Mk1 Jetta body swap 1st gen tundra
Discussion in '1st Gen Builds (2000-2006)' started by Rstfree1stgen, Aug 28, 2021.
  1. Aug 28, 2021 at 1:07 PM
    Rstfree1stgen
    Rstfree1stgen [OP] New Member
    2003 tundra SR5
    Camburg UCA cheapy spacer lift and add a leaf. 408k miles
    Yeah you read that right, 1984 Volkswagen Jetta body on a 03 tundra frame.
    The project is still in early stages and I’m one of those plan it as you go kinda guys.
    we will be taking the tundra firewall and floor pan and grafting it to the Jetta body (firewall is rotten anyway) .
    according to measurements we have to shorten the frame 34” to make wheelbase requirements. 469FECD1-1A97-4BFC-A383-1A29D4CF3B4D.jpg
    5072A25B-6F94-4C0E-9972-A051094B6A75.jpg 4D4AA653-734C-4BDA-B52C-BAC8A549A0FD.jpg410D156D-AF05-4F51-9C23-2302C44C9CD6.jpg
  2. Aug 28, 2021 at 1:14 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Sounds... interesting. Maybe you could tell us more about what your objective/goal is?
  3. Aug 28, 2021 at 1:22 PM
    Rstfree1stgen
    2003 tundra SR5
    My main goal is to have something that no one else does. I mean, a 4.7v8 4x4 mk1 Jetta is something I’ve never seen :playball:
    TRDGen, D4x4TRD, thunder100 and 4 others like this.
  4. Aug 29, 2021 at 7:09 PM
    TBinky
    TBinky Wassup weirdos
    2000 black tundra
    I'm excited to see this
    Sunnier likes this.
  5. Aug 31, 2021 at 11:57 AM
    Rstfree1stgen
    2003 tundra SR5
    Today I was messing around at the house and decided to pull the driveshaft, ebrake cables, fuel lines, and as many clips/bolts I could save to use along the journey.
    found some rust spots I plan to touch up on the frame and also measured out where I need to cut to make wheelbase requirements.
    ive decided to cut where toyota slid the frame together and welded the box section together since they only welded the outside I should be able to cut their welds and slide the frame forward (33.5”) and weld it back at the same place up front. We’ll see how that bridge looks when we get there.
    Side note: don’t mind the harness I accidentally cut when we were cutting the cab floor out :oops: it’s getting shortened anyway so it’s fine I guess :(46C592C0-C803-4A4B-A767-4F51D40CAD76.jpg 45FEF31F-C278-4BF6-9571-9D34B2200BBF.jpg A08B4E4C-D6B2-401D-96D1-807E9C912869.jpg C34D0778-F439-4C90-8F41-45BCD03C7E55.jpg 8D8A85E6-84BF-40DE-8691-7D8CD95AFFC1.jpg 05E52623-D0FA-4B67-9F8E-4DD3CA4D1A62.jpg
  6. Aug 31, 2021 at 12:02 PM
    Rstfree1stgen
    2003 tundra SR5
    Somehow need to make this work out mathematically too :ballchain:
    Darkness likes this.
  7. Aug 31, 2021 at 12:14 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Kind of a bummer because mk1 jettas aren't seen often these days but at least its a 4 door.
  8. Aug 31, 2021 at 12:28 PM
    Rstfree1stgen
    2003 tundra SR5
    @Darkness the filler neck hole and rockers are pretty much non existent anymore, there’s also some rot on the front control arms mounts, plus someone tried to RWD swap it and cut the firewall and floor up. So this was the next best option before scrap
  9. Aug 31, 2021 at 12:30 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    Shit! I laughed. Best of luck! Definitely watching this one.
  10. Aug 31, 2021 at 12:31 PM
    Rstfree1stgen
    2003 tundra SR5
    @TrashcanBand I can’t promise it will happen fast but I CAN promise it will most certainly be done.
    TrashcanBand likes this.
  11. Aug 31, 2021 at 12:33 PM
    TrashcanBand
    CenTex
    Tundra
    Can’t rush quality my dude. And this build will have to be quality. :cool:
    Boerseun likes this.
  12. Aug 31, 2021 at 12:38 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats good to hear. Game on sir :hattip:
  13. Aug 31, 2021 at 12:41 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Man, I love old mk1 volkswagens, including the scirocco, rabbit, and of course this jetta. Following this build for sure!!
  14. Aug 31, 2021 at 12:43 PM
    Rstfree1stgen
    2003 tundra SR5
    Also let me clarify I have ZERO engineering knowledge and am really bad at math. But I can turn a wrench pretty good and have been for the last 13 years of my life (I’m only 27) so if you guys were expecting a very technically involved and informed post, this isn’t the one for you o_O but if you like backyard nonsense that hopefully will work stick around :transformer:
  15. Aug 31, 2021 at 12:54 PM
    Mgmtundra
    Mgmtundra MGM Crew
    Nice project, next on the list VW bus pickup on Tundra frame.
