Modified or Towing Mirrors with Marker Lights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jego, Jan 31, 2021.
  1. Jan 31, 2021 at 5:11 PM
    Jego
    Jego [OP] New Member
    Orlando
    PR
    2018 Tundra 1794
    I was going to buy tow mirrors, not necessarily for better visibility, just liked how marker lights looks :). So before to buy it, I decided to modify mirrors by adding side marker lights from Ford F150.
    This is how it looks... What you think? Modified or tow mirrors?
  2. Jan 31, 2021 at 5:13 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Nice job. Looks OEM
    Jego[OP] likes this.
  3. Jan 31, 2021 at 5:16 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I hate it. You should buy towing mirrors and then send those mirrors to me so I can properly dispose of them for you... by installing them on my truck.
    You can keep the chrome caps though.
    Looks pretty good. I’d like to see more details.
  4. Jan 31, 2021 at 5:44 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Thanks!!
  5. Jan 31, 2021 at 5:54 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Also would love to see the install description and can you use white led instead of amber ? Love the hood also
  6. Jan 31, 2021 at 6:14 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    lol!!! Thanks!:)
    I am editing a step by step video with all details. I will upload it during the week!!
    This is the rear/inside view without the lights. Initially I installed smoke style lights but didn't like it at all and ended changing it by clear lights.
    SpeshulED and Saltyhero13 like this.
  7. Jan 31, 2021 at 6:18 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Nice. I'll be interested to know what you used for marker lights, and what circuit you tapped for them. Also, do they provide turn signal blinking like the tow mirrors do?
  8. Jan 31, 2021 at 6:20 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
  9. Jan 31, 2021 at 6:28 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    I tapped tailgate circuit using a fuse tap adapter. This lights are OEM mirror lights for Ford F-150. I installed it as marker lights only no signal. But I will explore that too :). I had to cut 2 small parts from the lights and used 3M glue. Here is the one I have: https://www.ebay.com/itm/AMBER-LED-...150-US/402350513865?ssPageName=STRK:MEBIDX:IT
    I tried smoke lights first but didn't like it.
    RainMan_PNW[QUOTED] likes this.
  10. Jan 31, 2021 at 7:23 PM
    Pins 5 and 6 on the plug for the mirrors are turn signal wires...I looked into this yesterday since I will be installing Muths in the near future.
    saybng and Jego[QUOTED][OP] like this.
  11. Jan 31, 2021 at 7:31 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Muths?
  12. Jan 31, 2021 at 7:37 PM
  13. Jan 31, 2021 at 7:38 PM
    RainMan_PNW
    Casey
    Clark County, WA
  14. Jan 31, 2021 at 7:54 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Thanks! Those mirrors came with my truck :). But I need to figure out how to switch the power source from the tailgate circuit (constant power 12v) to the signal circuit (pulse power). Maybe some logic with a relay NC o NO. To be honest I have to think more about it. All ideas suggestions are welcome :).
  15. Jan 31, 2021 at 7:59 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Hit the wiring diagram post in my signature and pull down the system circuit diagrams for 2021 - they will cover the 2018 and give you the info on the different circuits. The tow mirrors are plug and play for turn signals and marker lights, so the wiring should already be at the truck-side connector in your sail panels.
    Jego[QUOTED][OP] likes this.
  16. Jan 31, 2021 at 8:05 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Thanks!!! I did an old school test using a multimeter to measure all pins while turning ON/OFF lights but none of them worked. After that I decided to tap tailgate circuit from the fuse box. But I am going to double check and validate with your info!! Thank you!! I will let you know! :)
  17. Jan 31, 2021 at 8:16 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    If you don’t need tow mirrors I would stick with your modified ones. Can be tricky to find good looking tow mirrors that keep the BSM and power fold working properly.
  18. Jan 31, 2021 at 8:28 PM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Good point! Thanks!
  19. Jan 31, 2021 at 8:31 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Not so much tricky as just damned expensive!
  20. Feb 6, 2021 at 6:31 AM
    Jego
    Orlando
    PR
    2018 Tundra 1794
    Hello! Here is the link to the video with all details!:)
    https://youtu.be/QAy0z2mdnm0
  21. Feb 10, 2021 at 6:26 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Good job :thumbsup:
