Mood/Ambient Lighting
Discussion in '3rd Gen Tundras (2022+)' started by KDavenport, Sep 6, 2025 at 1:51 PM.
  1. Sep 6, 2025 at 1:51 PM
    KDavenport
    KDavenport [OP] New Member
    Saturday
    2022 Platinum. Wanting to install mood/ambient lighting on doors and dash. The truck is set up for it but no lights. I figured out the dash connections, but having difficulty with doors. I see two wires that are not connected on the inner door. Would these be the wires needed for the lighting? I bought Rave Ambient light kit.
  2. Sep 6, 2025 at 11:25 PM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    We gotsta know! :popcorn:
    Leo's first likes this.
  3. Sep 7, 2025 at 6:41 AM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Did you watch their install video? It's pretty detailed
    KDavenport[OP] likes this.
  4. Sep 7, 2025 at 7:13 AM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    If OP owns a 22 Platinum, you simply press your MOOD button on your overhead console.
    Done and no install needed.
  5. Sep 7, 2025 at 8:11 AM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    And also uses the wrong connections.... Double check before you commit to connecting. Their front door pinout instructions don't dim properly. Their rear door color are correct. Also, the passenger dash trim they want you to use double sided tape to install, the better method is to mimic OEM buy cutting holes into the 2 dash panel tabs to snap the light into (OEM does 4, but trucks that don't come with oem lighting only have 2 usable tabs. Its more than plenty secure this way)
  6. Sep 7, 2025 at 9:39 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Ha…I was thinking the same thing. If it’s a Platinum you already have the lighting
  7. Sep 7, 2025 at 9:42 AM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    As a Platinum owner, I don't think it could get any more moody in the cabin. There are lights everywhere haha
  8. Sep 7, 2025 at 4:24 PM
    KDavenport
    Saturday
    Update. Lights are installed. It looks like truck previously had ambient lights installed but they were removed by a previous owner. Luckily they left just enough wire to support a new connection. I bought the kit from Rave and they work great. Im glad I am able to control them with the mood button and didn't have to go with the headlight option from the install video. Thanks everyone.
    Tundrastruck91 and Alex261 like this.
  9. Sep 9, 2025 at 8:44 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Apparently wasn't in the 'mood'.
  10. Sep 9, 2025 at 1:41 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    That's what she said!
