Moisture behind instrument/guage panel
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigfoot17, May 6, 2025 at 3:52 PM.
  1. May 6, 2025 at 3:52 PM
    bigfoot17
    bigfoot17 [OP] New Member
    2018 SR5
    I just recently got some moisture trap behind the plastic panel for the speedometer, tachometer, etc. It’s a 2018 tundra. What’s the best way to dry it out? Or can it be removed easily?
  2. May 6, 2025 at 5:57 PM
    Yes it can be removed easily. If you look above the gauges you will see 2 push pins that you remove to pull the trim piece out. Don't yank it out as the lower portion of it as attached to a rubber seal on top of the steering column. Once it is out of the way you will see how the lens is attached to the cluster. I don't remember if it's clipped or attached with screws.
