Moaning noise when turning at low speed?
Discussion in 'Suspension' started by TexasYota2019, May 23, 2021.
  1. May 23, 2021 at 4:21 PM
    TexasYota2019
    TexasYota2019 [OP] New Member
    Houston, Texas
    2018 Black Tundra Sr5
    35" Ridge Grapplers 20x10 Fuel Wheels 4.5” fox 2.5 CO Lift
    My friend and I just got done changing out my front coil overs and now when I was driving I turned the wheel at a low speed and braking and it made a loud moan. There’s also a jingle, almost like a tiny bell found in a car collar, coming from the same wheel well. I have a 4” pro comp spacer lift in the front, but I don’t think it’s that. Any ideas on these 2 issues?
  2. May 23, 2021 at 4:40 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Are you sure a front axle didn’t slide out a bit during install?
  3. May 23, 2021 at 5:28 PM
    TexasYota2019
    Houston, Texas
    Would that be the possible moaning? We didn’t undo anything with the axle, we dropped the ball joint and my sway bar link and that’s it. The jingling I found out was the nut on top of the shock not being snug all the way down.
