Missing Jack and Spare kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by clauderdale001, Jun 29, 2021.
  1. Jun 29, 2021 at 12:06 PM
    clauderdale001
    clauderdale001 [OP] New Member
    Cody
    Hernando, MS
    2017 White Tundra TSS
    It took me a year and a half to notice the OEM jack and spare tire kit was missing in my used 2017 Tundra. I called the local dealer and was quoted $275 to replace it. Can you guys offer some suggestions for a roadside jack? I believe I will need a minimum height extension of 20". (Standard truck height; no lift) I'm pretty sure I can cut a tool on the CNC table to lower the spare with.
  2. Jun 29, 2021 at 12:10 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Bottle jack some 4x4
  3. Jun 29, 2021 at 12:10 PM
    Taco-Spike
    Two Trucks
  4. Jun 29, 2021 at 12:21 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Not sure where you are located, but if you are in the USA you may be able to find a military surplus Hummer H1 scissor jack. Well made, lots of reach and quite stable.
    Black Wolf likes this.
  5. Jun 29, 2021 at 12:27 PM
    FleaBay usually has a few.....decent jack
  6. Jun 29, 2021 at 12:29 PM
  7. Jun 29, 2021 at 12:47 PM
    clauderdale001
    Cody
    Hernando, MS
    I have looked into this one. The 15.375" lifting range is what worries me about it.
    Taco-Spike[QUOTED] likes this.
  8. Jun 29, 2021 at 12:49 PM
    clauderdale001
    Cody
    Hernando, MS
  9. Jun 29, 2021 at 1:04 PM
    Sunnier
    Sunny
    San Diego, CA
    I use this one. Tractor Supply carries it. Free one year warranty, or you can buy a second year for $10. If you leave it in the bed though, it’ll get rusty and need replacement. And it’s much larger than the Jack space in your truck.
  10. Jun 29, 2021 at 1:40 PM
    2mchfun
    +1 also considering to compliment my hi lift, factory, and 12T bottle. Waiting until I get my bed cover finished up. Different jacks have different uses. Been loaded before with junk jack and a flat, not good to call a wrecker in a rural area over a flat tire.
  11. Jun 29, 2021 at 1:49 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Junkyard?
    G10dra likes this.
  12. Jun 29, 2021 at 1:51 PM
    clauderdale001
    Cody
    Hernando, MS
    Amen.
  13. Jun 29, 2021 at 2:22 PM
  14. Jun 29, 2021 at 4:24 PM
    clauderdale001
    Cody
    Hernando, MS
    The oem one is probably reliable if I could find a similar one for real cheap. It’s a bottle jack but non hydraulic.
  15. Jun 29, 2021 at 4:29 PM
    A solid piece of 4X6 would be a nice to have too.
    2mchfun likes this.
  16. Jun 29, 2021 at 4:39 PM
    2mchfun
    I was just going to post it doesn't hurt to have a few blocks in your rig, jack base, and wheel chocking too!