  16. Aug 31, 2021 at 1:31 PM
    dgtulsaguy
    dgtulsaguy New Member
    18' 1794
    Nice going man! You're an inspiration to men like us everywhere who drink and stare at sh*t in our yards too long! Should go well with that fine radio flyer power wagon I see back there
    Rstfree1stgen[OP] likes this.
  17. Aug 31, 2021 at 1:39 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This area is such a killer for our frames. It's the only place I had to treat with POR15. I wish Toyota had done something different here.
    @Rstfree1stgen cool idea. I'm excited to follow along on your swap.
  18. Aug 31, 2021 at 2:28 PM
    Rstfree1stgen
    2003 tundra SR5
    @dgtulsaguy you mean this little thing I made up from a taotao 110 and another item destined for the junk yard :cool:
    tossed on a cheap eBay “motorcycle” fairing and glued in an Autozone headlight. Rips up the neighborhood pretty good as long as you have a screwdriver to jump the starter :rolleyes:
    Black Wolf, TRDGen, D4x4TRD and 2 others like this.
  19. Aug 31, 2021 at 2:29 PM
    Rstfree1stgen
    2003 tundra SR5
    @FirstGenVol what’s crazy is here in the rust belt this is the cleanest first gen tundra frame to ever be seen this old. Really wish I was out west and this was a normal frame not a freak of nature
  20. Sep 2, 2021 at 8:32 AM
    Rstfree1stgen
    2003 tundra SR5
    Well it rained like hell yesterday so I couldn’t mess around much, today I figured I’d tackle getting the crossmembers out that I won’t be using, what a chore that turned out to be. Someone never threw any batteries on the charger for the grinder. So half a battery here half a battery there two hours later I got both of them out! Hoping to get my buddy over here tomorrow to help me cut the frame down and weld it back together!
    edit: I finally got two batteries charged which was just enough to get the frame cut and start working on getting the welds off
  21. Sep 2, 2021 at 4:49 PM
    Rstfree1stgen
    2003 tundra SR5
    Ok last post for the day we got the frame shortened and welded!0B7EC8CC-A594-4DCA-8B5B-8323E6AEB6F5.jpg
  22. Sep 2, 2021 at 4:53 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Fuck yes OP. Fuck yes.
  23. Sep 5, 2021 at 11:34 AM
    Rstfree1stgen
    2003 tundra SR5
    Was going to work on the Jetta yesterday but my buddys jeep had other pans for us this weekend
  24. Sep 16, 2021 at 3:26 PM
    Rstfree1stgen
    2003 tundra SR5
    Been so busy with house work and real work I haven’t had time to mess with the Jetta.
    finally got my buddy over to brainstorm and figure out the plan of attack.
    We started cutting the firewall out just over some beers after work.
    Guess there’s more rocker to repair than we thought
    EBD95802-76C0-4B49-9119-A53249D796A9.jpg CB47C9E4-C71D-473D-A579-892317A37C9F.jpg DF6215AE-75DA-430F-9483-C4F165F8CE96.jpg
  25. Sep 16, 2021 at 3:35 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Did you tell him he is supposed to let go of the clutch pedal?
    :rofl:that thing got polished
  26. Sep 16, 2021 at 3:44 PM
    AZTundra
    Paul
    Phoenix, AZ
    Following. This will be interesting. :popcorn:
  27. Sep 16, 2021 at 4:27 PM
    Rstfree1stgen
    2003 tundra SR5
    @Darkness he just got it with 177k and knew it was going to need a clutch. We didn’t expect the disc to fly apart but he did shift really hard at 6800rpm :rofl:
    FrenchToasty and Darkness like this.
  28. Sep 16, 2021 at 4:54 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's fair. I've had similar happen, when you get a stick shift vehicle sometimes the last owner had lazy feet.
  29. Sep 16, 2021 at 5:39 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    The only thing I'm confused by is you're building a trar in the driveway of a suburban neighborhood north of the mason dixon line. :laughing:
    Weld on brother. :D
    Mater, Darkness and Rstfree1stgen[OP] like this.
  30. Sep 16, 2021 at 5:59 PM
    Rstfree1stgen
    2003 tundra SR5
    @Half Assed trust me this neighborhood HATES ME. Im the only house that doesn’t have a quiet and out of the way 50+ year old in it.
    even the younger (30s) people with kids don’t have toys or anything. It baffles me how people can live such a bland life.
    it’s a good week when the cops only show up once for a friends burnout or a quick quad ride around the block. :oldglory::oldglory:
    Wes_heppy, HBTundra, Bikeric and 8 others like this.
