Monetary switch wiring
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAA96, Apr 20, 2023.
  1. Apr 20, 2023 at 2:59 PM
    AAA96
    AAA96 [OP] New Member
    2020 Tundra 4x4 SR5 CrewMax
    So I purchased an Air on Board momentary switch that I will install next to my “tow” button by the steering wheel. I see that there are 4 wires. (12v power, ground, 12v switched power, and one that goes to the accessory).
    My question is, can I just piggy back off one of the other dash lit switches in the area? Seems to be easy access to 12v constant, and 12 v switched (when lights are on). Or should I run power straight from the battery for the 12v constant?
  2. Apr 20, 2023 at 3:18 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  3. Apr 20, 2023 at 4:10 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    You can tap into any other wire for the 12v switch nearby, the amperage is pretty small. The 12v constant though, depending on what you're running, may be smarter to run it via an add-a-fuse that replaces the accessory fuse. I use that for 12v "constant" (don't need switches activated if the car is off) which powers the relays I have set up in the engine bay
  4. Apr 20, 2023 at 4:34 PM
    AAA96
    thanks for the input. Do you have any recommended sources for an ignition switched on source in the engine bay? This would be for the switched signal to signal the 30amp relay to turn on.
  5. Apr 21, 2023 at 3:13 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
