Money is no object. Choose a rear locker.
Discussion in '1st Gen Tundras (2000-2006)' started by toyoboyo, May 24, 2020.
What would you choose?
  1. Harrop E Locker
    5 vote(s)
    45.5%
  2. ARB air locker
    6 vote(s)
    54.5%
  1. May 24, 2020 at 5:48 PM
    toyoboyo
    toyoboyo [OP] New Member
    Which one would you put on your rear diff, and if you feel like replying explain why.
    theBIGnaud likes this.
  2. May 24, 2020 at 5:56 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I like e-lockers. Just a 12v source and you’re done. No need for compressor or running air lines, etc. Some say there is a lag before engagement with e-lockers but it’s negligible in my opinion.
    Air lockers work great, just not my preference.
  3. May 24, 2020 at 5:58 PM
    toyoboyo
    What's an Aussie locker? Can you point me to the best locker available?
  4. May 24, 2020 at 6:13 PM
    toyoboyo
    :bowdown:
    Thank you for this post. Perhaps the Aussie is not for me then.
    One more thing off-puting about the ARB is that I'm reading stories of some sort of copper wire failure which has me worried.
    This is going on a 2WD Sequoia with a one wheel spinner out back. Need the locker for some loose trails and rough terrain. I nearly got stuck in the smallest and most mundane trench than ran down the side of a trail.
    theBIGnaud[QUOTED] likes this.
  5. May 24, 2020 at 6:45 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    ok, question could you swap out a first gen rear end for a 3rd gen ? My guess is no.
