Missing 3 Fuel Lug nuts
Discussion in 'Wheels & Tires' started by Spencey, Sep 4, 2021.
  1. Sep 4, 2021 at 9:46 AM
    Spencey
    Spencey [OP] New Member
    Spence
    2012 Black Tundra TRD-Off Road Limited Crewmax
    Flowmaster, Custom Interior, Air-raid Air intake,
    Hey guys, I saw a lot of threads but I can’t seem to confirm specifically what I need in terms of the lug nuts for my fuel rims. Does anyone have any links to where I can buy Gorilla M14x1.5RH/T & Gorilla M14x1.5ET3 lug nuts. I went to Schwab and they said I would have to order them online.
    2012 Tundra 18in rims
  2. Sep 4, 2021 at 10:36 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I would think Fuel might sell the matching lugs for their wheels. You can ask. Other than that, I would search the part number and see what hits you have. Amazon has a good number of all sorts of lugs available.
  3. Sep 4, 2021 at 10:39 AM
    frichco228
    also check summitracing
  4. Sep 4, 2021 at 10:45 AM
    frichco228
  5. Sep 4, 2021 at 11:12 AM
    Spencey
    Spence
    Unfortunately, Fuel does not provide lug nuts. They only make the wheels, so they don’t really help out when it comes to that. The ones you sent though seem pretty close to the closed cap ones. Thanks, I will see what I can find out.
  6. Sep 4, 2021 at 11:19 AM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Most tire shops that sell wheels will have lugs nuts in stock, at least the ones out here do. You know, that whole sell someone some rims probably need the appropriate lug nuts thing...
  7. Sep 4, 2021 at 3:42 PM
    Spencey
    Spence
    yeah you are probably right. I just went into a few shops. People are weird about Toyota though. They have lug nuts for a lot of wheels but Toyota lug nuts are unicorns to them. Specifically custom lugs. I will keep on hunting though. We don’t have the biggest market down in Montana.
  8. Sep 4, 2021 at 7:23 PM
    Gravy
    Yucaipa, California
    Ah, didn't know you were in the sticks. We've got alot of wheel shops down here. The lugs shouldn't be rare though, just a standard metric acorn. The first pic is your locking lug (spline). My Fuel Vapor rims use a similar lug cover to the wheels you have pictured, and they did take a "shallow" or shorter lug to fit under it. Anyways, good luck with the hunt.
    Anyways, type "14x1.5": in Amazon search bar, you get gobs of options.
    Amazon.com: Gorilla Automotive 26043SD Small Diameter Duplex Open End Chrome Lug Kit (14mm x 1.50 Thread Size) - Pack of 20 Seems excessive to use all splines, don't know why they dont seem to sell 4/1 mixed sets, but hey, I think these should do the trick. If the socket hole under your cap is deep, you can probably get a bigger set.
