Missing Lower Front Bumper Clips
Discussion in '2.5 Gen Tundras (2014-2021)' started by NCSkeeter, Sep 7, 2019.
  1. Sep 7, 2019 at 5:22 PM
    NCSkeeter
    NCSkeeter [OP] New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    The bumpers on my 2019 were really crooked from the factory so I asked the dealer to straighten them under warranty at my 6 month service. They did and they look much better now. There was greater than 1/4" difference in gap bt left and right. Front still isn't perfect, but its a lot better.
    While crawling around the truck to see if they caused any collateral damage, I notice it appears that some screws and clips are missing at the very bottom of the front bumper. There's a screw through a tab into the skid plate in the center. On each side there's a tab that looks like it should have a screw into the skid plate, but nothing's there.
    Below image is from a website I found for an aftermarket skid plate install. It indicates there's three screws.
    Image pulled from:
    https://www.addictivedesertdesigns.com/news/2014-2018-toyota-tundra-front-bumper-removal
  2. Sep 7, 2019 at 5:44 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    My 2019 has screws as pictured.
    Edit- it dose have clips on the skids that they screw into. Here is a pic. I had installed a rci skid a while ago and it mounts differently so I was thinking of it when I thought it screwed into the crossmember
    NCSkeeter[OP] likes this.
  3. Sep 7, 2019 at 5:50 PM
    NCSkeeter
    i have no screws nor clips on the outer holes. I guess it’s back to the dealer Monday.
  4. Sep 7, 2019 at 5:53 PM
    pickeledpigsfeet
    Kings & Icons
    Wonder how they lost those plastic clip in nuts? The are in there really good. I could see forgetting to put the screws back in. They must have had to remove them when trying to fit the bumper cover. They clip in and cant fall out.
    NCSkeeter[OP] and Black Wolf like this.
  5. Sep 7, 2019 at 5:54 PM
    pickeledpigsfeet
    Kings & Icons
    Here is a pic
  6. Sep 8, 2019 at 2:39 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I wished you would have posted earlier. I just tossed the ones off of mine last week.
  7. Sep 8, 2019 at 2:58 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Mine disappeared the first dealer oil change. They plastic flapping around makes a racket over bumps and wash boards now
    Boerseun likes this.
  8. Sep 8, 2019 at 3:52 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The rattle that causes took me months to find...
    You can order them online for almost nothing. They have broken on me a few times, and i now just zip tie the outer ones
  9. Sep 8, 2019 at 5:32 PM
    NCSkeeter
    Been planning on using my two free oil changes, but this may change my mind....
    If they didn’t put this back in right, how am I supposed to be confident that all the clips and screws I can’t see are in right....
    No one but me ever touched my old taco and I liked it that way.
    NewImprovedRon likes this.
  10. Sep 8, 2019 at 5:38 PM
    15whtrd
    15whtrd Mr. Blonde
    Before I got my RCI skid I dealt with those little clips often. One was stripped the first time I took the skid plate down to change the oil. I got the dealer to give me a couple. Then I bought some extras. They are really cheap. I suggest just keeping a few in the toolbox. A coarse metal screw into a plastic fitting. Recipe for a stripping LOL
  11. Sep 8, 2019 at 5:40 PM
    15whtrd
    15whtrd Mr. Blonde
    I have one left besides the ones in my old skid plate. Here’s the package and part numberCC631519-091F-426A-9BE1-A58B5B189F68.jpg
    Hbjeff, TWJLee and NewImprovedRon like this.
  12. Sep 8, 2019 at 5:41 PM
    NCSkeeter
    Thanks! Unfortunately I need the screw too....
    15whtrd[QUOTED] likes this.
  13. Sep 8, 2019 at 5:42 PM
    15whtrd
    15whtrd Mr. Blonde
    As I’m sure you’d like to make the dealer fix it all up for you, see if you can just get them to give you the screws and some extra inserts. I’m sure you can do a better job. They get the guy that sweeps the floors to do that stuff
  14. Sep 8, 2019 at 5:49 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Oh GOD No, another thing to go check under the truck!!! :annoyed:
  15. Sep 9, 2019 at 9:43 AM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    I just left off my skid plate (for the time being, since I dont off road regularly)
    But yes these plastic inserts break regularly so ask for a few extra when at dealer. I change my own oil. Not worth the time to go get the “free” oil changes
  16. Sep 9, 2019 at 3:40 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    They break, strip and fall out pretty easily, especially after several R&Rs. All have happened to one or more of mine (and I don't gorilla them when I tighten). Not a good fastener choice for repetitive use.
    15whtrd likes this.
  17. Sep 9, 2019 at 4:22 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    The issue is if you don't start the thread at the same spot you will be cutting a new one, eventually it will no longer work.
  18. Sep 9, 2019 at 5:40 PM
    15whtrd
    15whtrd Mr. Blonde
    You just got to get some bolts like this. The skid plate comes with them! Also has an access door for the oil filter. Then I added a fumoto valve for easy mess free oil draining.F515681B-0C94-4292-8605-F52220AA6D31.jpg
  19. Sep 9, 2019 at 5:56 PM
    coTony
    Tony
    Montrose, CO
    Stealership tosses them because the less hardware the quicker their job. They have done that to all our vehicles and I always have them correct it
    NewImprovedRon and Hbjeff like this.
  20. Sep 10, 2019 at 12:34 PM
    matictundra
    Franco
    AZ
    I have the same setup. I actually have their entire skiddies, trans and fuel.
  21. Sep 10, 2019 at 1:11 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s the plan eventually. Hard to do all at once. I let my truck mods nickel and dime me LOL
  22. Sep 13, 2019 at 6:07 AM
    JRTundra
    JRTundra New Member
    Jeff
    Indiana
    2014 SR5 Crewmax 4x4
    What does RCI use as fasteners for the oil access door? Are they a standard size or do they require a special tool? I'm looking to get rid of my factory skid because all of my front bumper tabs have magically disappeared and the damn thing rattles like crazy. Thanks
  23. Sep 13, 2019 at 1:27 PM
    matictundra
    Franco
    AZ
    I use 5mm metric hex to open the RCI oil filter access hole.
    15whtrd and JRTundra like this.
  24. Sep 15, 2019 at 12:35 AM
    JRTundra
    JRTundra New Member
    Jeff
    Indiana
    Thanks @matictundra. I appreciate the response.
  25. Sep 15, 2019 at 4:52 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yep. An old trick to avoiding cross-threading is to turn the fastener counter-clockwise one turn, or until you hear/feel the thread lead fall into position, before tightening. :thumbsup:
  26. Sep 16, 2019 at 11:35 AM
    matictundra
    Franco
    AZ
    Exactly what I do but no dealer tech does this, lol.
  27. Sep 16, 2019 at 12:54 PM
    JohnLakeman
    Nope, very unlikely. The worst are untrained tire techs that place the lug nut on the lug chamfer, and then run it up using full impact gun capacity. Lug is over-torqued at least, stripped-buggered at worst. Think about that while you're getting your next "free" tire rotation. :mad: :rant:
  28. Oct 1, 2022 at 11:39 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I know this is an older thread but has anyone found the part number for the screws that go into the retaining clips? First few Toyotacare oil changes resulted in missing clips and screws for me. Thanks.
  29. Oct 1, 2022 at 11:47 AM
    Nbab23[QUOTED] likes this.
  30. Oct 1, 2022 at 12:56 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Awesome thank you. I kept looking at the bumper diagrams. Wasn't even thinking skid plate.
