Mixing different brands of transmission fluid?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SteyrM40A1, May 11, 2021.
  1. May 11, 2021 at 7:22 AM
    SteyrM40A1
    SteyrM40A1 [OP] New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    Would it be ok if I drained my transmission fluid and replaced what came out with Amsoil ws compatible? I know I won't get every drop out and was wondering if it's ok if the new mixes with some of the old? Thanks.
  2. May 11, 2021 at 8:06 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    A simple drain and refill is only going to replace about 1/3 of the total fluid volume of your transmission.
    I would not use drain and fill to replace ATF WS with another brand fluid regardless of brand marketing that says it's "compatible". But, that's just me. I'm sure it has been tried, and you may receive differing opinions.
    You may even receive some actual positive experience with that approach. :popcorn:
  3. May 11, 2021 at 8:08 AM
    SteyrM40A1
    Gregg
    Ok. Thank you!
  4. May 11, 2021 at 8:22 AM
    JohnLakeman
    If your service duty indicates a need for fluid change (60K? miles), and you want to switch to Amsoil ATF, consider replacing the entire 12-13 quart fill by disconnecting a fluid cooler line, and pumping out/replacing the fluid two quarts at a time. That way, 95 percent of the ATF WS will be replaced with Amsoil at reasonable expense and much less labor.
    There will still be some mixing of the two fluids at the displacement interface, but that's unavoidable if the Amsoil is being used to push out the ATF WS. If the two fluids are even close to compatible, that small amount of contamination will be immaterial.
  5. May 21, 2021 at 9:28 AM
    Zap.Workshop
    Zap.Workshop New Member
    2008 Tundra SR5
    Hi I have a 2008 4.0L V6 2WD tundra, I am having a difficult time locating the fluid cooler line... Can you help me locate it?
  6. May 21, 2021 at 10:32 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
  7. May 21, 2021 at 10:51 AM
    Ebeast
    Ebeast New Member
    2021 Super White Tundra SR5
    Lift Front: Eibach Pro Stage 2 coilovers set at 2.5 Rear: Eibach Shocks. Deavers 3 leaf progressive pack added to stock leafs 1.5 Tires: Falken Wildpeaks AT3 295/70R18 Bed Rack: KB Voodoo High rise bars. RTT: Tuffstuff overland Ranger Tent
    Yeah it will the drain it’s only just a little bit and not the entire amount out of the transmission. you would have to drain all of it and then put in amsoil.
    I’m curious why do you want to use amsoil vs Toyota’s atf ws?
  8. May 21, 2021 at 4:02 PM
    SteyrM40A1
    Gregg
    I was under the impression that amsoil makes a WS compatible tranny fluid. I also read somewhere that amsoils fluid runs about 20 degrees cooler also.
    duerrs likes this.
  9. May 23, 2021 at 5:15 PM
    crewmaxlmt
    scott
    Negative. It is “recommended “ by them. WS is the only truly “compatible” fluid.
  10. May 23, 2021 at 7:24 PM
    Wallygator
    The Amsoil WS is completely compatible with the stock stuff. Call Amsoil to verify if you must but it is compatible.
  11. May 24, 2021 at 8:39 AM
    crewmaxlmt
    scott
    The smarter move is to call Toyota and ask them if they have certified Amsoil transmission fluid as replacement for WS. Well, if you value your warranty anyways.
    There is not any reason for an automotive manufacture to certify an aftermarket supplier for ATF production. It has been this way for decades. Most people don't service their transmission and the ones that do will likely only use ATF 3-5 times over the life of the vehicle.
  12. May 24, 2021 at 10:41 AM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    I belive Amsoil does in fact offer better protection for both hot and cold as it is a 100% synthetic product. The Toyota WS is not. It is also compatible with WS and you will have zero issues mixing. There is also a video on YouTube where someone compared WS and Amsoil Transmission in a -45 degree flow test. The WS wouldn't flow at all, while the Amsoil did...actually quite well!
    I had the dealer do a drain and fill on my 2020 PRO using Amsoil at 25,000. I plan on doing again at around 60,000 and again at 100,000 miles. I may extend the interval after that.
    Following this first drain/fill, shifting was noticeably smoother. Unfortunately, I don't have a scan tool or gauge so I can't compare TQ or pan temps.
    Since the truck does not have a cooler, it gives me piece of mind knowing I am keeping this fluid "fresh", as well as knowing I am using what I believe to be a superior fluid.
  13. May 24, 2021 at 11:03 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Valvoline Full Synthetic...works great...can get @ walmart $17/gal
    not sure of the Amsoil price
    I've used the valvoline for years...4runner, sequoia, LS460L & highlander.
    Rocko9999 likes this.
