Caster/Camber Kit)? I am down to these or SPC (non-greasable). I haven't found feedback for Tundras but have seen some mixed reviews for other vehicles. Thanks for any help you can provide!
    BUGEATER likes this.
  2. Jun 24, 2020 at 4:26 PM
    Vizsla
    Vizsla 2 = 2.5
    Neither one of those can hold the factory torque spec of 207 ft lbs, and if less they don't hold alignment. SPC is 150 ft lbs iirc, can’t find Moog but it’s gonna be low. Stock bolts and anti seize are good to go.
  3. Jun 24, 2020 at 4:49 PM
    buckrub71
    2016 Bronze 1794 CM
    Thanks. I'm just a bit confused though. The data sheet I have for SPC (see below) shows one of the bolts torque at 227. I'm really more curious about the Moog.20200624_194627.jpg
  4. May 3, 2023 at 5:17 AM
    lukedias00
    lukedias00 New Member
    2014 Tundra 4x4 Off-Road Limited
    What did you end up doing? Doesn't seem like moog would make a part that doesn't meet torque spec, especially with how beefy that bolt is.
