Mistakenly filled 6.8 or 6.9 qts during oil change.
Discussion in '1st Gen Tundras (2000-2006)' started by ToyotaJim, Jan 6, 2021.
  1. Jan 6, 2021 at 6:36 PM
    ToyotaJim
    ToyotaJim [OP] New Member
    Doing two oil changes today at the same time.
    Gen 1 Tundra, 4.7 Liter motor, which calls for 6.5 quarts with filter change. It hadn't been run for at least a week so I changed the cold oil today. Being a lifted 4x4 it's a dedicated vehicle that I rarely drive. I let it drain for at least 1-2 hours. Oil was black, no issues. Filter with gasket removed. New Mobile 1 filer filled 1/2 way, oil put around the ring for seal, installed.
    I filled from 2 partial bottles of full synthetic 5w30 and 1/4 quart of 0w20 (had it on hand for my other car) for cold startup help. I foolishly put a little too much in, and figure I put 6.8 or 6.9 quarts in. Oil pressure at startup went to about the 3/4 mark. Seemed a bit high based on my experience with this and my other similar Tundra. Then it ran from 3/4 mark when cold, down to the 1/4 to 1/2 mark when warmed up and accelerating. These trucks seem to moved between 1/4 to 1/2 when driving them. I ran it, drove it around to get it to operating temps and when it cooled I checked oil levels. It's exactly at the mid-point. I'm wondering now if it was a bit low before. I wish I had paid more careful attention, but I rarely drive it.
    I changed two vehicles so there's no way to measure the amount of oil I drained out. It's possible it had been underfilled or low from prior owner, and I didn't check the level before the oil change... The records I have on this relatively new to me truck is that the last oil change was 15 months and only 1,300 miles ago from a commercial oil change shop.
    I'll keep a close eye on it. Any thoughts...?
    jeremyd likes this.
  2. Jan 6, 2021 at 6:44 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If the engine was fully warmed up & off when you checked level, and it was at or just below the 'full' mark on the dipstick. You're good to go.
    I don't check levels with the engine cold.
    jpink, Boerseun and ToyotaJim[OP] like this.
  3. Jan 6, 2021 at 6:45 PM
    ToyotaJim
    Sorta what I'm thinking. I drove it for 5-10 minutes after oil change, then let it sit for probably 10 minutes and then checked it multiple times on flat surface, and it's at mid-point. I think it's probably fine, but kicking myself for not being more careful.
  4. Jan 6, 2021 at 6:53 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You're fine. A lot of guys report using more oil than the book asks for. My truck usually takes a little under 7qts before its right.
    I dig those wheels by the way.
  5. Jan 7, 2021 at 4:27 AM
    Professional Hand Model
    Hand Protectors
    Manual states drain and fill is 6.5 quarts.
    FSM states ‘Factory Fill’ is 7 quarts. Thats dry fill for a new engine.
    Because I start the truck for about 3 seconds after an oil drain to remove the last bits of stuck oil, I can attest its about .5 quart.
    Conclusion: 7 quarts and the line at the top dimple on the dip stick equals Golden Hands Thumbs Up!
    N84434 likes this.
  6. Jan 7, 2021 at 5:46 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    I do 7 qts everytime on my 05. Always drain when warm and give plenty of time to drain. New toyota filter. This puts me just barely over the full mark. Don't want a partial qt sitting around and a little extra won't hurt
    My oil pressure gauge varies quite a bit. From near half at startup and under load to near 1/4 at low rpm cruising. I've never seen it at 3/4. Maybe under load when cold, but I like my truck too much to do that to her.
  7. Jan 7, 2021 at 5:52 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    5 quart bottle plus 2 quart bottles for every oil change for me, with a Wix filter. Good to go baby!
  8. Jan 7, 2021 at 6:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm glad I'm not alone here. I've tried 6.5-6.8 quarts and it doesn't get me to the full mark. I'll do 7 going forward.
  9. Jan 7, 2021 at 7:31 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    6.5qt brings my dipstick to the middle mark, 7qt to the full mark. It is kind of a PITA to store 1/2 quart so the last oil change I put all 7qt in. Oil pressure seems to be the same and it is always right at the full mark.
  10. Jan 7, 2021 at 7:38 AM
    SouthPaw
    2000 Limited 4x4 AC
    Drain the oil and then start the truck empty with the train plug out?
  11. Jan 7, 2021 at 8:25 AM
    Hand Protectors
    Drain. Put plug back it (old oil filter hasn’t been removed yet). Start truck for 3 seconds. Remove plug and 1/2 quart comes out.
    Do not recommend. Used to do my early Hand Model Cars this way, too. Dangerous!
  12. Jan 7, 2021 at 5:31 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    “Rules for thee but not for me.”
