Mongo
Discussion in 'Lexus GX Builds' started by Grumpy Uncle, Jul 14, 2021.
  1. Jul 14, 2021 at 6:49 AM
    Grumpy Uncle
    Grumpy Uncle [OP] Pushing string down the hall SSEM #10
    Pat
    CO
    Been meaning to start this for a while now. The Mongo Build Thread.
    Mongo, 2010 GX 460
    When I bought it already had the front and rear bumpers including the winch. It also had the wheels and tires.
    I replaced the front and rear suspension.
    Bumpers
    Coastal Off-road
    Sliders
    Coastal Off-road
    Winch
    9.5k Smitybilt
    Wheels
    Vors
    Tires
    BFG AT KO2 285/70/17
    Front suspension
    OME Nitros
    OME Heavy coils
    SPC UCAs
    Rear suspension
    OME Nitros
    ICON Progressive Overland coils
    Rokmen UCAs
    Rokmen LCAs
    Rokmen panhard bar
    Treaty Oak KDSS Spacers
    Maintenance:
    HID ballasts replaced
    HID bulbs replaced
    Hi beams replaced with LED bulbs
    Spark plugs
    Rear brakes
    Rack and pinion replaced because it had blown seals
    A/C high pressure line because a hole had rubbed into it from the front bumper.
    Started to put rust reformer on the undercarriage. Then treating with fluid film.
    Upcoming Maintenance
    Front output seal on transfercase
    Fluid replacement in transmission- Done, made a world of difference.
    Things to come
    4.56 or 4.88 gears. Installed Yukons on 11182022. Thanks to Hefty Fabworks
    Eaton locker. Installed on 11182022. Thanks to Hefty Fabworks
    34" tires
    Full skid plates
    Additional lights
    MTS Module. Done
    Update:
    Running 34s now, 285/75/17, Toyo RT Trails
    Full RCI skids
    Magnaflow overland exhaust.
    An unmentioned roof rack, price too good to pass up at the time.
  2. Jul 14, 2021 at 7:01 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Awesome! Gonna have to get some pics in here at some point.
  3. Jul 14, 2021 at 7:03 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  4. Jul 14, 2021 at 7:45 AM
    Grumpy Uncle
    Pat
    CO
    That'll happen maybe this evening.
  5. Jul 14, 2021 at 7:49 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  6. Jul 14, 2021 at 9:41 AM
    Grumpy Uncle
    Pat
    CO
  7. Jul 14, 2021 at 10:44 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Darkness likes this.
  8. Jul 14, 2021 at 2:31 PM
    Grumpy Uncle
    Pat
    CO
  9. Jul 14, 2021 at 2:38 PM
    Grumpy Uncle
    Pat
    CO
  10. Jul 14, 2021 at 3:00 PM
  11. Jul 14, 2021 at 3:09 PM
    TheBeast The Beach
    very nice ! how many miles on it ?
  12. Jul 14, 2021 at 3:13 PM
    Grumpy Uncle
    Pat
    CO
    When I got it last year it had 117k miles and some change. It has around 124k miles now.
    jewsNbrews and TheBeast[QUOTED] like this.
  13. Jul 15, 2021 at 5:21 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    :eek2::bananadead:
  14. Jul 15, 2021 at 6:01 AM
    Grumpy Uncle
    Pat
    CO
    Had to post that one...
    Fotnot[QUOTED] likes this.
  15. Jul 15, 2021 at 6:05 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    :yes::fistbump:
  16. Jul 20, 2021 at 7:01 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Mine is not quite manly enough yet. But she is a goat. :oops:
    going to do the Alpine loop sometime this week and then Black Bear before I go home. 8AF970B8-5931-4FD9-81C3-4FBB63E37109.jpg
    Wallygator, Hightide, equin and 4 others like this.
  17. Jul 20, 2021 at 7:10 AM
    Grumpy Uncle
    Pat
    CO
    Nice
    I haven't done those yet. Make sure you are in lo range going down hill. These things are heavy! My brakes got really hot on this last trip. Even in S1 and S2 I couldn't get the right ratio on the downhills. Had to put the transfer case into lo a couple of times. This last trip was the only time I had to use the brakes as much as I did.
    Once I regear I should be good to go.
    jewsNbrews likes this.
  18. Jul 20, 2021 at 7:19 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I ran in 4lo all the time. Not a fan of listening to DAC either as it sounds like a bunch of dildos in a dryer.
    I did Ophir Pass from Ophir to 550, had lunch in silverton, then went to Animas Forks and out California Pass.
    I had my 90yo Mother with me so we didn’t do anything crazy.
    Grumpy Uncle[OP] likes this.
  19. Jul 31, 2021 at 6:31 PM
    Grumpy Uncle
    Pat
    CO
    4 cans of rustoleum rust reformer. Now I need to order or find locally some black Fluid Film before winter and the undercarriage will be good to go.
  20. Dec 26, 2021 at 8:58 AM
    Grumpy Uncle
    Pat
    CO
    If I knew then what I know now, HID headlights aren't that great. Then again, maybe this will improve my opinion. Need to replace the HID bulbs, I went with Diode Dynamics. I also need to replace the ballasts, those are on order. I'll be replacing everything thing this coming weekend.
    Fotnot and jewsNbrews like this.
  21. Dec 26, 2021 at 9:34 AM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I have 4.88s in mine and u will still need to put it in 4lo on steep terrain. Shit my tundra has 5.29s and I have to do the same there as well. Otherwise ur gonna burn up the brakes. It’s already happened to me on each vehicle and will not try to do that again. I don’t use the downhill assist cause once it’s in lo there is no need for it.
  22. Nov 19, 2022 at 3:35 PM
    Grumpy Uncle
    Pat
    CO
    4.56 Yukons have been installed and an Eaton E-locker in the rear. Doing the 500 mile break-in, so no fun with it yet.
    Thanks to the guys at Hefty Fabworks. Excellent service, I'll be going back.
    Fotnot likes this.
  23. Nov 19, 2022 at 3:39 PM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
