Mixing shock brands?? thoughts
Discussion in 'Suspension' started by wigburner, Jun 3, 2019.
  1. Jun 3, 2019 at 7:17 AM
    wigburner
    wigburner [OP] New Member
    09 double cab 5.7
    i ordered some bitstein 6112 cool overs for the front to give me some lift.
    ordered TC UCA.
    a diff drop kit and 1 inch rear shackles
    but the rear bilstein 5160 are out EVERYWHERE and on a pretty serious back order.
    will to spend some more for other rears.....
    suggestions, tips?
  2. Jun 3, 2019 at 7:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Budget?
  3. Jun 3, 2019 at 7:22 AM
    wigburner
    09 double cab 5.7
    well it would seem silly to put kinds in the rear with bilstein in front but around $600 give or take....
  4. Jun 3, 2019 at 7:33 AM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    I have 6112 up front and OME out back, works great for me on my 2nd Gen
  5. Jun 3, 2019 at 7:47 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think it would be fine honestly. I was running Monroe Quik Struts(I know) with Bilstein 4600's in the rear for a while. Then I switched the rear to ICON's while still running the Monroe's up front for a few weeks.
    I've only heard you should avoid mixing linear vs digressive with the valving. Others have said that even this isn't an issue.
    trayday, Black Wolf and Hbjeff like this.
  6. Jun 3, 2019 at 7:58 AM
    Zero One Actual
    Icon rear shocks. Valved the same as the Billy’s.
    Toytec.
    Myself and several others have Billy’s up front and Icons in the rear.
    Black Wolf and wigburner[OP] like this.
  7. Jun 3, 2019 at 8:00 AM
    wigburner
    09 double cab 5.7
    maybe i should add i have KYB GAS A JUST shocks on now...
  8. Jun 3, 2019 at 8:01 AM
    wigburner
    09 double cab 5.7
    which model? icons
  9. Jun 3, 2019 at 8:02 AM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    You could go with Bilstein 5100s for the rear I believe unless you want the external reservoir.
    JH5370 and Zero One Actual like this.
  10. Jun 3, 2019 at 8:03 AM
    Zero One Actual
    wigburner[QUOTED][OP] likes this.
  11. Jun 3, 2019 at 8:17 AM
    wigburner
    09 double cab 5.7
  12. Jun 3, 2019 at 8:50 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    On the budget the icon is a great choice.
  13. Jun 3, 2019 at 4:31 PM
    Zero One Actual
    That’s what we are here for. I will post pics for you in a few days. I’m currently away from my truck.
    T-Rex266 likes this.
  14. Jun 8, 2019 at 1:40 PM
    Zero One Actual
    Icons going on in the rear. Bilsteins will be at top setting in front.
  15. Jun 8, 2019 at 1:58 PM
    wigburner
    09 double cab 5.7
    with coach builder shackles?
    can you tell me you full set yup and a photo please.
  16. Jun 8, 2019 at 2:16 PM
    mgmcrewmax18
    mgmcrewmax18 New Member
    I went with 6112’s in the front and Toytec Boss shocks in the rear with 1.5” shackles and I’m 100% pleased with it. Truck rides better than stock.
    wigburner[OP] likes this.
  17. Jun 8, 2019 at 3:16 PM
    Zero One Actual
    Bilstein 6112 fronts at top setting.
    Icon rear shocks with reservoir rear.
    Coach builder +3 shackles in rear.
    Cooper ATX 285/75R18 tires.
    SCS Ray 10 18 inch wheels.
    No pic yet because build is ongoing now.
  18. Jun 8, 2019 at 3:38 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I have ADS, King and FOA on my truck. Works well.
    Zero One Actual likes this.
  19. Jun 8, 2019 at 5:51 PM
    ricsha
    ricsha One is none, two is one.
    Rich
    Oregon Coast
    2019 Tundra Limited TRD
    Keep checking availability on the Bilstein 5160's. I have the exact same setup, Bilstein 6112's at 1.3" on the front, CoachBuilder 1" Shackles and Bilstein 5160's on the rear. Just received and not installed yet. I ordered the Bilstein Shocks from Wheeler Engineering here in Oregon, they were backordered until the end of June but they were able to ship on May 28th. Supply may still be spotty, but they are showing up at last!
  20. Jun 8, 2019 at 8:34 PM
    wigburner
    09 double cab 5.7
    +3???
    hmm i got +2....
    how night is the top setting on the 6112's?
  21. Jun 9, 2019 at 3:50 PM
    wigburner
    09 double cab 5.7
    did you use any shims?
  22. Jun 9, 2019 at 4:05 PM
    Zero One Actual
    The top setting on the 6112 and the shins from @Coachbuilder1 put the front right at three inches. The +3 shackles in the rear will even out the rear with the front and I have additional weight in the rear also so I went +3’s to make sure I didn’t have the lower sagging rear.
  23. Jun 9, 2019 at 4:35 PM
    wigburner
    09 double cab 5.7
    sweet!
    thanks for sharing
  24. Jun 9, 2019 at 5:34 PM
    Zero One Actual
    No problem. I’m doing the instal right now and over the next day or two and this thread just happened to be perfectly timed. I will continue to post pics when I get some that will help out.
  25. Jun 9, 2019 at 6:32 PM
    wigburner
    09 double cab 5.7
    i got UCA's
    will they work with the bilstiens 6112s?
  26. Jun 10, 2019 at 3:06 AM
    Zero One Actual
    Yes. Your stock UCAs will work also. I only got some aftermarket ones because I went with the top setting. At the 1.9 setting a lot of guys on this forum do not need aftermarket UCAs because you can still keep a lot of things close to stock. By going to the top setting there is a possibility of having alignment issues. So I am just ensuring everything is done properly.
  27. Jun 14, 2019 at 7:25 AM
    Zero One Actual
    Total chaos UCAs with 6112s and Icons in the rear. 6112s at top setting.
  28. Jun 14, 2019 at 7:49 AM
    wigburner
    09 double cab 5.7
    +2 wasn't enough for top setting.
  29. Jun 18, 2019 at 8:06 PM
    wigburner
    09 double cab 5.7
    it settled down but the spacer on driver side is makes it .5 inch higher than the rest
  30. Jun 28, 2019 at 1:32 PM
    Zero One Actual
    The ride is very comfortable. Coachbuilder +3 shackles in the rear. Icon reservoir shocks in rear. Bilstein 6112 too setting/ two shims driver side. One passenger side. Total chaos UCAs. TRD rear sway bar. Cooper AT3 XLT 285/75/18. No rubbing anywhere. Totally smooth on the highway also.