  14. May 25, 2021 at 8:24 AM
    Wallygator
    Toyota is only going to officially certify non-Toyota fluids. They make money off those fluids.....And mixing in a fluid that is certified WS is not going to void your warranty. That's like saying because you used Mobil 1 0w20 in your engine and not Toyota 0w20 your warranty is voided, that's simply not the case. If the fluid is WS certified it is compatible with the transmission in these trucks and it is compatible with the warranty.
    jordoncloutier and nobodyintexas like this.
  15. May 25, 2021 at 9:17 AM
    Rocko9999
    Rocko9999 New Member
    That the Maxlife? I really like that stuff. Great price too.
  16. May 25, 2021 at 9:38 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes sir. Red jug. It has worked fine for me & mine.
  17. May 25, 2021 at 9:44 AM
    Rocko9999
    Thanks. Did you start off with complete fluid exchange or just drain and refill when you went to Maxlife?
  18. May 25, 2021 at 9:46 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    drain and fill....i do it every other motor oil change.
    heck, I'm down there already...right next to it.
    I'm of the age of maximizing efficiency.
  19. May 25, 2021 at 10:01 AM
    crewmaxlmt
    scott
    Engine oils and transmission fluids are entirely different animals and should not be compared when there is a possibility that your transmission warranty could be denied. Your engine oil is specified to an industry standard and engine oil manufacturer test and certify to that standard. Toyota WS is a proprietary formula manufactured to Toyota's specification. As far as I know, they have not certified any aftermarket ATF manufacturers with the rights to WS. Will other ATFs work, sure. Can your warranty be voided, of course.
    Remember, a synthetic lubricant is not always the "better" fluid. Look no further than synthetic gear lubes and LSD clutches.
  20. May 25, 2021 at 10:15 AM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    I've worked as a technician in a handful of dealers and private repair shops over the past 20 years . Never have I ever seen anyone take an ATF fluid sample from a blown transmission and send it off for analysis before approving warranty repairs . Same with engine oil.
    Your living in a dream world , welcome to real life . WS fluid is mediocre at best . Its made by exxon mobil for toyota , Its a semi synthetic .
    Amsoil , maxlife and other full synthetic aftermarket fluids are an upgrade compared to WS . There is way more evidence out there online backing my statements compared to your weak and unrealistic argument.
    Totmacher, coldcanuk, Joe333x and 2 others like this.
  21. May 25, 2021 at 10:29 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    jordoncloutier HUZZAH!
    I've been watching the precision transmission channel for a couple months.
    of all the units he takes apart...he is an artist!...never mentions what type of fluid.
    don't overthink this shit....use a good Trans fluid and live a little.
    tttrdpro and jordoncloutier like this.
  22. May 25, 2021 at 10:34 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    coldcanuk and jordoncloutier like this.
  23. May 25, 2021 at 10:42 AM
    Wallygator
    Again if it's certified WS it's compatible. You are wrong about the warranty. Well I guess, sure, they could deny the warranty but after the lawsuit they will honor said warranty. Toyota cannot deny any warranty if you use the designated trans fluid for the truck, which is WS.
    jordoncloutier likes this.
  24. May 25, 2021 at 11:45 AM
    crewmaxlmt
    scott
    It is not certified. It is listed as "suitable" by Amsoil. And yes, if I smoke my 2020 transmission with 10K on the truck, I am quite certain that Toyota will perform an oil analysis. Will they deny my warranty if I have fully synthetic Valvoline in it? Not sure, but they did not want to even spend the time looking at my drivers seat that has play in it. Maybe they just really love replacing transmissions and not seats. It's your truck, do what you want. Just do not tell others that Amsoil is certified for WS, it is not.
  25. May 25, 2021 at 12:10 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
  26. May 25, 2021 at 12:27 PM
    jordoncloutier
    Jordon
    Alberta , Canada
    I'll take some of whatever this guy is smokin lol . ☝️
    Joe333x and Wallygator like this.
  27. May 25, 2021 at 12:46 PM
    crewmaxlmt
    scott
    They, as many other do, are playing with words. Where does it say certified? It is recommended, by Amsoil, the manufacturer. Use it if you like, I am sure that is a quality product. I am just saying that it is not certified. Recommended by Amsoil and certified by Toyota are two very different things.
  28. May 25, 2021 at 12:48 PM
    crewmaxlmt
    scott
    I don't smoke but, by judging from your inability to comprehend my statement, I am sure you do; and quite often.
  29. May 25, 2021 at 1:20 PM
    I did a drain and filter swap on the Lexus, 5 qts AMSOIL went in.
    Waiting for the impending doom and gloom.....:anonymous:
    Wallygator and jordoncloutier like this.
  30. May 25, 2021 at 1:22 PM
    duerrs
    duerrs Semper Fi!
    You'll be waiting awhile!! ;)
